Hi, Is there any difference in encoding of an interlaced video in the following 2 ways: 1. just considering it as a progressive video and doing a progressive encoding. 2. doing a frame encoding. Again, field encoding is just matching fields instead of full frames, of an interlaced video, during motion estimation. Is that a correct explanation I am having? Please correct me if I am wrong. Thanks in advance.... jag
newbie question: difference b/w frame mode and progressive encoding of interlaced video
Started by ●August 16, 2005
Reply by ●August 16, 20052005-08-16
jagadeeshbp@gmail.com wrote:> Is there any difference in encoding of an interlaced video in the > following 2 ways: > 1. just considering it as a progressive video and doing a progressive > encoding. > 2. doing a frame encoding.Since a frame encompasses both interlaced fields, both of the options you listed do exactly the same thing. If you have a truly interlaced video, it is almost always better to treat each field seperatly, as the correlation between regions in the same field is higher than that across both fields interlaced into the same frame. Remember, each field is a different point in time.> Again, field encoding is just matching fields instead of full frames, > of an interlaced video, during motion estimation.It depends on the encoding method. Some do more, some do the same, some do less.
