amaraavati@yahoo.com (amara vati) writes:> after some thought, I feel I could be wrong. I am confused. cud > somebody enliten pls. > > amarHi Amar, You've already gotten some good responses, but allow me to reason with you from this viewpoint. Define energy over a period T as E(T) = /int_{-T/2}^{+T/2} |x(t)|^2 dt. Note that, unit-wise, this integral works out since |x(t)|^2 has units of power (assuming x is volts and there is an implied resistance of 1 ohm), and power times time (|x(t)|^2 * dt) is energy. A finite-energy signal is one in which \lim_{T --> \infty} E(T) < \infty. Then, if a signal has finite-energy, it must have zero power, since the total average power in a signal is \lim_{T --> \infty} E(T)/T. Since E(T) is always finite but T increases without bound, the ratio must approach 0. Similarly, define the average power over a period T as P(T) = (1/T) * E(T). A finite-power signal is one in which \lim_{T --> \infty} P(T) < \infty. Note that a finite non-zero power signal must necessarily have infinite energy, otherwise the limit above would tend toward zero since T would keep increasing while E(T) stops at some finite value. Now also note that power spectral density has the units of watts/Hz, which is equivalent to joules since watts = joules/second and Hz = 1/second. OK, so what? Well, this means that any signal x which has a PSD Sxx(w) (I'm using "w" here for omega, 2*pi*f) that is non-zero somewhere has a finite, non-zero power and thus must have infinite energy. That infinite energy could come from a single sinusoid at frequency w0, in which case Sxx(w0) = A * \delta(w-w0), where "\delta(x)" is the Dirac delta function. This must be true since there is only one isolated point in the Sxx(w) function that has a non-zero value, thus the energy represented by that point must be infinite. Stated another way, the power in a zero-Hz bandwidth must be non-zero. Or the infinite energy could come from a continuous range of frequencies, say, w1 to w2. In that case, the energy at one particular frequency can be finite, while the sum of energies at an infinite number of points (those in the interval of w of w1 to w2) remains infinite. The power, then, at any one frequency in the range w1 to w2 is zero since the energy is finite. So, that explains it. A signal with a smooth PSD (i.e., no Dirac delta functions) will have a finite energy at any particular frequency, which means the power at that frequency is zero. For a white spectrum, there is energy at DC, but there is no power there. -- % Randy Yates % "Bird, on the wing, %% Fuquay-Varina, NC % goes floating by %%% 919-577-9882 % but there's a teardrop in his eye..." %%%% <yates@ieee.org> % 'One Summer Dream', *Face The Music*, ELO http://home.earthlink.net/~yatescr
DC Component of White Noise?
Started by ●August 11, 2004
Reply by ●August 13, 20042004-08-13
Tim Wescott wrote:> Andor wrote:...> It means that in theory there will be no shot where the exact centroid > of the bullet lies over the exact centroid of the y axis -- the same for > any other finite set of points on the target that have zero area.You argue as follows: The probability of the shot landing on the Y axis is zero, therefore "in theory", this will never happen. I argue: The probability of the shot landing anywhere is zero (given 2-dim Gaussian distribution). Still, every shot hits some coordinate pair (X,Y). So your reasoning that an event with zero probability cannot happen, is flawed.> What this tells us about the DC content of the Gaussian white noise is > that because DC is a single point on the frequency axis when you > integrate the PDF from 0 to 0 there will be no area under the curve > (finite number * zero length = zero).Agreed, but that is not what I was aiming at.> If you mean n as being sample time then s(n) = 1 for all n has a mean > value of 1, not zero, so it cannot be an instance of a zero mean > Gaussian white noise process.But of course it can. It just has zero probability - but as we saw above, that does not immediately imply that it cannot happen. The law of large numbers tells us that the mean of a standard Gaussian white noise process with time index n converges to zero P-almost-surely as n goes to infinity, where P is the probability measure implied by the Gaussian density. This says that the set where the mean does not converge to zero has no mass with regard to measure P. Above example (with the marksman) shows that a set with zero mass need not necessarily be empty (for exactly that P). The process s(n) = 1, for all n, is in such a set. Regards, Andor
Reply by ●August 18, 20042004-08-18
"amara vati" <amaraavati@yahoo.com> wrote in message news:f89b870.0408110653.35703f9c@posting.google.com...> a zero mean process could have no DC component in it. PSD is a > statitistical curve and not the spectrum itself. PSD non zero at DC > doesnt meant there is a net DC component in noise. If that be the > case, I should be able to generate power from noise. To understand PSD > better, you should see that if u integrate PSD over the entire > spectrum, u get the variance of the process. that is PSD gives you a > picture of how much each part of the spectrum contrubutes to the > variance. that means you should add noise of same variance to all the > tones as white noise has uniform PSD > > amar > > le.com>... > > White noise has a PSD = No/2 for all frequencies w. Does this hold > > true at w = 0? In this case does that mean that white noise must have > > a DC component. What about zero mean white noise? Does this have: > > PSD(w) = No/2(1 - d(0)) where d(w) is the Kronecker Delta? > > > > I am simulating a baseband OFDM system and I want to add system noise > > at the appropriate level for a given SNR. Do I add noise on all tones > > equally? Given that the DC tone is not used, should I also turn off > > the noise on this tone? I am assuming a zero-mean white-noise channel.If you pass theoretical white noise through a simple RC time-constant you can calculate the theoretical PSD at the output quite easily and it goes right down to DC of course. However this does not mean there is a DC component at the output.As for the white noise itself,if it has zero mean then there is no DC component.With AC coupling this is usually the case unless there are DC offsets somewhere. Tom
