I have been looking at the many low power single chip processors available. But most are only 16 Mhz. I know that the higher the speed the more the current. Are there any low power DSP chips available that compare to TI MSPxxx ? Thanks
What is the lowest power dsp ?
Started by ●August 30, 2005
Reply by ●August 30, 20052005-08-30
Donald, The TI MSPxxx series was the power/price leader I found when searching for these features about three months ago. --Randy
Donald <donald@dontdoithere.com> wrote in news:UcGdnfiE-ff314neRVn- pQ@forethought.net:> I have been looking at the many low power single chip processors > available. But most are only 16 Mhz. > I know that the higher the speed the more the current. > Are there any low power DSP chips available that compare to TI MSPxxx ? > > ThanksYou might take a close look at the Blackfin. The switching power supply is adjustable to a very low voltage. The Blackfin is very fast. If you run at a reduced clock, it may still be fast enough for your application and operate at low power. -- Al Clark Danville Signal Processing, Inc. -------------------------------------------------------------------- Purveyors of Fine DSP Hardware and other Cool Stuff Available at http://www.danvillesignal.com
> The Blackfin is very fast. If you run at > a reduced clock, it may still be fast enough for your application and > operate at low power.Actually that brings up a good point, Al. If you utilize the sleep mode of the DSP (whatever the manufacturer), so that the "real work" is performed in short bursts and the rest of the time the processor remains asleep, you may be able to get very decent power consumption performance. I think price will bite you, however, for anything like a Blackfin or C55/6x when compared with the MSPxxx family. --Randy
I'm not sure, but I think you can run a dsPIC at 32 kHz and the current consumption should only be micro amps at 3V. Thomas "Donald" <donald@dontdoithere.com> wrote in message news:UcGdnfiE-ff314neRVn-pQ@forethought.net...>I have been looking at the many low power single chip processors available. >But most are only 16 Mhz. > I know that the higher the speed the more the current. > Are there any low power DSP chips available that compare to TI MSPxxx ? > > Thanks
well the ARM processors aren't as low power (mips/mA), but depending on your application they may be lower power, the TI MSP are 16 bit machines so even though the ARM's are higher power they are doing 32 bit math, so you may be able to run them at much lower frequency to get the job done
"Randy Yates" <yates@ieee.org> wrote in message news:1125411735.783786.255790@g43g2000cwa.googlegroups.com...>> The Blackfin is very fast. If you run at >> a reduced clock, it may still be fast enough for your application and >> operate at low power. > > Actually that brings up a good point, Al. If you utilize the sleep mode > of the DSP (whatever the manufacturer), so that the "real work" is > performed in short bursts and the rest of the time the processor > remains asleep, you may be able to get very decent power > consumption performance. I think price will bite you, however, > for anything like a Blackfin or C55/6x when compared with the > MSPxxx family. > > --Randy >That is a good point. The MSP430 derives much of its low-power characteristics from this principle. Its standby current is ultra-low so with the device waking up very infrequently the average current consumption approaches the sleep current. The 55x DSPs have low sleep current as well. Let me qualify that by saying it's very low for a DSP (I think that's sort of like "runs fast for a catcher"). From what I've seen comparing Blackfin and 55x it appears the Blackfin has lower operating current than the 55x but the 55x has MUCH lower sleep current. So for many real-world applications you end up with lower average current consumption using 55x than you would with Blackfin. My two cents... Brad
steve wrote:> well the ARM processors aren't as low power (mips/mA), but depending on > your application they may be lower power, the TI MSP are 16 bit > machines so even though the ARM's are higher power they are doing 32 > bit math, so you may be able to run them at much lower frequency to get > the job doneHow does it compare to the 'C33? Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Reply by ●August 31, 20052005-08-31
> That is a good point.The MSP430 derives much of > its low-power characteristics from this principle. > Its standby current is ultra-low so > with the device waking up very infrequently > the average current consumption > approaches the sleep current.I dont think there is a more(or less?!) ultra-low power MCU with this rich a set of features(MAC,DMA etc.) at this price point. (BTW, Uncle Tom has ensured that MSP430 has gobbled a significant portion of the 8-bit market by offering the 16-bit, semi-DSP/full MCU MSP430) There is an interesting Evangelist(Vincent Chan) at TI for MSP430, who calls the MSP430 "The Sun Kissed MCU".I attended one of magic shows where he ran a motor with MSP430 just by plunging the wires into a juicy chinese apple.Just like magic. --Bhooshan This message was sent using the Comp.DSP web interface on www.DSPRelated.com
