rhnlogic@yahoo.com wrote:> Jerry Avins wrote: > >>rhnlogic@yahoo.com wrote: >> >>>Is there any rule-of-thumb on what the phase response needs to look >>>like near any artificially sharp transition in a frequency domain >>>filter in order to reduce ripple (caused by the sharp transition) >>>in the continuous frequency response, if that's at all possible? >> >>We both know that linear-phase filters can be made arbitrarily sharp, >>so I don't understand what you're asking for. > > > I was refering not to arbitrarily sharp filters, but to artificially > sharp filters, such as the one the OP was using which quantizes > the magnitude response to either 1.0 or zero (obvious not a flat > filter). My question was about whether allowing degrees of freedom > in the phase response would help anything (assuming more than 1 bin > of 1.0 coefficients, or course). e.g. would his box filter get > any "better" if he removed all linear phase restrictions?Those filters aren't arbitrarily sharp. They can't be sharper than the bin spacing, even in one's dreams. A plot of the continuous frequency response shows poor attenuation between the zeroed-out bins and between the unity-gain bins near the transition. Using a longer FFT to put the bins closer together raises the frequency of the Gibbs oscillations, just as adding more frequency terms to a synthesized square wave does, but it doesn't affect the amplitudes. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Frequency domain filtering (rectangular window question)
Started by ●September 21, 2005
Reply by ●September 30, 20052005-09-30
