Hi folks, Can anyone give me some idea about demapping/detection algorithm for Dual carrier modulation . its used in OFDM based UWB systems. DCM is like mapping same databits into different constellation points from different constellation diagrams. In OFDM UWB 4databits are mapped into 2 I/Q points in (16 QAM like constellation) from 2 different constellation digrams. http://www.wimedia.org/imwp/idms/popups/pop_download.asp?ContentID=6394 Any idea how to detect/demodulate? Thanks John.
Dual carrier modulation / signal space diversity : demapping/detection
Started by ●October 25, 2005
Reply by ●January 19, 20062006-01-19
Hi, You can use ML & LLR decoding. ML based on symbol decision use minimum distance from two constellations. LLR based on bit dicision use log-likelihood functions. I knew that ML & LLR should show same performance. they show same performance in case of 16QAM with 1 constellation. But, when I simulated both in DCM, they were different, ML was better than LLR. I'm still wondering why....>Hi folks, > Can anyone give me some idea about demapping/detection algorithm for >Dual carrier modulation . its used in OFDM based UWB systems. > >DCM is like mapping same databits into different constellation points >from different constellation diagrams. In OFDM UWB 4databits are mapped >into 2 I/Q points in (16 QAM like constellation) from 2 different >constellation digrams. > > >http://www.wimedia.org/imwp/idms/popups/pop_download.asp?ContentID=6394 > >Any idea how to detect/demodulate? > >Thanks >John. > >
