How do I setup Code Composer Studio v2 to compile for the TMS320F2808? And how do I setup my XDS510PP PLUS JTAG Scan Path Emulator to work with this DPS? I suspect that I must download a lot of updates?
Setup Code Composer Studio for TMS320F2808? (HELP)
Started by ●November 18, 2005
Reply by ●November 20, 20052005-11-20
Moppe wrote:> How do I setup Code Composer Studio v2 to compile for the TMS320F2808? > > And how do I setup my XDS510PP PLUS JTAG Scan Path Emulator to work with > this DPS? > > I suspect that I must download a lot of updates? > >The 2808 uses the same core as the 2812. You should be able to run it without any updates. The main thing you'll need is the gel file to set up the memory map correctly for the 2808. Rather than writing your own I recommend going to the Spectrum Digital website and getting the most recent emulation drivers that correspond to the version of CCS you're using. The gel file should come in there as there are some 2808 configurations pre-packaged. Brad
Reply by ●November 25, 20052005-11-25
