Frank wrote: ...> I don't know what you people are talking about. > Back to my question, how do I make a +-5V?If you don't know what we're referring to, you're better off buying what you need. Power supplies are cheap compares to your board. If you post your current requirements, we can suggest specific hardware. Using supplies with adjustable voltage but without knob locks is a fairly common way to smoke parts. Be careful. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Quick question, how do I supply +-5V?
Started by ●December 1, 2005
Reply by ●December 2, 20052005-12-02
Fred Marshall wrote:> "Frank" <Francis.invalid@hotmail.com> wrote in message > news:438fa5a4@news.starhub.net.sg... > >>I have a large board which asks for three power supplies, +3V, +3.3V and >>+-5V. >>First two can be easily satisfied with two HP power supplies (each has its >>own >>GND pin also). Regarding +-5V, can I replace with an HP power supply set >>to >>10V, -5V pin connect to HP's ground and +5V to power? > > > You might with some caveats. > First, the intended +-5v supply needs to be floating with respect to the > other supplies. > Then the 10v voltage difference can be reference wherever you want in theory > and often in practice. > > The challenge is: now that you've floated the supply, how will you reference > it to the ground or 0v point on the board? > > Think of the +-5v supply as a 10v battery. A battery "floats" with no > problem. > Unless you do more, the result looks like this: > > > +------------------------------>+5v > | > | > +----+ +--------------->+3.3v > | 10v| +----+ > +----+ |3.3v| +----------+3v > | +-+--++----+ > | | |3.3v| > | | +-+--+ > | | | > | | | > | +-----+---------> 0v: the reference for +3.3v, +3v > | > | > | > +------------------------------>-5v > > With the 10v battery floating, there is no reference to the > other batteries. Current flowing through the circuit board will cause > the +/-5v terminals to go almost anywhere relative to 0v. Depending on > what's on the board, > the +5v terminal could end up at -6v and the =5v terminal at -15v (both > relative to 0v of course). > > > > +------+----------------------->+5v > | | > | | +--------------->+3.3v > +----+ | +----+ > | 10v| | |3.3v| +----------+3v > +----+ ++-+ +-+--++----+ > | |R1| | |3.3v| > | ++-+ | +-+--+ > | | | | > | | | | > | +-------+-----+---------> 0v: the reference for +3.3v, +3v > | +--+ > | |R1| > | ++-+ > | | > +------+----------------------->-5v > > A resistor divider with current much higher than the +/-5v > loads and connected to the 0v reference will refer the +/-5v > to the rest of the batteries. > It's not a very elegant or even practical solution but it makes the > point to address your question.You can make Fred's solution more practical by adding an operational amplifier that can deliver the difference between +5 and -5 currents. +------+-------------------------------------------->+5v | | | | +--------------->+3.3v +----+ | +----+ | 10v| | |3.3v| +---------+3v +----+ ++-+ +-+--+ +----+ | |R1| +----------+ | |3.0v| | ++-+ | |\ | | +-+--+ | | +---|-\ | | | | | | +---+----------+------+---------> 0v | +--------|+/ | +--+ |/ | |R1| | ++-+ | | +------+----------------------->-5v Is it worth it? Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Here's a cheap and quick, potentially noisy solution: 1. Buy two 5VDC "wall wort" power supplies. 2. connect the (-) from one to the (+) from the other. This is your common ground lead.. 3. The + lead will give you +5VDC 4. The - lead will give you -5VDC. Make sure the wall worts are rated to deliver enough current otherwise you'll get too much voltage drop for your app. Note that this supply is UNREGULATED, that is, increasing load will decrease your voltage. If you need a regulated supply, use 7-12VDC wall worts (to compensate for the voltage drop across the regulators), buy a 7805 positive and a 7905 negative 5V regulator, two 3300uF electrolytics and two 1uF ceramic caps to filter the output and a small PCB. There are tons of diagrams how to arrange things to get what you want. Google is your friend. Total cost of parts should be about $5 to build the regulator, plus some sort of enclosure if you require. If you happen to have two matching wall worts of >6VDC you can probably use them if you regulate, the regulator chips can accept up to ~35VDC. note that with larger input voltages you'll need to use heatsinks on the regulators to dissipate the extra power/heat. Dave "Frank" <Francis.invalid@hotmail.com> wrote in message news:438fcbcb@news.starhub.net.sg...> > "Jerry Avins" <jya@ieee.org> wrote in message > news:gpKdnbflleKAIhLeRVn-vg@rcn.net... > > Steve Underwood wrote: > > > Jerry Avins wrote: > > > > > >> Ryan Weihl wrote: > > >> > > >>> Michael R. Kesti wrote: > > >>> > > >>>> Frank wrote: > > >>>> > > >>>>> I have a large board which asks for three power supplies, +3V, > > >>>>> +3.3V and > > >>>>> +-5V. > > >>>> > > >>>> > > >>>> > > >>>> > > >>>> If I read you correctly, that's four supplies: +3V, +3.3V, +5V, and > > >>>> -5V. > > >>>> > > >>>>> First two can be easily satisfied with two HP power supplies (each > > >>>>> has its own > > >>>>> GND pin also). Regarding +-5V, can I replace with an HP power > > >>>>> supply set to > > >>>>> 10V, -5V pin connect to HP's ground and +5V to power? > > >>>> > > >>>> > > >>>> > > >>>> > > >>>> No. Doing so would provide zero volts to the board's -5V rail and > > >>>> +10V to > > >>>> its +5 rail. > > >>>> > > >>>> You need four supplies. > > >>>> > > >>> will an ATX supply not do? > > >>> rw > > >> > > >> > > >> > > >> Maybe not. Compound switchers need a load on the main supply in order > > >> to come up, and the auxiliary supplies aren't always well regulated. > > >> > > >> Jerry > > > > > > > > > They also make more noise than a neo-natal nursery. :-) > > > > If he knows what he's doing, ha can load the 10V supply with a beefy > > op-amp connected as a follower to a divider across the rails and ground > > its output. If something goes wrong, it can blow the board unless he > > uses Zener-cum-fuse protection. There are DC-DC power-supply bricks and > > chips that can probably supply all the -5 needed from a +5 supply. > > > > Jerry > > -- > > Engineering is the art of making what you want from things you can get. > > ����������������������������������������������������������������������� > > I don't know what you people are talking about. > Back to my question, how do I make a +-5V? > >
<previous replies were snipped> Frank wrote:> I don't know what you people are talking about. > Back to my question, how do I make a +-5V?We need answers to these basic questions: 1)You need -5 volts, +5 volts, +3.3 volts, and +3.0 volts - correct? (can you use just +3.3 volts instead of both +3.0volts _and_ +3.3volts?) 2)How much current do you need for each voltage? 3)What voltages and currents do your 2 HP power supplies produce? Assuming that the HP's can produce negative voltage (with respect to the HP's GND), then set one HP for -5 volts and set the other one for +5 volts. Then use Low-DropOut (LDO) voltage regulators to produce the +3.0 volts and +3.3 volts. Dave Pollum
In article <438fcbcb@news.starhub.net.sg>, "Frank" <Francis.invalid@hotmail.com> wrote:> I don't know what you people are talking about. > Back to my question, how do I make a +-5V?Swing and a miss -- |\/| /| |2 |< mehaase(at)gmail(dot)com
Dave Pollum wrote:> <previous replies were snipped> > > Frank wrote: > >>I don't know what you people are talking about. >>Back to my question, how do I make a +-5V? > > > We need answers to these basic questions: > 1)You need -5 volts, +5 volts, +3.3 volts, and +3.0 volts - correct? > (can you use just +3.3 volts instead of both +3.0volts _and_ > +3.3volts?) > 2)How much current do you need for each voltage? > 3)What voltages and currents do your 2 HP power supplies produce? > > Assuming that the HP's can produce negative voltage (with respect to > the HP's GND), then set one HP for -5 volts and set the other one for > +5 volts. Then use Low-DropOut (LDO) voltage regulators to produce the > +3.0 volts and +3.3 volts.If those hp supplies are like mine, either the positive or negative terminals may be grounded by a link. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
On 2005-12-02, Dave <dspear99ca@yahoo.delete.com> wrote:> Here's a cheap and quick, potentially noisy solution: > > 1. Buy two 5VDC "wall wort" power supplies. > 2. connect the (-) from one to the (+) from the other. This is your common > ground lead.. > 3. The + lead will give you +5VDC > 4. The - lead will give you -5VDC. > > Make sure the wall worts are rated to deliver enough current otherwise > you'll get too much voltage drop for your app. Note that this supply is > UNREGULATED, that is, increasing load will decrease your voltage.Only if you buy unregulated wall warts. You can get regulated 5V wall-warts and cable-lumps. They usually cost more of course. -- Grant Edwards grante Yow! There's enough money at here to buy 5000 cans of visi.com Noodle-Roni!
Reply by ●December 4, 20052005-12-04
On Fri, 02 Dec 2005 11:53:05 -0500, Jerry Avins wrote:> You can make Fred's solution more practical by adding an operational > amplifier that can deliver the difference between +5 and -5 currents. > > +------+-------------------------------------------->+5v > | | > | | +--------------->+3.3v > +----+ | +----+ > | 10v| | |3.3v| +---------+3v > +----+ ++-+ +-+--+ +----+ > | |R1| +----------+ | |3.0v| > | ++-+ | |\ | | +-+--+ > | | +---|-\ | | | > | | | +---+----------+------+---------> 0v > | +--------|+/ > | +--+ |/ > | |R1| > | ++-+ > | | > +------+----------------------->-5v >The main problem with this scheme is that if either of +5 or -5 volt rails tries to draw more than a few mA, the opamp won't be able to source or sink that much current, so that rail will droop. (The other rails will just follow whatever they've been grounded to.) This isn't too bad, but it'll cause the _other_ rail to suddenly spike by the same amount in the opposite direction. So, a 5A spike on the +5 rail might cause the -5 rail to go to -10V, possibly smoking something funny (like components.) I'd say you need some kind of beefy totem pole output to drive it, meaning a couple of power transistors in addition to the circuit above. Now, is it worth it? Particularly when you can buy a +-5V regulated supply that will source 20A for $50. --- Regards, Bob Monsen Music is the pleasure the human soul experiences from counting without being aware that it is counting. - Gottfried Leibniz
Reply by ●December 5, 20052005-12-05
Frank (Francis.invalid@hotmail.com) wrote: ... : I don't know what you people are talking about. : Back to my question, how do I make a +-5V? 'Buy one' is the most sensible suggestion I've seen elsewhere on the thread. *BEWARE* Another one I've seen mentioned is to get 2 stock 5V supplies, A and B, and connect the +5V of A to the 0V of B, and call pair this 0V, thus making the 0V of A -5V and the 5V of B +5V. *BEWARE* This may or may not work - many lab power supplies and some bricks conenct the 0V from the DC side to the mains earth, so doing this with two such supplies will cause funny noises, bad smells and possibly worse as the magic smoke escapes. If you're not sure, don't try ths aproach! --- cds
On Mon, 05 Dec 2005 22:22:54 +0000, c d saunter wrote:> This may or may not work - many lab power supplies and some bricks > conenct the 0V from the DC side to the mains earth, so doing this > with two such supplies will cause funny noises, bad smells and possibly > worse as the magic smoke escapes. > > If you're not sure, don't try ths aproach!The bricks I've used have always isolation, but I live a relatively sheltered life. Where have you seen them, mainly? -- Regards, Bob Monsen "You told me, 'God made the World.'" "No, no!" Harshaw said hastily. "I told you that, while all these many religions said many things, most of them said, 'God made the World.' I told you that I did not grok the fullness, but that 'God' was the word that was used." "Yes, Jubal," Mike agreed. "Word is 'God'" He added. "You grok." "No, I must admit I don't grok." "You grok," Smith repeated firmly. "I am explain. I did not have the word. You grok. Anne groks. I grok. The grass under my feet groks in happy beauty. But I needed the word. The word is God." Jubal shook his head to clear it. "Go ahead." Mike pointed triumphantly at Jubal. "Thou art God!" Jubal slapped a hand to his face. "Oh, Jesus H. What have I done? Look, Mike, take it easy! Simmer down! You didn't understand me. I'm sorry. I'm very sorry! Just forget what I've been saying and we'll start over again on another day. But " "Thou art God," Mike repeated serenely. "That which groks. Anne is God. I am God. The happy grass are God, Jill groks in beauty always. Jill is God. All shaping and making and creating together ." He croaked something in Martian and smiled.
