Bob Monsen (rcsurname@comcast.net) wrote: : On Mon, 05 Dec 2005 22:22:54 +0000, c d saunter wrote: : The bricks I've used have always isolation, but I live a : relatively sheltered life. Where have you seen them, mainly? Some of the transformer based ones I have at work are - mind you I'm in the UK where almost everything has an earth (mechanical interlocks stop you plugging anything in without the third pin...) - I'm guessing this isn't an issue in places like the USA as the various American bricks I've accumulated don't have an earth pin... Cheers Chris
Quick question, how do I supply +-5V?
Started by ●December 1, 2005
Reply by ●December 5, 20052005-12-05
c d saunter wrote:> Bob Monsen (rcsurname@comcast.net) wrote: > : On Mon, 05 Dec 2005 22:22:54 +0000, c d saunter wrote: > > : The bricks I've used have always isolation, but I live a > : relatively sheltered life. Where have you seen them, mainly? > > Some of the transformer based ones I have at work are - mind you I'm > in the UK where almost everything has an earth (mechanical interlocks > stop you plugging anything in without the third pin...) - I'm guessing > this isn't an issue in places like the USA as the various American bricks > I've accumulated don't have an earth pin...I know that you Brits have a very positive outlook, but there surely must be a way to supply a negative voltage? Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
"Jerry Avins" <jya@ieee.org> wrote in message news:Db6dnTyYHMr6TgnenZ2dnUVZ_smdnZ2d@rcn.net...>c d saunter wrote: >> Bob Monsen (rcsurname@comcast.net) wrote: >> : On Mon, 05 Dec 2005 22:22:54 +0000, c d saunter wrote: >> >> : The bricks I've used have always isolation, but I live a >> : relatively sheltered life. Where have you seen them, mainly? >> >> Some of the transformer based ones I have at work are - mind you I'm >> in the UK where almost everything has an earth (mechanical interlocks >> stop you plugging anything in without the third pin...) - I'm guessing >> this isn't an issue in places like the USA as the various American bricks >> I've accumulated don't have an earth pin... > > I know that you Brits have a very positive outlook, but there surely must > be a way to supply a negative voltage? > > Jerry >So, wall warts almost never have an earth, even in the UK! Our wall warts usually have a plastic 'earth' pin to overcome the interlock. Most power supplies that are a separate 'brick' connect with a two wire connection to the mains, live and neutral, as in the US. Here's a photo of a UK mains lead for this:- http://www.maplin.co.uk/images/Full/1168i0.jpg In the UK, such things are called 'double insulated', see :- http://en.wikipedia.org/wiki/Double-insulated That said, some bricks do have an earth connection as Chris says. These often use a IEC connector like this:- http://en.wikipedia.org/wiki/Power_connector Dunno if the output 0V is connected to this earth. I suspect not in most cases. All the bench DC power supplies I've used, both in the UK and in the US, have separate isolated 0V and earth, usually connectable with a bit of metal. FWIW, Syms.
My first reply would be "buy one". Cost of a PSU is a lot less than the cost of an average board... Otherwise, and assuming your load is less than ~40mA, you can use the circuit in http://sound.westhost.com/project43.htm with a 10v supply. Be careful to separate GND's (since the GND of your +/- 5V is really at 5V....) Simon
Reply by ●December 6, 20052005-12-06
"c d saunter" <christopher.saunter@durham.ac.uk> wrote in message news:dn2ho4$qhn$1@heffalump.dur.ac.uk...> Bob Monsen (rcsurname@comcast.net) wrote: > : On Mon, 05 Dec 2005 22:22:54 +0000, c d saunter wrote: > > : The bricks I've used have always isolation, but I live a > : relatively sheltered life. Where have you seen them, mainly? > > Some of the transformer based ones I have at work are - mind you I'm > in the UK where almost everything has an earth (mechanical interlocks > stop you plugging anything in without the third pin...) - I'm guessing > this isn't an issue in places like the USA as the various American bricks > I've accumulated don't have an earth pin...I have quite a lot of experience with power supply modules (the "open frame type") and I dear say that for instance NONE of the types offered in the Farnell catalog have their - or 0 connected to the PE. From a manufacturer's point of view this would be absolutely stupid because it means that he would have to have two types of each model, one with the + to PE and another with the - to PE. Also in lab supplies you will always see an extra ground terminal, often between the + and - and possibly with a supplied bracket between the ground and -. Besides, many applications need a complete separation from mains, even from ground. So that is another reason for manufacturers not to connect the - to PE(ground). Meindert
On Tue, 6 Dec 2005 08:06:58 +0100, "Meindert Sprang" <mhsprang@NOcustomSPAMware.nl> wrote:>I have quite a lot of experience with power supply modules (the "open frame >type") and I dear say that for instance NONE of the types offered in the >Farnell catalog have their - or 0 connected to the PE. From a manufacturer's >point of view this would be absolutely stupid because it means that he would >have to have two types of each model, one with the + to PE and another with >the - to PE. Also in lab supplies you will always see an extra ground >terminal, often between the + and - and possibly with a supplied bracket >between the ground and -. > >Besides, many applications need a complete separation from mains, even from >ground. So that is another reason for manufacturers not to connect the - to >PE(ground).For any low level measurements, the PE is badly polluted by the noise from switching mode power supply EMC filters etc. For this reason, a separate technical earth (TE) network is often used with only a single contact point between the neutral, grounding electrode and PE and TE earths. A single power supply with the DC side connected to PE would pollute the whole TE network and you would very quickly get rid of such power supplies. Paul
