On Thu, 08 Dec 2005 20:04:20 GMT, Vladimir Vassilevsky <antispam_bogus@hotmail.com> wrote:>Eric Jacobsen wrote: > > >>>Does any one know a way to measure the BER after Viterbi or RS decoding at >>>the Rx side if the uncoded data at the Tx side is unknown? >> >> As mentioned already, re-encode and compare (with the uncorrected >> stream) provides a good estimate of the Viterbi decoder's input error >> rate. > >What if the input stream is in the soft decisions?It usually is, but just taking the sign bit gives an easy comparison for the re-encoder. It's not a problem at all. All you want is the input BER, and the soft information isn't needed (or desired) for that.>> It's then a pretty simple mapping from input error rate to >> output BER. > >The cost of the best path is the distance between the input stream and >the data decoded. There is no need to re-encode the data since the >information is available already.That sounds like a nice alternative, but re-encode and compare is quite simple to implement and is a well-known and often used technique. The re-encoder for a convolution code is, as I'm sure you know, quite simple. The results that you can get with the re-encode and compare technique are pretty accurate, usually well within practical user requirements. For people who implement their own Viterbi decoder I'm sure the technique you mention has merit. Often, though, the decoder is purchased either as a discrete part or an IP block, and access to the internal metrics may be difficult or not possible. Eric Jacobsen Minister of Algorithms, Intel Corp. My opinions may not be Intel's opinions. http://www.ericjacobsen.org
Started by ●December 6, 2005
Reply by ●December 8, 20052005-12-08
