Dear all,
Can anyone point me to some code how to implement a division in a Fixed
Point DSP ?
(Just to see how it works to fit it in mine)
Thx, Wolfgang
Division in Fixed Point
Started by ●December 15, 2005
Reply by ●December 15, 20052005-12-15
"Wolfgang" <Never@nowhere.com> writes:> Dear all, > > Can anyone point me to some code how to implement a division in a Fixed > Point DSP ? > (Just to see how it works to fit it in mine)http://groups.google.com/group/comp.dsp/browse_frm/thread/9a21147500a7ee03/87630d175dd965db?lnk=st&q=fixed+point+division&rnum=4&hl=en#87630d175dd965db Or, repeated here: #include <stdint.h> uint64_t Divide32(uint32_t y, uint32_t x) { uint16_t n; uint64_t answer; uint64_t remainder; uint64_t divisor; answer = 0; remainder = x; divisor = (uint64_t)y << 32; for (n = 0; n < 32; n++) { divisor = divisor >> 1; if (remainder >= divisor) { remainder -= divisor; answer |= (uint64_t)1 << (63 - n); } } for (n = 0; n < 32; n++) { remainder = remainder << 1; if (remainder >= divisor) { remainder -= divisor; answer |= (uint64_t)1 << (31 - n); } } return answer; } -- % Randy Yates % "And all that I can do %% Fuquay-Varina, NC % is say I'm sorry, %%% 919-577-9882 % that's the way it goes..." %%%% <yates@ieee.org> % Getting To The Point', *Balance of Power*, ELO http://home.earthlink.net/~yatescr
Many thanks, Randy.
Yes Google is your friend I was impressed how fast I got relatively good
infos.
Thanks again, Wolfgang
"Randy Yates" <yates@ieee.org> schrieb im Newsbeitrag
news:64pqebz5.fsf@ieee.org...
>> Dear all,
>> Point DSP ?
> Or, repeated here:
> #include <stdint.h>
> uint16_t n;
> uint64_t answer;
> uint64_t remainder;
> uint64_t divisor;
> answer = 0;
> remainder = x;
> return answer;
> Power*, ELO
Wolfgang wrote:> Dear all, > > Can anyone point me to some code how to implement a division in a Fixed > Point DSP ? > (Just to see how it works to fit it in mine) > > Thx, Wolfgang > >All of the fixed point DSP chips that I have worked with have a divide primitive; it basically does one bit's worth of division and leaves the processor in a state to perform the next step with no intervening instructions -- so you can just repeat the thing once for each significant bit in your divisor. So if you're doing this in assembly look in the instruction set reference; there should be examples. If you're doing something like fractional fixed-point in C then do the divide itself in assembly -- it'll be much faster. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
Yes, you're absolutely right about this, Tim. I chose to do it this way on my DM642 project since I don't yet know the architecture of this machine very well and, being a parallel machine it's a lot more difficult to pick up than, e.g., the TMS32054x. The routine is also invoked at a very low rate, so two to three times the cycles of an assembly implementation isn't a problem. --Randy
Randy Yates wrote:> Yes, you're absolutely right about this, Tim. I chose to do it this > way on my DM642 project since I don't yet know the architecture > of this machine very well and, being a parallel machine it's a lot > more difficult to pick up than, e.g., the TMS32054x. The routine > is also invoked at a very low rate, so two to three times the > cycles of an assembly implementation isn't a problem. > > --Randy >At a former employer I maintained a little library of fixed-point routines -- I had a couple of versions that were hand-optimized for their target processors, and one version that was written as close to the ANSI C++ spec as I could get that would compile and run correctly on nearly anything. The portable version used long division pretty much like yours. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
Reply by ●December 16, 20052005-12-16
Dear Randy & Tim,
Many thanks, DM642 let my "ears ring".
Many thanks for the "assembly implementation" hint, now sitting in front of
TI's
Integer Division document.
Do you also have a starting point on how to determine the angle of an
X/Y-pair given in fixed point.
Is there a keyword for an algorithm I can google ?
Many thanks, Wolfgang
> Do you also have a starting point on how to determine the angle of an > X/Y-pair given in fixed point. > Is there a keyword for an algorithm I can google ?take a look at http://dspguru.com/comp.dsp/tricks/alg/fxdatan2.htm works fine for me there is also magnitude estimator on the same site, if you need one Mitja
Many thanks Mitja,
Very interesting case.
Thank you for the link.
Wolfgang
"Korenje" <korenje@yahoo.co.uk> schrieb im Newsbeitrag
news:1134720961.351978.102620@g44g2000cwa.googlegroups.com...
> works fine for me
> Mitja
I also have used something similar to this with good results. Thanks Jim for the trick! --Randy "Korenje" <korenje@yahoo.co.uk> writes:>> Do you also have a starting point on how to determine the angle of an >> X/Y-pair given in fixed point. >> Is there a keyword for an algorithm I can google ? > > take a look at http://dspguru.com/comp.dsp/tricks/alg/fxdatan2.htm > > works fine for me > > there is also magnitude estimator on the same site, if you need one > > Mitja >-- % Randy Yates % "How's life on earth? %% Fuquay-Varina, NC % ... What is it worth?" %%% 919-577-9882 % 'Mission (A World Record)', %%%% <yates@ieee.org> % *A New World Record*, ELO http://home.earthlink.net/~yatescr
