Wolfgang wrote:> Dear all, > > Can anyone point me to some code how to implement a division in a Fixed > Point DSP ? > (Just to see how it works to fit it in mine) > > Thx, WolfgangIn many DSPs usually a primitive division assist operation is available. In those processors where it is not available, there is a fast algorithm that uses multiply-accumulate operations which are usually found in many DSPs to compute the division. It's a fairly old algorithm developed by R.E. Goldschimdt for his MS thesis in 1964 [1]. A Matlab implementation of the algorithm for computing the reciprocal of a 16-bit integer (1<x<2^15) is: function Q = reciprocal(D) if (D < 1) | (D > 32767), error(' Reciprocal Error: Input out of bounds '); end % Normalize the input to fraction 0.5 <= D < 1 % L = 0; while D < 16384 D = 2*D; L = L + 1; end N0 = 1; D0 = D/(2^15); % Reciprocal through multiplication algorithm % y = (1 - D0); N1 = N0*(1 + y); N2 = N1*(1 + y^2); N3 = N2*(1 + y^4); N4 = N3*(1 + y^8); % Round the result. % Q = round(N4*2^(L)); % Saturate the result % Q = min(Q, 32767); For example, on ZSP400 DSP core (http://www.zsp.com) which does not have 1-bit division assist, it takes around 16 cycles to perform one reciprocal. You can find more details on the algorithm and implementation in a small application note here: http://www.zsp.com/support/downloads/docs/pdf/fixedpointrecipalgo.pdf Jitendra [1] R. E. Goldschmidt, "Applications of Division by Convergence", Master's Thesis, MIT, 1964.
Division in Fixed Point
Started by ●December 15, 2005
Reply by ●December 18, 20052005-12-18
Jitendra Rayala wrote: ...> http://www.zsp.com/support/downloads/docs/pdf/fixedpointrecipalgo.pdfA password is required for access. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Reply by ●December 19, 20052005-12-19
On Sun, 18 Dec 2005 10:18:26 -0500, Jerry Avins <jya@ieee.org> wrote:>Jitendra Rayala wrote: > > ... > >> http://www.zsp.com/support/downloads/docs/pdf/fixedpointrecipalgo.pdf > >A password is required for access. > >JerryJust cancel, register and download.
