Hello all: I want to know more about how Maximal ratio combining is done in an OFDM based system. I have some IEEE references but cannot get an insight as to how this is to be implemented. I am particularly interested as to how to cophase the signals on the two channels and then combine them. What sort of circuitry can be used to do this, say in a 802.11a WLAN system. Here are some of the references Postdetection Maximal Ratio Combining Diversity Receiver with Scalar Phase Signals - Tomoaki Kumagai and Kiyoshi Kobayashi Receive Diversity for Mobile OFDM Systems - A. A. Hutter I, J. S . Hammerschmidt I , E. de Carvalho 2, J. M. Cioffi Pre-DFT Combining Space Diversity Assisted COFDM - Minoru Okada and Shozo Komaki, Optimal Maximal Ratio Combining With Correlated Diversity Branches - Xiaofei Dong, Member, IEEE, and Norman C. Beaulieu, Fellow, IEEE Optimal Antenna Diversity Combining for IEEE 802.1 la System - Xuemei Ouyang, Monisha Ghosh and Joseph P. Meehan Optimum Combining for Indoor Radio Systelms with Multiple Users - Jack Winters Thanks -IM
OFDM Maximal ratio combining
Started by ●December 25, 2005
Reply by ●December 25, 20052005-12-25
IM 쓴 글:> Hello all: > > I want to know more about how Maximal ratio combining is done in an > OFDM based system. I have some IEEE references but cannot get an > insight as to how this is to be implemented. I am particularly > interested as to how to cophase the signals on the two channels and > then combine them. What sort of circuitry can be used to do this, say > in a 802.11a WLAN system.For simple explanation, assume that we have two receive antenna branches. Two brance yields two recevied signals x1(t) and x2(t) and two pilot signals p1(t) and p2(t). The pilot signals are equivalent to the channels, c1(t) and c2(t), between the transmiter and each received branch, respectively, except they includes the unnecessary noise, n1_p(t) and n2_p(t). That is, the received pilot signals are represented as p1(t) = c1(t) + n1_p(t) ~= c1(t), p2(t) = c2(t) + n2_p(t) ~= c2(t). Assuming that s(t) is transmitted information, the recevied signals are given by x1(t) = c1(t)*s(t) + n1(t), x2(t) = c2(t)*s(t) + n2(t) where n1(t) and n2(t) are the noise signals. From the theory of maximal ratio combine (MRC), the combined signal is obtained as x(t) = c1(t)'*x1(t) + c2(t)'*x2(t) which maximize the signal to noise ratio before detecting the transmitted information, such as s_dec(t) = dec( x(t)) where dec(.) is a decision function. For BPSK without channel coding, dec( x) is given by dec( x) = {0 for x > 0, and 1 for x < 0}. I have omitted the detailed theory to proof the optimality of MRC and an example which considers OFDM modulation at this note. -James G.
Reply by ●December 26, 20052005-12-26
HI James: Thanks for the info. Here's my understanding. In the case of the OFDM, I would have to do the above for each and every carrier. Considering the 2 path case as you mentioned above we have x_m(t) = c1_m(t)*x1_m(t) + c2_m(t)*x2_m*(t). where m represents the carrier number, i.e. 1_m representing antenna 1 data corresponding to carrier m and 2_m representing antenna 2 data corresponding to carrier m. Combining should be done before channel decoding and decision making, hence just after equalization. What bothers me is '+' sign during combining in x_m(t) = c1_m(t)*x1_m(t) + c2_m(t)*x2_m*(t). Intuitively I feel that the we would need to weigh a signal based on how strong the power of the signal is on an antenna path since I would be better off trusting the signal on the higher powered path. So In the 2 antenna case, say signal x1_m(t) and x2_m(t) are the output of the equalizers for carrier m in path 1 and path 2 respectively. I would combine by x(t) = w1*x1_m(t) + w2*x2_m(t); where w1 and w2 are weights that maximize x(t) in such way as to maximize SNR. Now if x1_m is the higher powered signal (based on RSSI measurements), then w1 > w2 and w1 + w2 = 1; w1 and w2 should probably be calculated based on RSSI of path 1 and path 2. The combining occurs. But the signals x1_m and x2_m could be out of phase. How to take care of this phase difference. Having separate equalizers for each path won't help, We would need information from one path that can be used by the other path to offset the phase difference (cophasing)? How can that be done? So does it make sense to do the combining after decision making, the we sort of put off the cophasing issue? Please comment.
IM wrote:> I would combine by > x(t) = w1*x1_m(t) + w2*x2_m(t); > > where w1 and w2 are weights that maximize x(t) in such way as to > maximize SNR. Now if x1_m is the higher powered signal (based on RSSI > measurements), then w1 > w2 and w1 + w2 = 1; w1 and w2 should probably > be calculated based on RSSI of path 1 and path 2. > The combining occurs. But the signals x1_m and x2_m could be out of > phase. How to take care of this phase difference. Having separate > equalizers > for each path won't help, We would need information from one path that > can be used by the other path to offset the phase difference > (cophasing)? > How can that be done? > So does it make sense to do the combining after decision making, the we > sort of put off the cophasing issue?I am not good at 11n but I have seen 16e a little bit. So, I'll explain the combining techniques based on the 16e OFDM structure. Assuming that carrier n is located close enough to carrier m, the pilot signal, p1_n(t) and p2_n(t), transmitted through carrier n can be used for determining the weight. Therefore, for MRC, w1 = p1_n*(t) and w2 = p2_n*(t) can be used where * is the conjugate operator. In addition, the power constraint on weights is |w1|^2 + |w2|^2 = 1, which is usually applied for simplification. - James G.
Reply by ●December 27, 20052005-12-27
Thanks again James. It is begining to make sense to me now. All I know about 16e PHY is that it is OFDM based. Does the 16e talk about the cophasing? Thanks
IM wrote:> Thanks again James. > > It is begining to make sense to me now. > All I know about 16e PHY is that it is OFDM based. Does the 16e talk > about the cophasing? > > Thanks >To simplify the diversity combine, we can use equal gain combining (EGC) insead of maximal ratio combining (MRC) although the pilot singal exists per each coherence group of subcarriers. Moreover, as you said there are two different diversity combining methods which are post-decoding combining and pre-decoding combining. In the diversity system which considers post-decoding combining, the decoded bits from two antenna branches are combined after the bit is decoded based on the effective signal to noise ratio (SNR) of each bit. In this case, selection combining (SC) is more preperable than the others because of its easy applicability. - James G.
Reply by ●June 20, 20072007-06-20
>IM wrote: >> Thanks again James. >> >> It is begining to make sense to me now. >> All I know about 16e PHY is that it is OFDM based. Does the 16e talk >> about the cophasing? >> >> Thanks >> > >To simplify the diversity combine, we can use equal gain combining (EGC)>insead of maximal ratio combining (MRC) although the pilot singal exists>per each coherence group of subcarriers. Moreover, as you said there are>two different diversity combining methods which are post-decoding >combining and pre-decoding combining. In the diversity system which >considers post-decoding combining, the decoded bits from two antenna >branches are combined after the bit is decoded based on the effective >signal to noise ratio (SNR) of each bit. In this case, selection >combining (SC) is more preperable than the others because of its easy >applicability. > >- James G. >Hi, After I have measured the SNR of the pilot signal on each branch, in what way I should calculate the weight of this path? What is the formula of this factor w? thanks
