Hi all, I would like to know how to regenerate the clock bit from the symbol clock for multiple level PSK modulations ? For QPSK modulation we need to recover a clock bit twice the symbol clock. I don't found any help on google... Thanks. Best regards.
Clock multiplication M-PSK
Started by ●March 13, 2006
Reply by ●March 13, 20062006-03-13
patrick.melet@dmradiocom.fr wrote:> Hi all, > > I would like to know how to regenerate the clock bit from the symbol > clock for multiple level PSK modulations ? > > For QPSK modulation we need to recover a clock bit twice the symbol > clock. > > I don't found any help on google... > > Thanks. > Best regards.If you have the symbol clock, you will need to send log2(M) bits out of the demodulator in every symbol period. Depending on how the receiver of these bits works, you could use a high rate free running clock to essentially burst them out. Each time you get a new symbol, wait for the next rising edge of the high rate clock. Shift out the first bit then, wait for the next rising edge, then shift out the second bit, etc. Also shift out rising and falling clock edges. Tell the guy grabbing the bits to sample them on the falling edge of the gated clock that you provide. John
"john" <johns@xetron.com> writes:> patrick.melet@dmradiocom.fr wrote: >> Hi all, >> >> I would like to know how to regenerate the clock bit from the symbol >> clock for multiple level PSK modulations ? >> >> For QPSK modulation we need to recover a clock bit twice the symbol >> clock. >> >> I don't found any help on google... >> >> Thanks. >> Best regards. > > If you have the symbol clock, you will need to send log2(M) bits out of > the demodulator in every symbol period. Depending on how the receiver > of these bits works, you could use a high rate free running clock to > essentially burst them out. Each time you get a new symbol, wait for > the next rising edge of the high rate clock. Shift out the first bit > then, wait for the next rising edge, then shift out the second bit, > etc. Also shift out rising and falling clock edges. Tell the guy > grabbing the bits to sample them on the falling edge of the gated clock > that you provide.Couldn't one also use a frequency synthesizer to lock a bit clock at a frequency of M times the symbol clock, where M = 2^k, k bits per symbol? -- % Randy Yates % "Ticket to the moon, flight leaves here today %% Fuquay-Varina, NC % from Satellite 2" %%% 919-577-9882 % 'Ticket To The Moon' %%%% <yates@ieee.org> % *Time*, Electric Light Orchestra http://home.earthlink.net/~yatescr
patrick.melet@dmradiocom.fr wrote:> Hi all, > > I would like to know how to regenerate the clock bit from the symbol > clock for multiple level PSK modulations ? > > For QPSK modulation we need to recover a clock bit twice the symbol > clock. > > I don't found any help on google... > > Thanks. > Best regards. >I got 1500 hits on Altavista searching for +synchronize +QAM -- some of them even looked promising. With the bit of work that I've done on cell phone stuff, the protocols either use a format that's easy to synchronize (such as MSK) or they provide pilot data sequences that make it easy to synchronize the carrier and symbol clocks. Have you looked at your particular protocol to see if this is being done? -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Posting from Google? See http://cfaj.freeshell.org/google/
<patrick.melet@dmradiocom.fr> wrote in message news:1142260490.146538.116770@i39g2000cwa.googlegroups.com...> Hi all, > > I would like to know how to regenerate the clock bit from the symbol > clock for multiple level PSK modulations ? > > For QPSK modulation we need to recover a clock bit twice the symbol > clock. > > I don't found any help on google... >If it's only QPSK I would insist that it's up to the analogue blokes to provide you with a clock at the symbol rate and at the bit rate because: a) They can do it without using any of your precious DSP resources. b) You can blame them for any poor performance later ;) Best of luck - Mike
