Hi, I am currently doing a object tracking project in computer vision. My project involves tracking snooker balls on a snooker table. The balls are tracked frame by frame but the resulting tracking information is noisy and does not follow the smooth linear motion of the balls on the table. To smooth the resulting information i am trying to use the kalman filter as i assumed this was what it was created for. The issue i am having is that i am not a very mathematical person but i am willing to learn. The kalman filter looks very challenging and i dont know how to go about smoothing the tracking data so that i get a smooth, noise-less motion. Can someone try and explain the steps in laymans terms to help someone who isnt so mathematically minded. I have read various online tutorials and the kalman introduction paper and they try and explain it simply but i am still finding it hard to work out what the inputs and outputs are into the filter, what needs to be set up before running the filter and the matrix the filter uses and what each matrix represents. I know i am asking a lot but it would be helping me greatly. Also if you think that there is a better solution to my problem that is easier to implement then feel free to let me know. Thanks and kind regards Paul -=---------=-
Kalman Filter for Image Object Tracking
Started by ●April 2, 2006
Reply by ●April 2, 20062006-04-02
ProdigalSon wrote:> Hi, > > I am currently doing a object tracking project in computer vision. My > project involves tracking snooker balls on a snooker table. The balls > are tracked frame by frame but the resulting tracking information is > noisy and does not follow the smooth linear motion of the balls on the > table. To smooth the resulting information i am trying to use the > kalman filter as i assumed this was what it was created for. > > The issue i am having is that i am not a very mathematical person but i > am willing to learn. The kalman filter looks very challenging and i > dont know how to go about smoothing the tracking data so that i get a > smooth, noise-less motion. > > Can someone try and explain the steps in laymans terms to help someone > who isnt so mathematically minded. I have read various online tutorials > and the kalman introduction paper and they try and explain it simply > but i am still finding it hard to work out what the inputs and outputs > are into the filter, what needs to be set up before running the filter > and the matrix the filter uses and what each matrix represents. > > I know i am asking a lot but it would be helping me greatly. Also if > you think that there is a better solution to my problem that is easier > to implement then feel free to let me know.You might want to ask this particular question on sci.image.processing. Rune
ProdigalSon wrote:> Hi, > > I am currently doing a object tracking project in computer vision. My > project involves tracking snooker balls on a snooker table. The balls > are tracked frame by frame but the resulting tracking information is > noisy and does not follow the smooth linear motion of the balls on the > table. To smooth the resulting information i am trying to use the > kalman filter as i assumed this was what it was created for. > > The issue i am having is that i am not a very mathematical person but i > am willing to learn. The kalman filter looks very challenging and i > dont know how to go about smoothing the tracking data so that i get a > smooth, noise-less motion. > > Can someone try and explain the steps in laymans terms to help someone > who isnt so mathematically minded. I have read various online tutorials > and the kalman introduction paper and they try and explain it simply > but i am still finding it hard to work out what the inputs and outputs > are into the filter, what needs to be set up before running the filter > and the matrix the filter uses and what each matrix represents. > > I know i am asking a lot but it would be helping me greatly. Also if > you think that there is a better solution to my problem that is easier > to implement then feel free to let me know. > > Thanks and kind regards > > Paul > -=---------=- >First, a Kalman filter on the tracker data will only do you good to the extent that the tracker is doing it's job -- for tracker questions you'll need to use that image processing newsgroup that Rune suggested. Second, a Kalman filter is a mathematical construct that gives you the Very Best Filter that you can possibly have, given some assumptions about the nature of the system you're trying to observe and the nature of the noise with which your data is corrupted. The big pile-o-math that you encounter is there (a) to translate your assumptions into a filter, and (b) to prove that the filter is, indeed, optimal. Unfortunately, if your assumptions aren't valid then the Kalman filter won't be the Very Best Filter. It will, at best, be a Pretty Good Filter, but it may be a Very Bad Filter. Furthermore, if you don't make the right assumptions then the math will go from something that is conceptually difficult but easy once you grasp it to something that is difficult, if not impossible, to solve. The input(s) into a Kalman filter are everything you know about the problem at hand. In your case I assume that it is just the tracker's x and y outputs, but if you had any prior knowledge about the ball motion, or about the tilt of the table, you'd want to find a way to include that, too. The output(s) from a Kalman filter are everything you want to know about the problem at hand. In your case I assume that this will be a four element vector, with x and y velocity and position. In your case, the outputs from the Kalman filter are also the states of the filter -- velocity and position are all you need to make good estimates of velocity and position. If you make your inputs into a vector and call it 'u', and call your outputs 'y', then the core operation in a discrete-time Kalman filter can be expressed as: y_k = A_k y_{k-1} + B_k u_k. Note the subscripting -- not only do you get a new input each time, but your gains change. In the above equation the A matrix is called the "state transition matrix", and the B matrix is called the "input matrix". These matrices change with time; what they encode is the very best that you know about how the estimates should change with every bit of new information. These matrices are found by answering the question "if I take the prior state of the system and it's current input, what are the very best values of A and B to get the very best estimate of it's current state?" Much of the complexity of Kalman filter design goes into answering the above question, but remember that at it's heart the Kalman filter is just a simple linear* system, albeit time varying. For your system, if you can safely assume that the snooker table surface is frictionless and if you have no prior knowledge of the ball's position and velocity then your Kalman filter will devolve into a computationally efficient way to do a least-squares curve fit to the x and y data, to find the 'a' and 'b' in x = a*t + b (t being your time variable). Keep this in mind -- the Kalman filter problem is stated in a manner that for the assumptions I've given above there can be no other answer. So should you construct a Kalman filter with those assumptions and get a different answer then you've made an error. If you _can_ assume a frictionless surface (which you can only do if the ball is traveling fairly fast) then you don't have to construct a 'real' Kalman filter -- you can just go to your nearest statistics book and pull out the single-variable least-squares fit for a line and use that equation on both the x position and y. If you _can't_ assume a frictionless surface (i.e. the ball will slow down significantly over the length of time that you're tracking it, perhaps even stop) then you will have to use something fancier. You'll either have to assume that the ball is being given some unknown acceleration, or you'll have to use an extended Kalman filter (friction is a nonlinear phenomenon). I hope this helps -- I have a feeling it's too long, too short, not clear enough and not detailed enough. * A Kalman filter is only optimal for a certain set of cost criteria, system behavior, and noise distributions. An "Extended Kalman Filter" is used when you can't assume that costs, behavior and noise fit into these sets. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Posting from Google? See http://cfaj.freeshell.org/google/
ProdigalSon wrote:> > Hi, > > I am currently doing a object tracking project in computer vision. My > project involves tracking snooker balls on a snooker table. The balls > are tracked frame by frame but the resulting tracking information is > noisy and does not follow the smooth linear motion of the balls on the > table. To smooth the resulting information i am trying to use the > kalman filter as i assumed this was what it was created for. >It doesn't seem that you have really defined your problem/solution very well. I would say you could state your problem like this: You need to know where the balls are at regular instants of time and you need to figure out where the balls go between those instants. I can see how various things can lead to adding error (or noise) to the estimation of where the balls are at each frame instant, but smoothing isn't going to be always the right solution to that problem. If a ball changes course between frames (due to collision) you don't want a smoothed representation of that in your model. So you need to be selective about what you smooth. So it seems you need to model the motion as generally well behaved smooth motion in between collision nodes. So the task would seem to be to identify the collision nodes and to smooth the paths between nodes. That seems easy to say but since the 2 depend on each other it probably alot more difficult to do. The nodes need to be defined in 2d, but the motion between nodes should be able to be dealt with as two 1d problems. So the smoothing the samples between nodes could be done independently in X and Y. That is the input to your smoothing filter in the x direction would be distance traveled in x between each frame (with no collisions). That is to say, the change in x from one frame to the next should not be erratic but should graph as a smooth curve (and usually descending). I wouldn't think you need anything like an adaptive filter to accomplish this. At least it would seem that starting with something simple like low pass filter would tell you if you need something more complicated. -jim> The issue i am having is that i am not a very mathematical person but i > am willing to learn. The kalman filter looks very challenging and i > dont know how to go about smoothing the tracking data so that i get a > smooth, noise-less motion. > > Can someone try and explain the steps in laymans terms to help someone > who isnt so mathematically minded. I have read various online tutorials > and the kalman introduction paper and they try and explain it simply > but i am still finding it hard to work out what the inputs and outputs > are into the filter, what needs to be set up before running the filter > and the matrix the filter uses and what each matrix represents. > > I know i am asking a lot but it would be helping me greatly. Also if > you think that there is a better solution to my problem that is easier > to implement then feel free to let me know. > > Thanks and kind regards > > Paul > -=---------=-----== Posted via Newsfeeds.Com - Unlimited-Unrestricted-Secure Usenet News==---- http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups ----= East and West-Coast Server Farms - Total Privacy via Encryption =----
