I'm new to the TI boards, and would like to control parameters of a DSP project external to the board. Over Serial, USB, whatever. In the software world I would use MIDI, but I see no MIDI libs for the TI boards. I see documentation on the hardware of McBSP and so on, but if I'm to do this it's going to have to be at the C level; I don't have time to write a serial driver from scratch. I seem to be spinning my wheels, so I wonder if somebody could point me in the right direction for simple external control of parameters. Thanks
Control of a TI C6xxx DSK
Started by ●April 27, 2006
Reply by ●April 28, 20062006-04-28
Hi Hans "Hans Fugal" <fugalh@xmission.com> wrote in message news:e2qt7s$nsv$1@news.xmission.com...> I'm new to the TI boards, and would like to control parameters of a DSP > project external to the board. Over Serial, USB, whatever. In the software > world I would use MIDI, but I see no MIDI libs for the TI boards. I see > documentation on the hardware of McBSP and so on, but if I'm to do this > it's going to have to be at the C level; I don't have time to write a > serial driver from scratch. > > I seem to be spinning my wheels, so I wonder if somebody could point me in > the right direction for simple external control of parameters. ThanksYou don't say which DSK it is. If it is the '6713, there is an I2C port available that is presented on the HPI header. Cheers, Howard
> You don't say which DSK it is. If it is the '6713, there is an I2C port > available that is presented on the HPI header.The board is '6416. I was able to borrow a book [1] that has cleared it up nicely. The magic words are RTDX and OLE. I should probably be able to code up a simple GUI using Ruby (with FXRuby or Tk, using the win32ole library) to control the parameters.
