Walker wrote:> > > >Thaks you have understand what I would like :). It would be great if I > >find a rate converter like "interp" in Matlab...It's too compplicate to > >implement it :S. > > > >Carlos Vargas > > > > I have an implementation: > > 1. Interpoling signal with "rate-1" zeros: > for example if rate = 3 > Signal: 2 1 4 6 7 ... > Signal zeros: 2 0 0 1 0 0 4 0 0 6 0 0 7 0 0 ... > > 2. Make a simetric sinc with 5-6 lobules at each side, and sample it with > "rate"-samples at each lobule. (Principal Lobule "rate"-samples from 0 to > 1 and "rate"-samples from -1 to 0). > > 3. Convolve Signal zeros with that sinc. > > Note: If you take more lobules (for example 35 at each side) the result > will be better, but we will have a large transitory in the signal result. > > Can somebody make it better? It would be great, if somebody konw how to > eliminate that transitori without cut it.Sampling the sinc function is a good approach. By windowing the sinc samples you can noticably improve transition bandwidth and stopband attenuation. See: http://www.dspguide.com/ch16.htm Regards, Andor
Interpolation with JAVA like MATLAB
Started by ●May 20, 2006
Reply by ●May 30, 20062006-05-30
