ADSP-21364 delay buffer question
Started by Roman Rumian May 30, 2006
Hi friends,
want to use ADSP-21369 device for universal module containing processor,
FLASh and SDRAM memory only, but the samples of this device are not
available now, so my distributor has sent me ADSP-21364 one.
In my audio implementations I need 2 seconds delay buufer for many
channels, so 1 megaword is a minimum. As I  know from the user manual
ADSP-21364 has a parallel memory port, which can be configured as 24
address bits and 8 data bits.
How efficient and easy to use is such a delay buffer construction ?
Regards
Roman Rumian
Roman Rumian <usun_torumian@agh.edu.pl> wrote in news:e5h8cm$tc0$1
@news.agh.edu.pl:
> Hi friends, > > want to use ADSP-21369 device for universal module containing
processor,
> FLASh and SDRAM memory only, but the samples of this device are not > available now, so my distributor has sent me ADSP-21364 one. > > In my audio implementations I need 2 seconds delay buufer for many > channels, so 1 megaword is a minimum. As I know from the user manual > ADSP-21364 has a parallel memory port, which can be configured as 24 > address bits and 8 data bits. > How efficient and easy to use is such a delay buffer construction ? > > Regards > > Roman Rumian >
Roman, Have you looked at our dspblok 21369? It is a 60mm x 60mm square module with a ADSP-21369, 4Mbit flash, EE memory, 64kbit SDRAM and a core switching supply. It is available independently or as a subcomponent of a dspstak 21369zx2. The dspstak 21369zx2 includes a high speed USB interface, programmable clocks, RS-232. The dspstak 21369zx2 with ICE includes an ADI EZ-Kit sytle debugger and is supported by a free KIT license of VDSP as well as a full license. We have a pilot run completed of both products and will have RoHS versions in late June or July. We have a sufficient number of DSPs to last until the official production release of the ADSP-21369 later this year. Email us for more details/questions. -- Al Clark Danville Signal Processing, Inc. -------------------------------------------------------------------- Purveyors of Fine DSP Hardware and other Cool Stuff Available at http://www.danvillesignal.com
