Sound chip recordings... How is it done?
Started by Trains June 5, 2006
Sound chip (DSP) recordings... How is it done?
Pardon my ignorance and naivety, but....
A group of model railroaders would like to customize/personalize the train
sound announcements that have been recorded on the sound chip on their
locomotives and railcars.
Is there a website that, in layman's language, explains how sound effects
are "recorded" on a sound chip?  ... and, how one would/could "re-record"
or "re-program" a sound chip with the particular sounds that are
appropriate for ones use?
What type of equipment is necessary for programming a sound chip?
Are there companies that will "customize" a sound chip for your particular
needs?
Thanks for any and all information you can pass along   .... to us
novices!!
Trains skrev:
> Sound chip (DSP) recordings... How is it done? > > Pardon my ignorance and naivety, but.... > > A group of model railroaders would like to customize/personalize the train > sound announcements that have been recorded on the sound chip on their > locomotives and railcars.
What does this mean? That the horn sounds differently for each train? That the PA announcements on the stations sound differently?
> Is there a website that, in layman's language, explains how sound effects > are "recorded" on a sound chip? ... and, how one would/could "re-record" > or "re-program" a sound chip with the particular sounds that are > appropriate for ones use?
Maybe there is, but probably not from a technical point of view. As a first suggestion, try musician's web sites and see if you can find explanations of sound effects. You are looking for the same sort of technology but with a different application. Rune
"Trains" <alanchamel@hotmail.com> wrote in message
news:PeGdne9LG-AckhnZnZ2dnUVZ_vidnZ2d@giganews.com...
> Sound chip (DSP) recordings... How is it done? > > Pardon my ignorance and naivety, but.... > > A group of model railroaders would like to customize/personalize the train > sound announcements that have been recorded on the sound chip on their > locomotives and railcars. > > Is there a website that, in layman's language, explains how sound effects > are "recorded" on a sound chip? ... and, how one would/could "re-record" > or "re-program" a sound chip with the particular sounds that are > appropriate for ones use? > > What type of equipment is necessary for programming a sound chip? > > Are there companies that will "customize" a sound chip for your particular > needs? > > Thanks for any and all information you can pass along .... to us > novices!! > > >
You'll need a ROM of some sort and a D/A convertor + amp and a speaker (a cheap one that they use in toys is fine). Record the sound effects 8 bits sampled at 11.25kHz on a PC and then write to ROM. There maybe a kit you can buy somewhere. M.P -- Posted via a free Usenet account from http://www.teranews.com
