Hi! Please help to choose a dsp chip for a audio processing project. I want to make a kind of effect box with reverberation or surround algorithm inside. Since have experience mostly in dsp programming area, I need an all-in-one solution including the dsp, memory, adc/dac etc, to make board design as simple as possible. The requirements are: 2-3ch ADC, 2-8ch DAC digital in/out (optional) fixed or float 50-70 mips C compiler available RAM/ROM - more is better not expensive easy to deal with
Choose a chip for audio processing
Started by ●June 8, 2006
Reply by ●June 8, 20062006-06-08
denden wrote:> Hi! > > Please help to choose a dsp chip for a audio processing project. I want to > make a kind of effect box with reverberation or surround algorithm inside.I am doing a similar kind of a project. Thats an FM receiver with USB interface to record programs at scheduled time.> Since have experience mostly in dsp programming area, I need an all-in-one > solution including the dsp, memory, adc/dac etc, to make board design as > simple as possible. >I am considering dsPIC series from Microchip and Blackfin 538 from ADI. Normally Blackfins don't have flash but this new chip "538" has it. Warm regards --Himanshu
Reply by ●June 9, 20062006-06-09
"Himanshu Chauhan" <hs.chauhan@gmail.com> wrote in message news:1149818819.745696.10350@g10g2000cwb.googlegroups.com...> > I am doing a similar kind of a project. Thats an FM receiver with USB > interface > to record programs at scheduled time.Coincidentally I manufactured a number of these http://www.silabs.com/tgwWebApp/public/web_content/products/Microcontrollers/en/USBFMRadio.htm with a few minor firmware and hardware changes before they became generally available about three months ago for a Seattle startup (http://www.snaptune.com). The design used 0402 devices that are placed rather too close together for hand soldering, and the soldering of QFN packages by hand can also be a little fun. Digikey part #336-1293-ND Cheers, Howard
Howard Long wrote:> "Himanshu Chauhan" <hs.chauhan@gmail.com> wrote in message > news:1149818819.745696.10350@g10g2000cwb.googlegroups.com... > > > > I am doing a similar kind of a project. Thats an FM receiver with USB > > interface > > to record programs at scheduled time. > > Coincidentally I manufactured a number of these > http://www.silabs.com/tgwWebApp/public/web_content/products/Microcontrollers/en/USBFMRadio.htm > with a few minor firmware and hardware changes before they became generally > available about three months ago for a Seattle startup > (http://www.snaptune.com). The design used 0402 devices that are placed > rather too close together for hand soldering, and the soldering of QFN > packages by hand can also be a little fun. >Its the same that I am working upon for my final year project. But my design is using FM tuner from Philips. I was considering dsPIC so that I can implement some filters like dynamic range compressor inside the device. Is USB power driving the whole circuit? I was thinking of an external power source to make it an independent system as well. To make it work stand alone as well as with a PC. Regards --Himanshu
Reply by ●June 11, 20062006-06-11
denden wrote:> Hi! > > Please help to choose a dsp chip for a audio processing project. I > want to make a kind of effect box with reverberation or surround > algorithm inside. Since have experience mostly in dsp programming > area, I need an all-in-one solution including the dsp, memory, > adc/dac etc, to make board design as simple as possible. >> The requirements are: > 2-3ch ADC, 2-8ch DAC > digital in/out (optional) > fixed or float > 50-70 mips > C compiler available > RAM/ROM - more is better > not expensive > easy to deal withYou may want to look at the ATSAM3308 http://www.atmel.com/dyn/products/datasheets.asp?family_id=618 Has a DSP array of 8 x 24 bit DSPs and a 16 bit micro on one chip. 8 input channels and 8 output channels. * MP3 decoding with time stretch and pitch control, concurrent Wavetable synthesis, effect processing and digital mixing. -- Best Regards, Ulf Samuelsson ulf@a-t-m-e-l.com This message is intended to be my own personal view and it may or may not be shared by my employer Atmel Nordic AB
Reply by ●June 12, 20062006-06-12
denden wrote:> Hi! > > Please help to choose a dsp chip for a audio processing project. I want to > make a kind of effect box with reverberation or surround algorithm inside. > Since have experience mostly in dsp programming area, I need an all-in-one > solution including the dsp, memory, adc/dac etc, to make board design as > simple as possible. > > The requirements are: > 2-3ch ADC, 2-8ch DAC > digital in/out (optional) > fixed or float > 50-70 mips > C compiler available > RAM/ROM - more is better > not expensive > easy to deal withWhere's Al when you need him? Check out http://www.danvillesignal.com/index.php?id=products_dspstak If you inted to implement a multi-channel reverb (say two input, five output) you have to increase that MIPS count a bit. Analog Devices has an application note available from their website on how to implement audio effects with their floating-point DSPs (which are used in Danville's products). It doesn't include reverbs, however. Regards, Andor
"Andor" <andor.bariska@gmail.com> wrote in news:1150096607.628409.32400@h76g2000cwa.googlegroups.com:> denden wrote: >> Hi! >> >> Please help to choose a dsp chip for a audio processing project. I >> want to make a kind of effect box with reverberation or surround >> algorithm inside. Since have experience mostly in dsp programming >> area, I need an all-in-one solution including the dsp, memory, >> adc/dac etc, to make board design as simple as possible. >> >> The requirements are: >> 2-3ch ADC, 2-8ch DAC >> digital in/out (optional) >> fixed or float >> 50-70 mips >> C compiler available >> RAM/ROM - more is better >> not expensive >> easy to deal with > > Where's Al when you need him? Check out > > http://www.danvillesignal.com/index.php?id=products_dspstak > > If you inted to implement a multi-channel reverb (say two input, five > output) you have to increase that MIPS count a bit. Analog Devices has > an application note available from their website on how to implement > audio effects with their floating-point DSPs (which are used in > Danville's products). It doesn't include reverbs, however. > > Regards, > Andor > >We have some new boards that might be of interest. Our dspstak 21369zx2 was an ADI ADSP-21369, SDRAM (needed for reverb), high speed USB, etc. We also have a new I/O module: dspstak c192k48 which is 4 in/8 outwith sampling as high as 192K. A balanced extender is available for balanced + 4dBu audio circuits. -- Al Clark Danville Signal Processing, Inc. -------------------------------------------------------------------- Purveyors of Fine DSP Hardware and other Cool Stuff Available at http://www.danvillesignal.com
