Hello, I have maganged to simulate an OFDM system using Matlab. It works fine in AWGN channel and SNR vs BER curve matches the theoretical one. But I have problem when I add Rayleigh to it (I get similar amount of BER for all SNR). I have used standard matlab functions to gerenate static flat fading: c=raylieghchan(); y = filter(c,ofdm_symbol); % then I add AWGN Is there anything else I need to do? Best regards Shahin
Rayleigh fading in OFDM
Started by ●July 10, 2006
Reply by ●July 11, 20062006-07-11
persian_eagle wrote:> Hello, > > I have maganged to simulate an OFDM system using Matlab. It works > fine in AWGN channel and SNR vs BER curve matches the theoretical one. > But I have problem when I add Rayleigh to it (I get similar amount of > BER for all SNR). I have used standard matlab functions to gerenate > static flat fading: > > c=raylieghchan(); > y = filter(c,ofdm_symbol); > % then I add AWGN > > Is there anything else I need to do?Just some random ideas, since I've never used those matlab functions (I tend to create my own low-level functions). Is the BER you're getting close to 0.5? This might indicate the fading you're introducing is too strong. What happens if you don't introduce noise? What happens if you substitute your rayleigh filter by a constant attenuator and a phase shift? HTH.
