Extracting pulse height and width from noise
Started by John Devereux ●July 15, 2006
Hi,
I have an application with random, nominally rectangular pulses in the
presence of (white) noise. I want to extract the pulse heights and
widths.
- pulse height, width and arrival time are "random"
- I do not actually need the height and width of a *particular* pulse,
  I am more interested in the distribution of heights and the
  distribution of widths.
I was wondering if there was some clever dsp way to achieve this,
(analogous to using an FFT to extract sinusoidal signals, perhaps).
John Devereux
Have you considered different correlation techniques?  There are lots
of IEE and IEEE papers to this effect, since this is a common problem
in Radar applications.
John Devereux wrote:
> Hi, > > I have an application with random, nominally rectangular pulses in the > presence of (white) noise. I want to extract the pulse heights and > widths. > > - pulse height, width and arrival time are "random" > > - I do not actually need the height and width of a *particular* pulse, > I am more interested in the distribution of heights and the > distribution of widths. > > I was wondering if there was some clever dsp way to achieve this, > (analogous to using an FFT to extract sinusoidal signals, perhaps). > > -- > > John Devereux
It almost sounds like an intelligence problem.  If you want that information,
you will probably need to do a least fit to the waveform.  The three
parameters you will need for the fit, height, width, and position, will need
to be estimated.  I suggest that you use the Levenburg-Marquadt algorithm.
I've used Hooke-Jeeves for this too.
In article <87ac7bvzsk.fsf@cordelia.devereux.me.uk>, John Devereux
<jdREMOVE@THISdevereux.me.uk> wrote:
> >Hi, > >I have an application with random, nominally rectangular pulses in the >presence of (white) noise. I want to extract the pulse heights and >widths. > >- pulse height, width and arrival time are "random" > >- I do not actually need the height and width of a *particular* pulse, > I am more interested in the distribution of heights and the > distribution of widths. > >I was wondering if there was some clever dsp way to achieve this, >(analogous to using an FFT to extract sinusoidal signals, perhaps). >
John_W_Herman@yahoo.com (John Herman) writes:
> In article <87ac7bvzsk.fsf@cordelia.devereux.me.uk>, John Devereux > <jdREMOVE@THISdevereux.me.uk> wrote: >> >>Hi, >> >>I have an application with random, nominally rectangular pulses in >>the presence of (white) noise. I want to extract the pulse heights >>and widths.
> It almost sounds like an intelligence problem. If you want that > information, you will probably need to do a least fit to the > waveform. The three parameters you will need for the fit, height, > width, and position, will need to be estimated. I suggest that you > use the Levenburg-Marquadt algorithm. I've used Hooke-Jeeves for > this too.
OK, Thanks. I am not sure how this would work though. For a given region of the input data, I do not know in advance how many pulses are present, so I don't see how to parameterise the model. Although I suppose one could make the number of pulses itself another parameter? -- John Devereux
Minimize the square of the difference between a template of the signal based
on the current estimate of the three parameters and the current measured
signal.  This is a minimization problem.  Thiunking about the problem,
Hooke-Jeeves may be the better choice since it doesn't require the Jacobian
and uses only function values.  The function values in this case are the
square of the difference between the template and the signal.
In article <87irlx35pu.fsf@cordelia.devereux.me.uk>, John Devereux
>John_W_Herman@yahoo.com (John Herman) writes: > >> In article <87ac7bvzsk.fsf@cordelia.devereux.me.uk>, John Devereux >> <jdREMOVE@THISdevereux.me.uk> wrote: >>> >>>Hi, >>> >>>I have an application with random, nominally rectangular pulses in >>>the presence of (white) noise. I want to extract the pulse heights >>>and widths. > >> It almost sounds like an intelligence problem. If you want that >> information, you will probably need to do a least fit to the >> waveform. The three parameters you will need for the fit, height, >> width, and position, will need to be estimated. I suggest that you >> use the Levenburg-Marquadt algorithm. I've used Hooke-Jeeves for >> this too. > >OK, Thanks. > >I am not sure how this would work though. For a given region of the >input data, I do not know in advance how many pulses are present, so I >don't see how to parameterise the model. Although I suppose one could >make the number of pulses itself another parameter? >
walsh hadamard xform?
"John Devereux" <jdREMOVE@THISdevereux.me.uk> wrote in message
news:87ac7bvzsk.fsf@cordelia.devereux.me.uk...
"BlagooBlanaa" <BlagooBlanaa@hotmail.com> writes:
Yes, I did look at "walsh functions", but could not quite see how to apply them to the problem. -- John Devereux
how would you extract a signal from noise with the FFT?
xform time series into frequency domain and then take
only the lower order frequency components - lo pass filter?
what is an ft - an approximation of some time series via a
finite sum of orthogonal trig functions?
what is a walsh-hadamard xform - an approximation of
a signal by a finite sum of orthogonal 'sequencies'...
http://www.ciphersbyritter.com/RES/WALHAD.HTM
and, moreover I can prove that the WHT is a special
case of the FT, in other words I can use an FFT algorithm
to attain a WHT of data.
better, if you work hard with an fft algorithm, by unwinding
and hand calculating the butterflies, you can reduce the FFT
to an extremely simple form ideal for computing the WHT.
so, whiten your time series by hi-pass filtering, and de-noise
by lo pass filtering. Does it matter if you are approximating
via FFT or via WHT?
Then you can obtain pulse height and width, perhaps via
IWHT
cheers
> > John_W_Herman@yahoo.com (John Herman) writes: > > > In article <87ac7bvzsk.fsf@cordelia.devereux.me.uk>, John Devereux > > <jdREMOVE@THISdevereux.me.uk> wrote: > >> > >>Hi, > >> > >>I have an application with random, nominally rectangular pulses in > >>the presence of (white) noise. I want to extract the pulse heights > >>and widths. > > > It almost sounds like an intelligence problem. If you want that > > information, you will probably need to do a least fit to the > > waveform. The three parameters you will need for the fit, height, > > width, and position, will need to be estimated. I suggest that you > > use the Levenburg-Marquadt algorithm. I've used Hooke-Jeeves for > > this too. > > OK, Thanks. > > I am not sure how this would work though. For a given region of the > input data, I do not know in advance how many pulses are present, so I > don't see how to parameterise the model. Although I suppose one could > make the number of pulses itself another parameter?
Are you saying there are no limits to these pulses. There is no range of how high or low they might be? No range of how wide or narrow? No limit to the time period between pulses? Are they even sequential or can they overlap one another. If there are truly no limits and are truly random then your problem seems to me to be impossible to solve. -jim
----== Posted via Newsfeeds.Com - Unlimited-Unrestricted-Secure Usenet News==---- http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups ----= East and West-Coast Server Farms - Total Privacy via Encryption =----
