jim <"sjedgingN0sp"@m@mwt.net> writes:> Are you saying there are no limits to these pulses. There is no range of > how high or low they might be? No range of how wide or narrow? No limit > to the time period between pulses? Are they even sequential or can they > overlap one another. If there are truly no limits and are truly random > then your problem seems to me to be impossible to solve.Hi jim, Imagine objects going past a detector. They have a range of sizes and speeds. The width of a pulse will give the speed, and the height will give the particle size. The average pulses/second will give me the number density. But the arrival time will be random, and occasionally overlapping. I realise there will be limits to what can be detected, such as when the objects are too small to be seen above the noise, and errors when two objects coincide. I was hoping for some kind of magic dsp transform, that could extract the parameters of this "signal", like the FFT can extract the frequency and amplitude of sine waves. What I want to end up with is a frequency distribution of pulse heights, and another one of pulse widths. -- John Devereux
Extracting pulse height and width from noise
Started by ●July 15, 2006
Reply by ●July 18, 20062006-07-18
"BlagooBlanaa" <BlagooBlanaa@hotmail.com> writes:> how would you extract a signal from noise with the FFT? > xform time series into frequency domain and then take > only the lower order frequency components - lo pass filter? > > what is an ft - an approximation of some time series via a > finite sum of orthogonal trig functions? > > what is a walsh-hadamard xform - an approximation of > a signal by a finite sum of orthogonal 'sequencies'... > > http://www.ciphersbyritter.com/RES/WALHAD.HTM > > and, moreover I can prove that the WHT is a special > case of the FT, in other words I can use an FFT algorithm > to attain a WHT of data. > > better, if you work hard with an fft algorithm, by unwinding > and hand calculating the butterflies, you can reduce the FFT > to an extremely simple form ideal for computing the WHT. > > so, whiten your time series by hi-pass filtering, and de-noise > by lo pass filtering. Does it matter if you are approximating > via FFT or via WHT? > Then you can obtain pulse height and width, perhaps via > IWHT >OK... But say I had some pulses 1 unit wide. I would need to be able to distinguish 10 pulses 1 unit high, from 1 pulse 10 units high. It seems to me that anything equivalent to a FT would not do this. I need to end up with the frequency distribution of pulse heights (i.e. the number of pulses of each height that were detected). -- John Devereux
John Devereux wrote:> > jim <"sjedgingN0sp"@m@mwt.net> writes: > > > Are you saying there are no limits to these pulses. There is no range of > > how high or low they might be? No range of how wide or narrow? No limit > > to the time period between pulses? Are they even sequential or can they > > overlap one another. If there are truly no limits and are truly random > > then your problem seems to me to be impossible to solve. > > Hi jim, > > Imagine objects going past a detector. They have a range of sizes and > speeds. The width of a pulse will give the speed, and the height will > give the particle size. The average pulses/second will give me the > number density. But the arrival time will be random, and occasionally > overlapping. >Bear with me - my imagination is weak. Do you mean like bags on an airport baggage conveyor or do you mean the jumble of rocks and gravel that comes out of gravel pit before processing. It also might help if you explained what the end goal is. I know you have said you want to extract some sort of statistics of the process. But what are you really looking for? For instance, in the end you might be trying to measure the overall volume of material conveyed.> I realise there will be limits to what can be detected, such as when > the objects are too small to be seen above the noise, and errors when > two objects coincide. > > I was hoping for some kind of magic dsp transform, that could extract > the parameters of this "signal", like the FFT can extract the > frequency and amplitude of sine waves. What I want to end up with is a > frequency distribution of pulse heights, and another one of pulse > widths. >There might be an easy solution if you narrow the problem down sufficiently. For instance, if the pulses came in 3 different heights and 3 different widths then the problem should be a lot easier. And if there was some linear or logarithmic relation ship between those different sizes it should get even easier.> -- > > John Devereux----== Posted via Newsfeeds.Com - Unlimited-Unrestricted-Secure Usenet News==---- http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups ----= East and West-Coast Server Farms - Total Privacy via Encryption =----
John Devereux wrote:> "BlagooBlanaa" <BlagooBlanaa@hotmail.com> writes: > > > how would you extract a signal from noise with the FFT? > > xform time series into frequency domain and then take > > only the lower order frequency components - lo pass filter? > > > > what is an ft - an approximation of some time series via a > > finite sum of orthogonal trig functions? > > > > what is a walsh-hadamard xform - an approximation of > > a signal by a finite sum of orthogonal 'sequencies'... > > > > http://www.ciphersbyritter.com/RES/WALHAD.HTM > > > > and, moreover I can prove that the WHT is a special > > case of the FT, in other words I can use an FFT algorithm > > to attain a WHT of data. > > > > better, if you work hard with an fft algorithm, by unwinding > > and hand calculating the butterflies, you can reduce the FFT > > to an extremely simple form ideal for computing the WHT. > > > > so, whiten your time series by hi-pass filtering, and de-noise > > by lo pass filtering. Does it matter if you are approximating > > via FFT or via WHT? > > Then you can obtain pulse height and width, perhaps via > > IWHT > > > > OK... But say I had some pulses 1 unit wide. I would need to be able > to distinguish 10 pulses 1 unit high, from 1 pulse 10 units high. It > seems to me that anything equivalent to a FT would not do this. > > I need to end up with the frequency distribution of pulse heights > (i.e. the number of pulses of each height that were detected).The signal would still need some analog of being bandlimited to below some Nyquist frequency or else there will be aliasing. 1 unit wide pulses would seem to violate that bandlimiting. The process generating the rectangular pulses needs to be orthogonal or independant in some manner, otherwise I'm not sure how one could differentiate a bunch of pairs of identical and successive 5-wides from 10-wides. IMHO. YMMV. -- rhn A.T nicholson d.0.t C-o-M
John Devereux wrote:> "BlagooBlanaa" <BlagooBlanaa@hotmail.com> writes: > >> walsh hadamard xform? > > Yes, I did look at "walsh functions", but could not quite see how to > apply them to the problem.Is it time for heuristics? Bandpass filter the signal so that the widest and narrowest pulses of interest will be passed relatively intact. With no signal present, there should be no long-term departure from zero mean. If the short-term integral departs significantly (you decide what is significant) from a random walk, a pulse is (or has recently been) present. If that much seems to work, start refining. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
jim <"sjedgingN0sp"@m@mwt.net> writes:> John Devereux wrote: >> >> >> Hi jim, >> >> Imagine objects going past a detector. They have a range of sizes and >> speeds. The width of a pulse will give the speed, and the height will >> give the particle size. The average pulses/second will give me the >> number density. But the arrival time will be random, and occasionally >> overlapping. >> > > Bear with me - my imagination is weak. Do you mean like bags on an > airport baggage conveyor or do you mean the jumble of rocks and gravel > that comes out of gravel pit before processing.The jumble of rocks is a close analogy - although there will usually be some space between them, so mostly can be counted individually. Also they are in a fluid stream rather than on a conveyor, so that different regions of the stream go at somewhat different speeds. If it helps we can ignore the possibility of two coming through together, for now, although in reality this can happen occasionally.> It also might help if you explained what the end goal is. I know you > have said you want to extract some sort of statistics of the process. > But what are you really looking for? For instance, in the end you might > be trying to measure the overall volume of material conveyed.The end goal is in fact the size distribution of the objects, i.e. the number of each size that have gone past. The total volume is not needed (although of course this could be calculated from the distribution). -- John Devereux
"Ron N." <rhnlogic@yahoo.com> writes:> John Devereux wrote: >> >> OK... But say I had some pulses 1 unit wide. I would need to be able >> to distinguish 10 pulses 1 unit high, from 1 pulse 10 units high. It >> seems to me that anything equivalent to a FT would not do this. >> >> I need to end up with the frequency distribution of pulse heights >> (i.e. the number of pulses of each height that were detected). > > The signal would still need some analog of being bandlimited > to below some Nyquist frequency or else there will be aliasing. > 1 unit wide pulses would seem to violate that bandlimiting.Sorry, by "1 unit" I just meant "some time period", nothing to do with the sample interval.> The process generating the rectangular pulses needs to be > orthogonal or independant in some manner, otherwise I'm > not sure how one could differentiate a bunch of pairs of > identical and successive 5-wides from 10-wides.I think the process will be "orthogonal or independent", if I am interpreting those terms correctly. -- John Devereux
Hi John, maybe you can use Matching Pursuit. MP basically works by identifying a member of a dictionary (containing pulses of various widths and heights in your case) that best fits some part of the data, subtracting it out, and iterating on the residual. If you think that doesn't sound as cheap as you hoped for you're probably right. Still, i guess it can't hurt to look into the topic. Martin -- Quidquid latine scriptum sit, altum viditur.
Reply by ●July 19, 20062006-07-19
Martin Eisenberg <martin.eisenberg@udo.edu> writes:> Hi John, > > maybe you can use Matching Pursuit. MP basically works by identifying > a member of a dictionary (containing pulses of various widths and > heights in your case) that best fits some part of the data, > subtracting it out, and iterating on the residual. If you think that > doesn't sound as cheap as you hoped for you're probably right. Still, > i guess it can't hurt to look into the topic.Hi Martin, Thanks, looks interesting. It is useful to know of the existance of things like this, (even if they may indeed be too expensive to use). Simply the *names* of relevant algorithms is a big help when one is unfamiliar with the field! And I have already found out things that will be very useful in another project. -- John Devereux
