Kinda off topic -- A month or two ago there was a spate of postings on these groups displaying a profound misunderstanding of how to apply Nyquist's theorem to problems of setting sampling or designing anti-alias filters. I helped folks out as much as I could, but it really demands an article, which I am currently working on. The misconceptions that I noticed pretty much boiled down to the following two: One, "I need to monitor a signal that happens at X Hz, so I'm going to sample it at 2X Hz". Two, "I can sample at X Hz, so I'm going to build an anti-alias filter with a cutoff of X/2 Hz". I estimate that answering these misconceptions will only take 3-4k words, but I don't want to miss any other big ones. Have you seen any other real howlers that relate to Nyquist, and what you should really be thinking about when you're pondering sampling rates, anti-aliasing filters and/or reconstruction filters? Danke. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Posting from Google? See http://cfaj.freeshell.org/google/ "Applied Control Theory for Embedded Systems" came out in April. See details at http://www.wescottdesign.com/actfes/actfes.html
Nyquist Didn't Say That
Started by ●August 22, 2006
Reply by ●August 22, 20062006-08-22
Tim Wescott wrote:> Kinda off topic -- > > A month or two ago there was a spate of postings on these groups > displaying a profound misunderstanding of how to apply Nyquist's theorem > to problems of setting sampling or designing anti-alias filters. I > helped folks out as much as I could, but it really demands an article, > which I am currently working on. > > The misconceptions that I noticed pretty much boiled down to the > following two: > > One, "I need to monitor a signal that happens at X Hz, so I'm going to > sample it at 2X Hz". > > Two, "I can sample at X Hz, so I'm going to build an anti-alias filter > with a cutoff of X/2 Hz". > > I estimate that answering these misconceptions will only take 3-4k > words, but I don't want to miss any other big ones. > > Have you seen any other real howlers that relate to Nyquist, and what > you should really be thinking about when you're pondering sampling > rates, anti-aliasing filters and/or reconstruction filters? > > Danke.So, if you need to monitor a signal that occurs at xHz - what frequency should you sample it at? D
Tim Wescott wrote:> One, "I need to monitor a signal that happens at X Hz, so I'm going to > sample it at 2X Hz". > > Two, "I can sample at X Hz, so I'm going to build an anti-alias filter > with a cutoff of X/2 Hz". >looks ok to me and Mr Nyquist, I suspect, ...what do you think the relationships should be
Tim Wescott said the following on 22/08/2006 23:23:> The misconceptions that I noticed pretty much boiled down to the > following two: > > One, "I need to monitor a signal that happens at X Hz, so I'm going to > sample it at 2X Hz". > > Two, "I can sample at X Hz, so I'm going to build an anti-alias filter > with a cutoff of X/2 Hz".Are you referring to: a) bandpass sampling, or b) in baseband sampling, the notion that in practice, one needs to sample faster than 2X Hz to measure something at X Hz? (or both)? -- Oli
Tim Wescott wrote:> Kinda off topic -- > > A month or two ago there was a spate of postings on these groups > displaying a profound misunderstanding of how to apply Nyquist's theorem > to problems of setting sampling or designing anti-alias filters. I > helped folks out as much as I could, but it really demands an article, > which I am currently working on. > > The misconceptions that I noticed pretty much boiled down to the > following two: > > One, "I need to monitor a signal that happens at X Hz, so I'm going to > sample it at 2X Hz". > > Two, "I can sample at X Hz, so I'm going to build an anti-alias filter > with a cutoff of X/2 Hz". > > I estimate that answering these misconceptions will only take 3-4k > words, but I don't want to miss any other big ones. > > Have you seen any other real howlers that relate to Nyquist, and what > you should really be thinking about when you're pondering sampling > rates, anti-aliasing filters and/or reconstruction filters?Before going into a detailed article, perhaps you could review/improve the wikipedia article: http://en.wikipedia.org/wiki/Nyquist-Shannon_sampling_theorem
steve wrote:> Tim Wescott wrote: > > >>One, "I need to monitor a signal that happens at X Hz, so I'm going to >>sample it at 2X Hz". >> >>Two, "I can sample at X Hz, so I'm going to build an anti-alias filter >>with a cutoff of X/2 Hz". >> > > looks ok to me and Mr Nyquist, I suspect, ...what do you think the > relationships should beI'd guess he wants the word "periodic" in there somewhere (:
Oli Filth wrote:> Tim Wescott said the following on 22/08/2006 23:23: > >> The misconceptions that I noticed pretty much boiled down to the >> following two: >> >> One, "I need to monitor a signal that happens at X Hz, so I'm going to >> sample it at 2X Hz". >> >> Two, "I can sample at X Hz, so I'm going to build an anti-alias filter >> with a cutoff of X/2 Hz". > > > Are you referring to: > > a) bandpass sampling,I doubt that I'm going to touch bandpass sampling, and if I do it'll be using a 10 foot pole.> or > b) in baseband sampling, the notion that in practice, one needs to > sample faster than 2X Hz to measure something at X Hz? >Yes, (b). As well as the notion that just because your signal has a fundamental frequency of X that doesn't mean it doesn't have harmonics up as far as the imagination can reach. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Posting from Google? See http://cfaj.freeshell.org/google/ "Applied Control Theory for Embedded Systems" came out in April. See details at http://www.wescottdesign.com/actfes/actfes.html
David Hearn wrote:> Tim Wescott wrote: > >> Kinda off topic -- >> >> A month or two ago there was a spate of postings on these groups >> displaying a profound misunderstanding of how to apply Nyquist's >> theorem to problems of setting sampling or designing anti-alias >> filters. I helped folks out as much as I could, but it really demands >> an article, which I am currently working on. >> >> The misconceptions that I noticed pretty much boiled down to the >> following two: >> >> One, "I need to monitor a signal that happens at X Hz, so I'm going to >> sample it at 2X Hz". >> >> Two, "I can sample at X Hz, so I'm going to build an anti-alias filter >> with a cutoff of X/2 Hz". >> >> I estimate that answering these misconceptions will only take 3-4k >> words, but I don't want to miss any other big ones. >> >> Have you seen any other real howlers that relate to Nyquist, and what >> you should really be thinking about when you're pondering sampling >> rates, anti-aliasing filters and/or reconstruction filters? >> >> Danke. > > > So, if you need to monitor a signal that occurs at xHz - what frequency > should you sample it at? > > DYou need to be more than 2X times the highest interesting frequency component in your periodic wave, which can be quite high in some cases. You may also have to do some anti-alias filtering. Or in other words "that depends". Which is why I'm writing the dang article, so I only have to write it once... -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Posting from Google? See http://cfaj.freeshell.org/google/ "Applied Control Theory for Embedded Systems" came out in April. See details at http://www.wescottdesign.com/actfes/actfes.html
"Tim Wescott" <tim@seemywebsite.com> wrote in message news:q6mdnZgxjJhQHnbZnZ2dnUVZ_rGdnZ2d@web-ster.com...> Kinda off topic -- > > A month or two ago there was a spate of postings on these groups > displaying a profound misunderstanding of how to apply Nyquist's theorem > to problems of setting sampling or designing anti-alias filters. I helped > folks out as much as I could, but it really demands an article, which I am > currently working on. > > The misconceptions that I noticed pretty much boiled down to the following > two: > > One, "I need to monitor a signal that happens at X Hz, so I'm going to > sample it at 2X Hz". > > Two, "I can sample at X Hz, so I'm going to build an anti-alias filter > with a cutoff of X/2 Hz". > > I estimate that answering these misconceptions will only take 3-4k words, > but I don't want to miss any other big ones. > > Have you seen any other real howlers that relate to Nyquist, and what you > should really be thinking about when you're pondering sampling rates, > anti-aliasing filters and/or reconstruction filters? > > Danke. > > -- > > Tim Wescott > Wescott Design Services > http://www.wescottdesign.com >I have noticed that for switch mode power supplies the loop crossover frequency is Fs/2piD and have often modelled such things in spice and they have behaved themselves where the loop crossover frequency is well above a half of Fs which rather pisses on Nyquist.... What did I miss? DNA
Tim, are you going to be including in your artcle cases with filter banks, specifically, critical sampled, oversampled etc, and how nyquist fits into those implementations? Tim Wescott wrote:> David Hearn wrote: > > > Tim Wescott wrote: > > > >> Kinda off topic -- > >> > >> A month or two ago there was a spate of postings on these groups > >> displaying a profound misunderstanding of how to apply Nyquist's > >> theorem to problems of setting sampling or designing anti-alias > >> filters. I helped folks out as much as I could, but it really demands > >> an article, which I am currently working on. > >> > >> The misconceptions that I noticed pretty much boiled down to the > >> following two: > >> > >> One, "I need to monitor a signal that happens at X Hz, so I'm going to > >> sample it at 2X Hz". > >> > >> Two, "I can sample at X Hz, so I'm going to build an anti-alias filter > >> with a cutoff of X/2 Hz". > >> > >> I estimate that answering these misconceptions will only take 3-4k > >> words, but I don't want to miss any other big ones. > >> > >> Have you seen any other real howlers that relate to Nyquist, and what > >> you should really be thinking about when you're pondering sampling > >> rates, anti-aliasing filters and/or reconstruction filters? > >> > >> Danke. > > > > > > So, if you need to monitor a signal that occurs at xHz - what frequency > > should you sample it at? > > > > D > > You need to be more than 2X times the highest interesting frequency > component in your periodic wave, which can be quite high in some cases. > You may also have to do some anti-alias filtering. > > Or in other words "that depends". Which is why I'm writing the dang > article, so I only have to write it once... > > -- > > Tim Wescott > Wescott Design Services > http://www.wescottdesign.com > > Posting from Google? See http://cfaj.freeshell.org/google/ > > "Applied Control Theory for Embedded Systems" came out in April. > See details at http://www.wescottdesign.com/actfes/actfes.html
