Now I am debuging the TMS320C6713 hardware board(designed by myself). But when I run CCS 2.20, the CCS window just disappear, In windows task manager, I can find the ccs process.Just can't see the window. But if I use the demo board of 6713 by Ti, everything is OK,CCS is ok. what could be the problem? Thanks.
CCS 2.20 problem or hardware problem?
Started by ●August 26, 2006
Reply by ●August 26, 20062006-08-26
hans wrote:> Now I am debuging the TMS320C6713 hardware board(designed by myself). > But when I run CCS 2.20, the CCS window just disappear, > In windows task manager, I can find the ccs process.Just can't > see the window. > But if I use the demo board of 6713 by Ti, everything is OK,CCS is ok. > what could be the problem?You are using the demo version of CCS which works only if the eval board is connected. You should use the full version. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
