Dear Experts, I need your help in order to detect what i am possibly doing wrong. I try to run the examples that came with the board (just as it came), especially the video and video networking examples and the result is always the same: at the beginning the screen shows a color bar, and then when I try to run any of the examples the screen just becomes pink/grey. I am trying to run the examples for PAL systems using the configuration described on the user guides. I tried to compile the examples with CCS v3.1, and I get no errors but then when I load the program the result is the same. I already perform the update of CSL as adviced on http://c6000.spectrumdigital.com/evmdm642/V3/docs/evmdm642_faq.html. Any hint you can provide will be of great help. Thanks in advance Ant�nio Silva
EVMDM642 problem in running examples
Started by ●August 31, 2006
Reply by ●August 31, 20062006-08-31
arichard wrote:> I try to run the examples that came with the board (just as it came), > especially the video and video networking examples and the result is > always the same: at the beginning the screen shows a color bar, and then > when I try to run any of the examples the screen just becomes pink/grey.Possibly not much help, but I had exactly the same symptoms when I upgraded from CCS v3.0 to v3.1, but upgrading the CSL cured it. Are you sure that you're using the newer CSL? Cheers mark-r -- Currently sigless
