To promote some interesting discussion I thought I would raise the following question: Possibly as part of a sequence of processing, to interpolate a sampled sequence by 2 is it correct to keep the original samples and derive the in-between samples, or replace the original samples in the process of interpolating the signal. Dirk Bell DSP Consultant
Discussion: Interpolation Can of Worms
Started by ●September 12, 2006
Reply by ●September 12, 20062006-09-12
dbell wrote:> To promote some interesting discussion I thought I would raise the > following question: > > Possibly as part of a sequence of processing, to interpolate a sampled > sequence by 2 is it correct to keep the original samples and derive the > in-between samples, or replace the original samples in the process of > interpolating the signal.My gut tells me that the first option, being more tightly constrained, is in general more difficult than the second. I can see instances in which the first option is more desirable than the second, if only for esthetics. I therefore arrive at the Universal Answer: it depends. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Jerry Avins wrote:> dbell wrote: > >> To promote some interesting discussion I thought I would raise the >> following question: >> >> Possibly as part of a sequence of processing, to interpolate a sampled >> sequence by 2 is it correct to keep the original samples and derive the >> in-between samples, or replace the original samples in the process of >> interpolating the signal. > > > My gut tells me that the first option, being more tightly constrained, > is in general more difficult than the second. I can see instances in > which the first option is more desirable than the second, if only for > esthetics. I therefore arrive at the Universal Answer: it depends. > > JerryMore precisely: It depends on your application. I think that the only linear interpolation that you could use that would give you output points that match input points would be a 2-point, which doesn't have the best frequency domain characteristics. Fancier linear filters will tend to let other points bleed into the 'current' one, violating your rule. If you want to interpolate over more than two points _and_ get your exact match you'll either need to have a different rule for generating your in-between points, which is a shift-varying filter*, or you'd have to use something that's just plain nonlinear. Either of these solutions may be better for the problem at hand, but might have bad effects, too. So in the end (if it mattered) you'd have to investigate different methods, and choose the best one. * I was going to say "or you'd have to use something like splines, which is nonlinear" -- but I think that for an even sample rate interpolating with splines would end up being shift-varying, but linear. Hmm. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Posting from Google? See http://cfaj.freeshell.org/google/ "Applied Control Theory for Embedded Systems" came out in April. See details at http://www.wescottdesign.com/actfes/actfes.html
"dbell" <bellda2005@cox.net> wrote in news:1158072374.880336.237110 @e3g2000cwe.googlegroups.com:> To promote some interesting discussion I thought I would raise the > following question: > > Possibly as part of a sequence of processing, to interpolate a sampled > sequence by 2 is it correct to keep the original samples and derive the > in-between samples, or replace the original samples in the process of > interpolating the signal. > > Dirk Bell > DSP Consultant >I like all the "depends" answers, but the only reason I could see for the latter would be if you absolutely need the result to be differentiable for a certain number of iterations. It also depends on the interpolator you're using. If you're using some sort of high-order piece of nastiness that might ring, you might be giving up any semblance of reality if you toss the original data. -- Scott Reverse name to reply
Tim Wescott wrote:> Jerry Avins wrote: >> dbell wrote: >> >>> To promote some interesting discussion I thought I would raise the >>> following question: >>> >>> Possibly as part of a sequence of processing, to interpolate a sampled >>> sequence by 2 is it correct to keep the original samples and derive the >>> in-between samples, or replace the original samples in the process of >>> interpolating the signal. >> >> >> My gut tells me that the first option, being more tightly constrained, >> is in general more difficult than the second. I can see instances in >> which the first option is more desirable than the second, if only for >> esthetics. I therefore arrive at the Universal Answer: it depends. >> >> Jerry > > More precisely: It depends on your application. > > I think that the only linear interpolation that you could use that would > give you output points that match input points would be a 2-point, which > doesn't have the best frequency domain characteristics. Fancier linear > filters will tend to let other points bleed into the 'current' one, > violating your rule.Perhaps I misunderstood what you meant by 2-point, but any filter with impulse response of the form h[n] = {..., g[-2], 0, g[-1], 0, g[0], 1, g[1], 0, g[2], 0, g[3], ...} will match the input points with the output points. -- Jani Huhtanen Tampere University of Technology, Pori
Jani Huhtanen wrote:> Tim Wescott wrote: > > >>Jerry Avins wrote: >> >>>dbell wrote: >>> >>> >>>>To promote some interesting discussion I thought I would raise the >>>>following question: >>>> >>>>Possibly as part of a sequence of processing, to interpolate a sampled >>>>sequence by 2 is it correct to keep the original samples and derive the >>>>in-between samples, or replace the original samples in the process of >>>>interpolating the signal. >>> >>> >>>My gut tells me that the first option, being more tightly constrained, >>>is in general more difficult than the second. I can see instances in >>>which the first option is more desirable than the second, if only for >>>esthetics. I therefore arrive at the Universal Answer: it depends. >>> >>>Jerry >> >>More precisely: It depends on your application. >> >>I think that the only linear interpolation that you could use that would >>give you output points that match input points would be a 2-point, which >>doesn't have the best frequency domain characteristics. Fancier linear >>filters will tend to let other points bleed into the 'current' one, >>violating your rule. > > > Perhaps I misunderstood what you meant by 2-point, but any filter with > impulse response of the form > > h[n] = {..., g[-2], 0, g[-1], 0, g[0], 1, g[1], 0, g[2], 0, g[3], ...} > > will match the input points with the output points. > >Well I'll be damned. That's obvious. The nice thing about always doing my newsgroup stuff in the morning is that I can claim that I'm not awake yet. Certainly that must be the case here. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Posting from Google? See http://cfaj.freeshell.org/google/ "Applied Control Theory for Embedded Systems" came out in April. See details at http://www.wescottdesign.com/actfes/actfes.html
That would be a halfband filter. Dirk Jani Huhtanen wrote:> Tim Wescott wrote: > > > Jerry Avins wrote: > >> dbell wrote: > >> > >>> To promote some interesting discussion I thought I would raise the > >>> following question: > >>> > >>> Possibly as part of a sequence of processing, to interpolate a sampled > >>> sequence by 2 is it correct to keep the original samples and derive the > >>> in-between samples, or replace the original samples in the process of > >>> interpolating the signal. > >> > >> > >> My gut tells me that the first option, being more tightly constrained, > >> is in general more difficult than the second. I can see instances in > >> which the first option is more desirable than the second, if only for > >> esthetics. I therefore arrive at the Universal Answer: it depends. > >> > >> Jerry > > > > More precisely: It depends on your application. > > > > I think that the only linear interpolation that you could use that would > > give you output points that match input points would be a 2-point, which > > doesn't have the best frequency domain characteristics. Fancier linear > > filters will tend to let other points bleed into the 'current' one, > > violating your rule. > > Perhaps I misunderstood what you meant by 2-point, but any filter with > impulse response of the form > > h[n] = {..., g[-2], 0, g[-1], 0, g[0], 1, g[1], 0, g[2], 0, g[3], ...} > > will match the input points with the output points. > > > -- > Jani Huhtanen > Tampere University of Technology, Pori
dbell wrote:> To promote some interesting discussion I thought I would raise the > following question: > > Possibly as part of a sequence of processing, to interpolate a sampled > sequence by 2 is it correct to keep the original samples and derive the > in-between samples, or replace the original samples in the process of > interpolating the signal. > > Dirk Bell > DSP Consultant >Hi Dirk, I think the only time the latter would be preferable is if the signal needs to be filtered with a corner frequency other than the original folding frequency. Or if development time is more precious than cpu cycles :) As for the former ... Yes! Increasing the rate by two with anti-aliasing can be accomplished by interleaving the original samples with the sequence delayed by one-half sample. I've used this with great results. As others in this thread have mentioned, half-band filters are superb for this application. Convolving the original signal with the odd coefficients from a half-band filter will create this half-sample delayed signal. Works good with fast convolution too, at least on a GPP. FWIW, This makes a good first stage in a multirate interpolator. The subsequent stages can use much shorter FIRs since they are nicely band-limited and the anti-aliasing filters can have wide transition bands. There is no call for fast convolution on anything but the first stage. -- Mark Borgerding
Reply by ●September 13, 20062006-09-13
dbell skrev:> To promote some interesting discussion I thought I would raise the > following question: > > Possibly as part of a sequence of processing, to interpolate a sampled > sequence by 2 is it correct to keep the original samples and derive the > in-between samples, or replace the original samples in the process of > interpolating the signal.I generally tend to prefer the "intuitively acceptable" method wherever possible. I always use the simple, intuitive approaches first to get a "baseline" of how a method works, and then test out whatever modifications. The idea is to get a feel for when a particular method works, and when it doesn't. Hopefully, one is able to make informed choises about which method to use with what problem. Besides, it is an easier "sell" to keep the original samples and fill in the missing ones. From a pedagogical point of view (maybe during a project progress meeting with a paying customer present) it is easy to see -- and for the customer to accept -- the old samples with some new ones in between, as opposed to all "new" samples. Of course, at a later stage you may find it convenient to combine an interpolation step and, say, a subsequent filtering step into one block, but in that case you can always say that "the interpolation + filter sequence has been combined into one operation", which may be easier for the customer to keep track of. Rune
dbell wrote:> > To promote some interesting discussion I thought I would raise the > following question: > > Possibly as part of a sequence of processing, to interpolate a sampled > sequence by 2 is it correct to keep the original samples and derive the > in-between samples, or replace the original samples in the process of > interpolating the signal.I would like to contradict what everyone else in this thread has said ;-). I prefer the second method or rather I consider the first method wrong and here's why. So, for the upsample by 2 case lets use: fs -- source sample rate fd -- desitnation sample rate (fs * 2) Consider a source signal with frequency components all the way up to a frequency of fx = 0.5 * fs - epsilon where epsilon is orders of magnitude smaller than fs. Now upsample the source signal by inserting a zero valued sample between each of the original samples and filter the resulting signal (at sample rate of fd) using a half band FIR anti aliasing filter of the form: h[n] = {..., g[-2], 0, g[-1], 0, g[0], 1, g[1], 0, g[2], 0, g[3], ...} Notice however than the frequency response of this filter has a passband magnitude response of 2, a -3dB point occuring at 0.5 of the source sample rate. This looks something like (ASCII art): +--------------------- -3dB point | \ / | \ | |\ | | \ | | \ | | \ | | \ | | \ | | \ | | \ +----------------------+----------------------+- fs/2 fd/2 So whats the problem here? Well remember that source frequency at a frequency of fx? Well, that frequency gets aliased to fx1 = 0.5 * fs + epsilon and the attenuation of the anti aliasing filter at fx1 is only about 3dB. Now normally, fs/2 is 22.05kHz or more so that the original fx and the alias frequency fx1 are both out of hearing range. However, they do exist and at least one of them shouldn't be there. These alias frequencies should be obvious when upsample from say 8kHz to 16kHz. As far as I am concerned the filter should look like this: +--------------- | \ | \ | \ | \ | \ | \ target stopband attenuation | \ / | | | |\ | | \ +----------------------+----------------------+- fs/2 fd/2 The anti-aliasing filters in Secret Rabbit Code http://www.mega-nerd.com/SRC/ are designed like this. Erik Erik -- +-----------------------------------------------------------+ Erik de Castro Lopo +-----------------------------------------------------------+ "It has been discovered that C++ provides a remarkable facility for concealing the trival details of a program -- such as where its bugs are." -- David Keppel
