Does signal from geostationaric satellite need to be equalized? I'm talking about static receivers, not mobile. Because as far as I understand this channel, except for non-linear distorion due to high-power amplifiers, which does not affect M-PSK modulations, there are no other distortions that require equalization. Please help me with this!!! Thanks, Moshe
Equalization in satelleite channel
Started by ●September 21, 2006
Reply by ●September 21, 20062006-09-21
hi tmoshe,
quite interesting question you asked. Regarding
satellite, their antennas will be pin pointed towards receiver earth
station antennas (powerfull directioned antennas).
if it is perfectly so
1. no question of multipath.
2. regarding fading, definately it will be there..
3, since you told it is static, no doppler effect.
hope, there are many greats here in this group.they will come up with
very good answers
regards
particlereddy
> Thanks,
> Moshe
Hi Particlereddy, Thanks! Of course that there is fading but I think that it is very slow, so again, no equalizer is needed.>hi tmoshe, > quite interesting question you asked. Regarding >satellite, their antennas will be pin pointed towards receiver earth >station antennas (powerfull directioned antennas). >if it is perfectly so >1. no question of multipath. > >2. regarding fading, definately it will be there.. > >3, since you told it is static, no doppler effect. > >hope, there are many greats here in this group.they will come up with >very good answers >:) > >regards >particlereddy > > >tmoshe wrote: >> Does signal from geostationaric satellite need to be equalized? >> I'm talking about static receivers, not mobile. >> Because as far as I understand this channel, except for non-linear >> distorion due to high-power amplifiers, which does not affect M-PSK >> modulations, there are no other distortions that require equalization. >> Please help me with this!!! >> Thanks, >> Moshe > >
"tmoshe" <moshe.twitto@horizonsemi.com> wrote in message news:4tudneFujZKIo4_YnZ2dnUVZ_tCdnZ2d@giganews.com...> Does signal from geostationaric satellite need to be equalized? > I'm talking about static receivers, not mobile. > Because as far as I understand this channel, except for non-linear > distorion due to high-power amplifiers, which does not affect M-PSK > modulations, there are no other distortions that require equalization.If we are talking about a non-regenerative transponder channel that is sub-divided into smaller FDMA uplink sub-channels using the same HPA, then equalization across the entire transponder channel passband would be beneficial in order to ensure that one uplink does not use more HPA power at the expense other uplinks. It is possible (indeed highly likely in practice) that one uplink will be stronger than another for many reasons such as off-pointed antennas or polarization mismatch. Typically correction can be achieved by providing frequency specific AGCs across the transponder's passband using a dynamically calculated custom filter. Cheers, Howard
"tmoshe" <moshe.twitto@horizonsemi.com> wrote in message news:4tudneFujZKIo4_YnZ2dnUVZ_tCdnZ2d@giganews.com...> Does signal from geostationaric satellite need to be equalized? > I'm talking about static receivers, not mobile. > Because as far as I understand this channel, except for non-linear > distorion due to high-power amplifiers, which does not affect M-PSK > modulations, there are no other distortions that require equalization. > Please help me with this!!! > Thanks, > Moshe >Well you need some equalization just to undo the ISI caused by the symbol shaping filter. Depending on the roll off factor it can be pretty distorted even direct from a signal generator. However, I think you're right the delay spread should be very minimal since there's really nothing to reflect off of. I would google: "delay spread" "satellite channel" and see what pops up. -Clark
tmoshe wrote:> Does signal from geostationaric satellite need to be equalized? > I'm talking about static receivers, not mobile.There could be a need for the equalization because of the multipath propagation. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
Thanks guys, I would like to reffer to some of your comments. Howard: Of course I use matched filter. But with fixed coefficients, I forgot to note that. Clark: I'm running agc over each channel (about 40Mhz), after I got it from the tuner. Is that enough or there is possibility that there will be varations in the gain INSIDE a channel??? If so I think that equalizer is obligatory. Vladimir: to my opinion, due to the directionality of the sat-antenna, the multipath are very week (less than -20dBc in most cases).
"tmoshe" <moshe.twitto@horizonsemi.com> wrote in message news:Q6-dnQlzfN_tL4_YnZ2dnUVZ_vudnZ2d@giganews.com...> Thanks guys, > > I would like to reffer to some of your comments. > > Howard: Of course I use matched filter. But with fixed coefficients, I > forgot to note that. > > Clark: I'm running agc over each channel (about 40Mhz), after I got it > from the tuner. Is that enough or there is possibility that there will be > varations in the gain INSIDE a channel??? If so I think that equalizer is > obligatory. >PSK is fairly immune to small gain changes. If your matched filter undoes the ISI then you can probably live without the EQ. In my product I don't know the shaping ahead of time so I need an equalizer to determine the matched filter for me.> Vladimir: to my opinion, due to the directionality of the sat-antenna, the > multipath are very week (less than -20dBc in most cases). > >
"Anonymous" <someone@microsoft.com> wrote in message news:owyQg.32477$Md4.26578@tornado.southeast.rr.com...> > "tmoshe" <moshe.twitto@horizonsemi.com> wrote in message > news:Q6-dnQlzfN_tL4_YnZ2dnUVZ_vudnZ2d@giganews.com... >> Thanks guys, >> >> I would like to reffer to some of your comments. >> >> Howard: Of course I use matched filter. But with fixed coefficients, I >> forgot to note that. >> >> Clark: I'm running agc over each channel (about 40Mhz), after I got it >> from the tuner. Is that enough or there is possibility that there will be >> varations in the gain INSIDE a channel??? If so I think that equalizer is >> obligatory. >> > > PSK is fairly immune to small gain changes. If your matched filter undoes > the ISI then you can probably live without the EQ. In my product I don't > know the shaping ahead of time so I need an equalizer to determine the > matched filter for me. > >> Vladimir: to my opinion, due to the directionality of the sat-antenna, >> the >> multipath are very week (less than -20dBc in most cases). >>You can sometimes get a bit better ISI with a bit of equalisation as the channel filter often puts a bit of slope at the band edges and this isn't always equalised in the uplink. Best of Luck - Mike
"Mike Yarwood" <mpyarwood@btopenworld.com> wrote in message news:Fe6dnZRMZrFeU4_YRVnytQ@bt.com...> > "Anonymous" <someone@microsoft.com> wrote in message > news:owyQg.32477$Md4.26578@tornado.southeast.rr.com... > > > > "tmoshe" <moshe.twitto@horizonsemi.com> wrote in message > > news:Q6-dnQlzfN_tL4_YnZ2dnUVZ_vudnZ2d@giganews.com... > >> Thanks guys, > >> > >> I would like to reffer to some of your comments. > >> > >> Howard: Of course I use matched filter. But with fixed coefficients, I > >> forgot to note that. > >> > >> Clark: I'm running agc over each channel (about 40Mhz), after I got it > >> from the tuner. Is that enough or there is possibility that there willbe> >> varations in the gain INSIDE a channel??? If so I think that equalizeris> >> obligatory. > >> > > > > PSK is fairly immune to small gain changes. If your matched filterundoes> > the ISI then you can probably live without the EQ. In my product I don't > > know the shaping ahead of time so I need an equalizer to determine the > > matched filter for me. > > > >> Vladimir: to my opinion, due to the directionality of the sat-antenna, > >> the > >> multipath are very week (less than -20dBc in most cases). > >> > You can sometimes get a bit better ISI with a bit of equalisation as the > channel filter often puts a bit of slope at the band edges and this isn't > always equalised in the uplink. > > Best of Luck - Mike > >By the way IF you do need an equalizer it probably doesn't have to be very long (4-5 symbols) so the answer may be better safe than sorry since it won't cost you much. -Clark
