> > >> > > You can sometimes get a bit better ISI with a bit of equalisation as the > > channel filter often puts a bit of slope at the band edges and this isn't > > always equalised in the uplink. > > > > Best of Luck - Mike > > > > > > By the way IF you do need an equalizer it probably doesn't have to be very > long (4-5 symbols) so the answer may be better safe than sorry since it > won't cost you much. > > -ClarkThere are many things in the system that could put some slope in the system, for example the transmission lines feeding the antennas may have some mis-match and can cause ripple in the passband. Adaptive EQ will improve that. You may not NEED to have adaptive EQ to close the link, but adaptive EQ in the receiver will help to keep the implementation losses in the overall system at a minimum. Mark
Equalization in satelleite channel
Started by ●September 21, 2006
Reply by ●September 21, 20062006-09-21
Reply by ●September 30, 20062006-09-30
On 21 Sep 2006 17:04:32 -0700, "Mark" <makolber@yahoo.com> wrote:>> > You can sometimes get a bit better ISI with a bit of equalisation as the >> > channel filter often puts a bit of slope at the band edges and this isn't >> > always equalised in the uplink. >> > >> > Best of Luck - Mike >> > >> > >> >> By the way IF you do need an equalizer it probably doesn't have to be very >> long (4-5 symbols) so the answer may be better safe than sorry since it >> won't cost you much. >> >> -Clark > >There are many things in the system that could put some slope in the >system, for example the transmission lines feeding the antennas may >have some mis-match and can cause ripple in the passband. Adaptive EQ >will improve that. You may not NEED to have adaptive EQ to close the >link, but adaptive EQ in the receiver will help to keep the >implementation losses in the overall system at a minimum. > >MarkYeah, that's generally right by my understanding, i.e., the only reason to use an EQ in a satellite link is to correct for tilt or other non-flat signal pass behavior in the transponder. This usually only comes into play when trying to use higher-order modulations like 16-QAM or higher. There's no multipath to speak of in satellite systems as there are no significant reflectors along the signal path and the antennas are highly directive. Eric Jacobsen Minister of Algorithms, Intel Corp. My opinions may not be Intel's opinions. http://www.ericjacobsen.org
