Acoustic Echo Cancellation using LMS algorithm with C++ coding
Started by Unknown September 26, 2006
 Hai all,
          I am working on Acoustic Echo Cancellation using LMS
algorithm . Theoretically I went through that thorougly and now I am
implementing that using C++.
         I am considering the 16 bit mono with 8KHz sampling
frequency.As it is considered of 16 bits amplitude(intensity) of each
sample should be within the range -32768 to 32767.As we know the
computational equations in that are:
  >              Estimated echo sample,n[i] = x[i] * w(i)
                     where x[i] is farend signal sample.
                               w(i) is the weight of the filter
corresponding to n[i]
  >              Estimated error signal is,e[i] = y[i] - n[i]
                    where y[i] is the desired signal which is the
combination of farend signal and the near end signal.
 >                Weights for the next iteration is, = w(i) + 2 * u *
e[i] * x[i]
                      where u is the convergence weight factor.
            But the problem is when the intensity of the samples of the
signal exceeds 32767 which is the right extreme of the range it is
taking the values from the left extreme . That is if the intensity of a
sample ie 32768 which is greater to the right extreme 32767 by one
number  and hence it is taking the value from the beginning,  that is
it will take -32768. ie.,
  for         32768     it will take        -32768
  for         32769     it will take        -32767
  for         32770     it will take        -32766
in this it will proceed .My doubt is "If it decrease the intensity
values like thie the entire signal changes.So what is the solution? Can
we set in such a manner that if the intensity of sample exceeds 32767
that sample intensity should be maintained at a maximum of 32767
instead of it going to the starting of the range.
                Can any one give me the idea regarding this.Can we keep
the value of the sample to be 32767 when it exceeds the right extreme
of the range.
                                   Thanking in advance.
Regards,
Aparna Ram.K.
aparnaram84@yahoo.co.in wrote:
> So what is the solution? Can > we set in such a manner that if the intensity of sample exceeds 32767 > that sample intensity should be maintained at a maximum of 32767 > instead of it going to the starting of the range.
Yes. It is called saturation. It needs to be applied to extreme negative values as well, of course. How does the intesity of signal increase in your system? Are you applying gain factors (AGC, ALC) that can be greater than 1.0? C
> Hai all, > > I am working on Acoustic Echo Cancellation using LMS > algorithm . Theoretically I went through that thorougly and now I am > implementing that using C++.
Is it a third time you are telling that you have understood everything? It appears you are missing the basics again.
> Can any one give me the idea regarding this.Can we keep > the value of the sample to be 32767 when it exceeds the right extreme > of the range.
Clipping the value to keep it in the valid range is called "saturation". It is supported by the DSP arithmetics. However the real problem with the LMS is what to do with the saturated data... Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
Vladimir Vassilevsky wrote:
> > > aparnaram84@yahoo.co.in wrote: > >> Hai all, >> >> I am working on Acoustic Echo Cancellation using LMS >> algorithm . Theoretically I went through that thorougly and now I am >> implementing that using C++. > > > Is it a third time you are telling that you have understood everything? > It appears you are missing the basics again.
I wonder why it is that "I went through that thoroughly" usually seem to preface something that shows little understanding of the topic. :-)
>> Can any one give me the idea regarding this.Can we keep >> the value of the sample to be 32767 when it exceeds the right extreme >> of the range. > > > Clipping the value to keep it in the valid range is called "saturation". > It is supported by the DSP arithmetics. > > However the real problem with the LMS is what to do with the saturated > data...
This is one of the pains of LMS (well, NLMS, since LMS is useless for acoustic echo cancellation). If you just let the saturation logic do its work, things are fast and efficient. However, most machines then give you no indication that saturation occurred. If you monitor for overflow it massively slows things down. However, you really do need to detect saturation and freeze adaption when it occurs. Steve
> aparnaram84@yahoo.co.in wrote: > > > Hai all, > > > > I am working on Acoustic Echo Cancellation using LMS > > algorithm . Theoretically I went through that thorougly and now I am > > implementing that using C++. > > Is it a third time you are telling that you have understood everything? > It appears you are missing the basics again. > > > >It is a mistake to say that ' I have understood every thing '.But when I studied and analysed that I got the reason for each and every step So I thought that I understood every thing.But each and every time when I am revising that I am getting some new points and I am getting new doubts. So now I came to know that this subject is a ocean . Here after I wont say that' I under stood every thing ' as there is a lot to understand and we will get more ideas on a topic when we think more.. > > > Can any one give me the idea regarding this.Can we keep > > the value of the sample to be 32767 when it exceeds the right extreme > > of the range. > > Clipping the value to keep it in the valid range is called "saturation". > It is supported by the DSP arithmetics. > > However the real problem with the LMS is what to do with the saturated > data... > > > > By the way thanks for the reply and I think that this information will help me a lot to proceed further.Can you suggest me some reference website to proceed regarding this point.I think that it will take time to clip each and every sample if it exceeds the maximum range.Then what is the solution. > > > Vladimir Vassilevsky > > DSP and Mixed Signal Design Consultant > > http://www.abvolt.com
Steve Underwood wrote:
> Vladimir Vassilevsky wrote: > > > > > > aparnaram84@yahoo.co.in wrote: > > > >> Hai all, > >> > >> I am working on Acoustic Echo Cancellation using LMS > >> algorithm . Theoretically I went through that thorougly and now I am > >> implementing that using C++. > > > > > > Is it a third time you are telling that you have understood everything? > > It appears you are missing the basics again. > > I wonder why it is that "I went through that thoroughly" usually seem to > preface something that shows little understanding of the topic. :-) > > > > > When I read that I got the reason for each and every step so I thought that 'I went through that thoroughly' . But now I came to know my mistake.Here after I wont repeat this.By the way thanks for the reply. > > >> Can any one give me the idea regarding this.Can we keep > >> the value of the sample to be 32767 when it exceeds the right extreme > >> of the range. > > > > > > Clipping the value to keep it in the valid range is called "saturation". > > It is supported by the DSP arithmetics. > > > > However the real problem with the LMS is what to do with the saturated > > data... > > This is one of the pains of LMS (well, NLMS, since LMS is useless for > acoustic echo cancellation). If you just let the saturation logic do its > work, things are fast and efficient. However, most machines then give > you no indication that saturation occurred. If you monitor for overflow > it massively slows things down. However, you really do need to detect > saturation and freeze adaption when it occurs. > > Steve
> I am considering the 16 bit mono with 8KHz sampling > frequency.As it is considered of 16 bits amplitude(intensity) of each > sample should be within the range -32768 to 32767.As we know the > computational equations in that are: > > But the problem is when the intensity of the samples of the > signal exceeds 32767 which is the right extreme of the range it is > taking the values from the left extreme . That is if the intensity of a > sample ie 32768 which is greater to the right extreme 32767 by one > number and hence it is taking the value from the beginning, that is > it will take -32768. ie., > > > for 32768 it will take -32768 > for 32769 it will take -32767 > for 32770 it will take -32766 > > > in this it will proceed .My doubt is "If it decrease the intensity > values like thie the entire signal changes.So what is the solution? Can > we set in such a manner that if the intensity of sample exceeds 32767 > that sample intensity should be maintained at a maximum of 32767 > instead of it going to the starting of the range. > > Can any one give me the idea regarding this.Can we keep > the value of the sample to be 32767 when it exceeds the right extreme > of the range.
Solutions: 1) Adaptive filtering algorithms do not care whatever x(n) is; 2) If x(n) exceeds the ranges that you expect, why not adjust your amplifer or ADC of the system; 3) if you want to simulate a 16-bit fixed point DSP using C++, saturate the input data, i.e. forcing it within 0x0000-0xFFFF Regards, Leans.
