Hi, I am designing an 802.11b transceiver and after developing the block of modulators and scrambler I have a question: these ones (blocks) have control inputs which must be used to control their functionality ... How can I control them? : There are three parts on the frame: preamble, header and data ... and each one can be transmitted with different modulation so ... how can the physical layer know when it must change the modulation? ... using, for example, a finite state machine? ... a microprocessor? ... an embedded microprocessor?. Thanks for your advices. Jajo.
Control of modulator blocks
Started by ●October 10, 2006
Reply by ●October 10, 20062006-10-10
jajo wrote:> Hi, > > I am designing an 802.11b transceiver and after developing the block of > modulators and scrambler I have a question: these ones (blocks) have > control inputs which must be used to control their functionality ... > How can I control them? : > > There are three parts on the frame: preamble, header and data > ... and each one can be transmitted with different modulation so ... > how can the physical layer know when it must change the modulation? ... > using, for example, a finite state machine? ... a microprocessor? ... > an embedded microprocessor?. > > Thanks for your advices. > > Jajo. >I would expect that such control would come from the link layer. As far as the technology to implement them -- what makes the most sense? The answer to this question will depend on the required reaction speed, and whether you have any existing plans on where you're going to put the link layer. I suspect that your speeds are great enough, and the requirements for the different modulation formats are simple enough, that implementing this as a state machine in your digital hardware would be the most appropriate -- but you may find that for some screwy reason it makes more sense to time or bit-bang this from a microprocessor. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Posting from Google? See http://cfaj.freeshell.org/google/ "Applied Control Theory for Embedded Systems" came out in April. See details at http://www.wescottdesign.com/actfes/actfes.html
Reply by ●October 11, 20062006-10-11
> > > I would expect that such control would come from the link layer. As far > as the technology to implement them -- what makes the most sense? The > answer to this question will depend on the required reaction speed, and > whether you have any existing plans on where you're going to put the > link layer. > > I suspect that your speeds are great enough, and the requirements for > the different modulation formats are simple enough, that implementing > this as a state machine in your digital hardware would be the most > appropriate -- but you may find that for some screwy reason it makes > more sense to time or bit-bang this from a microprocessor. >Hi, I agree with your opinions but I would like to point out something. My first idea consisted on using an state machine but I noticed that this option y the least flexible. So I found three options more: a embedded microprocessor into the FPGA (picoblaze, microblaze or powerpc for Xilinx FPGAs), and external microcontroller or use a PC. I am not sure about which options is the best, what do you think? . My problem is the speed of each deviced since, for example, an DBPSK modulation requires a rate of 1Mbps ... At this moment, I am a bit lost. Thanks Jajo
jajo wrote:>>I would expect that such control would come from the link layer. As far >>as the technology to implement them -- what makes the most sense? The >>answer to this question will depend on the required reaction speed, and >>whether you have any existing plans on where you're going to put the >>link layer. >> >>I suspect that your speeds are great enough, and the requirements for >>the different modulation formats are simple enough, that implementing >>this as a state machine in your digital hardware would be the most >>appropriate -- but you may find that for some screwy reason it makes >>more sense to time or bit-bang this from a microprocessor. >> > > > Hi, > > I agree with your opinions but I would like to point out something. My > first idea consisted on using an state machine but I noticed that this > option y the least flexible. So I found three options more: a embedded > microprocessor into the FPGA (picoblaze, microblaze or powerpc for > Xilinx FPGAs), and external microcontroller or use a PC. I am not sure > about which options is the best, what do you think? . > > My problem is the speed of each deviced since, for example, an DBPSK > modulation requires a rate of 1Mbps ... At this moment, I am a bit > lost. >Microprocessor + program = finite state machine. It's just that software can easily house much bigger finite state machines than a 'pure logic' implementation can. So the question shouldn't be "can I write a finite state machine in Verilog (or VHDL) that's big enough to work?" but "will my great big finite state machine fit on an economical device?". I'm not familiar with the protocol, but I bet that if you dig a bit you'll find that you don't need a lot of flexibility. I would expect that the preamble and header are always the same length, and the length of the data will be known before the packet is sent. Even if the preamble and header are of varying length, too, you should be able to put a state machine in logic that uses numbers supplied to it by software, then calculate the lengths of your pieces in software before the packet is sent. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Posting from Google? See http://cfaj.freeshell.org/google/ "Applied Control Theory for Embedded Systems" came out in April. See details at http://www.wescottdesign.com/actfes/actfes.html
