What would be the best way to describe the following in using discrete-time Z transfer function: A software loop filter computes a set of metrics using a block of data of 1024 samples (4 samples spans a symbol period). The computed metrics are then applied to the input data samples starting from next block, and so on and so forth. If I want to model this behavior in Z-domain, what would be the delay of 1024 samples be modeled as? Z^-1024 ? Z^1024/4 (in symbol terms)?, or Z^-1?
Model delays in z-domain
Started by ●October 26, 2006
Reply by ●October 27, 20062006-10-27
Jamake wrote:> What would be the best way to describe the following in using > discrete-time Z transfer function: > > A software loop filter computes a set of metrics using a block of data > of 1024 samples (4 samples spans a symbol period). The computed metrics > are then applied to the input data samples starting from next block, > and so on and so forth. > If I want to model this behavior in Z-domain, what would be the delay > of 1024 samples be modeled as? Z^-1024 ? Z^1024/4 (in symbol terms)?, > or Z^-1? >It really depends on what you're trying to find out. If I read you correctly you update the metrics once every block, and I assume that the effect of the computed metrics on the input data isn't known until the end of the next block. If that's the case, then you would use z^-1. If you're updating symbol-by-symbol, then you'd need to use z^-256. If you're updating sample-by-sample, then you'd need to use z^-1024. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Posting from Google? See http://cfaj.freeshell.org/google/ "Applied Control Theory for Embedded Systems" came out in April. See details at http://www.wescottdesign.com/actfes/actfes.html
