robert bristow-johnson wrote:> stevenj@alum.mit.edu wrote: > > > > From the perspective of trigonometric interpolation (i.e. taking the > > DFT formula and using it to interpolate between the samples), splitting > > up the Nyquist amplitude half-and-half between positive and negative > > frequencies is in some sense the optimal choice. It leads to a minimal > > rms slope interpolation, and also interpolates real data to real data. > > this is what was motivating this question i've been having about > bandlimited interpolation of periodic discrete signals. letting > x[n]=x[n+N] for all n, when the period N is odd, there is no Nyquist > component and the reconstruction formula is the Dirichlet thingie: > > N-1 > x(t) = SUM{ x[n] * sin(N*pi*(t-n))/(N*sin(pi*(t-n))) } > n=0 > > x(t+N) = x(t) > > but for the case of N even, there is a (potential) component at > Nyquist, for real x[n] this component has to be real, and if you split > it half and half and reconstruct, you get > > > N-1 > x(t) = SUM{ x[n] * sin(N*pi*(t-n))/(N*tan(pi*(t-n))) } > n=0 > > x(t+N) = x(t) > > it's the same for interpolating spectra coming out of the DFT when N is > odd, but not for N even.>> On the other hand, if your Nyquist amplitude is not very small then you >> probably have more serious problems with aliasing. If it is small, >> then it doesn't matter much what you do with it.If the signal is strongly bandlimited, then there is no content in the N/2 bin. If the signal is weakly bandlimited, then N has to approach infinity for the N/2 bin to determine the content at that frequency. I'm not sure if there is a significant difference in the two reconstruction formulas for N and N+1 as N approaches infinity. Thoughts? IMHO. YMMV. -- rhn A.T nicholson d.0.t C-o-M
FFT Algorithm and Time
Started by ●November 11, 2006
Reply by ●November 14, 20062006-11-14
Ron N. wrote:> If the signal is strongly bandlimited, then there is no content in the N/2 bin.let's say we don't know how strongly bandlimited it was originally, except there was nothing above Nyquist. maybe *some* energy at Nyquist.> If the signal is weakly bandlimited, then N has to approach infinity for > the N/2 bin to determine the content at that frequency.i don't really get that at all. N is fixed. the curiousity i was bringing up is given a perfectly periodic sequence, x[n] such that x[n+N] = x[n] for all n. so if you know one period, say x[n] for 0 <= n < N then you have a complete definition for x[n] for all n. correct? so, if we were to reconstruct out of those real samples a continuous-time periodic signal, x(t) (let's assume the sampling period to be 1, with no loss of generality) so that x(t-N) = x(t) for all t, how is the function defined in terms of the finite set of samples x[0], x[1], ... x[N-1] that fully define the periodic sequence and, these discrete sequence should be able to fully define the continuous-time signal it was sampled from (assuming appropriate bandlimiting, which we are pushing the envelope a little). now, usually, we think of the ideal interpolation formula for x(t) is: +inf x(t) = SUM{ x[n] * sinc(t - n) } n=-inf N-1 +inf = SUM{ SUM{ x[n+m*N] * sinc(t - (n+m*N)) } } n=0 m=-inf but since x[n+m*N] = x[n] for any integer m, then N-1 +inf x(t) = SUM{ SUM{ x[n] * sinc(t - (n+m*N)) } } n=0 m=-inf N-1 +inf = SUM{ x[n] * SUM{ sinc(t - n - m*N) } } n=0 m=-inf N-1 = SUM{ x[n] * h(t-n) } n=0 now this interpolation function, +inf h(t) = SUM{ sinc(t - m*N) } } m=-inf is periodic with period N, h(t+N) = h(t) for all t, as we expect. so what does that periodic interpolation function look like? i've pondered this a while and first posted this to comp.dsp in 2001: http://groups.google.com/group/comp.dsp/msg/2cbabcc52d43399c?fwc=1 thread: http://groups.google.com/group/comp.dsp/browse_thread/thread/44a63e8177ff7365/2cbabcc52d43399c?#2cbabcc52d43399c take a look at that. Adrian Hey got into it enough to see the thing that was bothering me a little. anyway, the result i get for a closed for periodic h(t) is { sin(pi*t)/(N*sin(pi*t/N)) N odd h(t) = { { sin(pi*t)/(N*tan(pi*t/N)) N even from above you get show +inf h(t) = SUM{ sin(pi*(t - m*N))/(pi*(t - m*N)) } } m=-inf +inf = sin(pi*t) * SUM{ 1/(pi*(t - m*N)) } } N even m=-inf +inf = sin(pi*t) * SUM{ ((-1)^m)/(pi*(t - m*N)) } } N odd m=-inf> I'm not sure if there is a significant difference in the two reconstruction > formulas for N and N+1 as N approaches infinity. Thoughts?i just don't want to make that assumption and equality holds exactly for the two cases, even and odd. one case the formula looks just like the Dirichlet interpolation commonly done for the FFT and the other, it's slightly different, but it *is* different. in the even case, the tails of those sinc() functions have bumps of opposite polarity so they cancel themselves out more than in the odd case where the tails, though descreasing in amplitude as 1/x, have their bumps of the same polarity, so they team up. so i'm pretty sure the formula is correct (the 1/tan() reduces the amplitude more than the 1/sin() as one approaches midway between the two main pulses. it also came up (indirectly) with tthese two mathematical identities: +inf 1/tan(t) = SUM{ 1/(t - m*pi) } m=-inf +inf 1/sin(t) = SUM{ ((-1)^m)/(t - m*pi) } m=-inf which i have not been able to prove directly. if someone has it, i would like some insight for why the Dirichlet formula applies exactly only for N odd, not exactly for N even, although it applies exactly for both N odd or N even in the case of interpolating DFT output to get the DTFT of the time-limited x[n]. do you guys see what it is that is bothering me? or proving more directly the two math identities above would be gratifying. i have not been able to do that directly, as of yet. r b-j
Reply by ●November 15, 20062006-11-15
robert bristow-johnson wrote:> stevenj@alum.mit.edu wrote: > > > > From the perspective of trigonometric interpolation (i.e. taking the > > DFT formula and using it to interpolate between the samples), splitting > > up the Nyquist amplitude half-and-half between positive and negative > > frequencies is in some sense the optimal choice. It leads to a minimal > > rms slope interpolation, and also interpolates real data to real data. > > this is what was motivating this question i've been having about > bandlimited interpolation of periodic discrete signals. letting > x[n]=x[n+N] for all n, when the period N is odd, there is no Nyquist > component and the reconstruction formula is the Dirichlet thingie: > > N-1 > x(t) = SUM{ x[n] * sin(N*pi*(t-n))/(N*sin(pi*(t-n))) } > n=0 > > x(t+N) = x(t) > > but for the case of N even, there is a (potential) component at > Nyquist, for real x[n] this component has to be real, and if you split > it half and half and reconstruct, you get > > > N-1 > x(t) = SUM{ x[n] * sin(N*pi*(t-n))/(N*tan(pi*(t-n))) } > n=0 > > x(t+N) = x(t)Robert, are you claiming that x(n) = x[n]? I tried your formula in a maths program, and it seems that x(t) is periodic with period 1, and does not at all interpolate x[n] (at any scale). The (unique) pi-bandlimited interpolation function f(t) of the uniformly spaced discrete N-periodic data x[n] is given (for n even) by f(t) = 1/n ( a_0 + 2 sum_{k=1}^{N/2-1} ( a_k cos(2 pi k / N t) - b_k sin(2 pi k / N t) ) + a_{N/2} cos(pi t) ), where a_k = Re[ X[k] ] and b_k = Im[ X[k] ], and X[k] = DFT[ x[n] ]. This results in f(n) = x[n], and f(t + N) = f(t) for all t. For odd N, you can scratch the Nyquist cosine term and sum to (N-1)/2. Regards, Andor
Andor wrote:> > are you claiming that x(n) = x[n]?yes, for n = integer.> I tried your formula in a maths > program, and it seems that x(t) is periodic with period 1, and does not > at all interpolate x[n] (at any scale).it should be periodic with period N.> The (unique) pi-bandlimited interpolation function f(t) of the > uniformly spaced discrete N-periodic data x[n] is given (for n even) by > > f(t) = 1/N ( a_0 + 2 sum_{k=1}^{N/2-1} ( a_k cos(2 pi k / N t) > - b_k sin(2 pi k / N t) ) + a_{N/2} cos(pi t) ), > > where a_k = Re[ X[k] ] and b_k = Im[ X[k] ], and X[k] = DFT[ x[n] ]. > This results in f(n) = x[n], and f(t + N) = f(t) for all t. For odd N, > you can scratch the Nyquist cosine term and sum to (N-1)/2.well, if you have an arbitrary set of N values of x[n] for 0 <= n < N so that x[n+N] = x[n] for all n, when N is even, there is no guarantee that there is no energy in the X[N/2] bin. what do you do with that component? i think split it in half in the only reasonable thing. so, you have your a_k and b_k defined in terms of X[k] which are defined in terms of x[n]. can you come up with an expression for f(t) in terms of x[n]? in that reference to 2001, i think i *did*, and the result was not surprizing for N odd, but a little surprizing for N even. i used superposition and defined x[n] to be 1 for n = 0 (or an integer multiple of N) and zero for all other n. r b-j
Reply by ●November 16, 20062006-11-16
robert bristow-johnson wrote:> Andor wrote: > > > > are you claiming that x(n) = x[n]? > > yes, for n = integer. > > > I tried your formula in a maths > > program, and it seems that x(t) is periodic with period 1, and does not > > at all interpolate x[n] (at any scale). > > it should be periodic with period N.I just saw your mistake. It should be N-1 x(t) = SUM{ x[n] * sin(pi*(t-n))/(N*tan(pi/N*(t-n))) } n=0 (notice how the frequency is divided by N as compared to your formula).> > > The (unique) pi-bandlimited interpolation function f(t) of the > > uniformly spaced discrete N-periodic data x[n] is given (for n even) by > > > > f(t) = 1/N ( a_0 + 2 sum_{k=1}^{N/2-1} ( a_k cos(2 pi k / N t) > > - b_k sin(2 pi k / N t) ) + a_{N/2} cos(pi t) ), > > > > where a_k = Re[ X[k] ] and b_k = Im[ X[k] ], and X[k] = DFT[ x[n] ]. > > This results in f(n) = x[n], and f(t + N) = f(t) for all t. For odd N, > > you can scratch the Nyquist cosine term and sum to (N-1)/2. > > well, if you have an arbitrary set of N values of x[n] for 0 <= n < N > so that > x[n+N] = x[n] for all n, when N is even, there is no guarantee that > there is no energy > in the X[N/2] bin. what do you do with that component? i think split > it in half in the > only reasonable thing.Don't know what you mean.> > so, you have your a_k and b_k defined in terms of X[k] which are > defined in terms of x[n]. can you come up with an expression for f(t) > in terms of x[n]?That's not too hard. Just insert the DFT definition for X[k], then factor out the whole kasunkle and you get (for N even) f(t) = 1/N sum_{n=0}^{N-1} ce_{N,n}(t) x[n], where ce_{N,n}(t) is the periodic interpolation kernel for even N, given by ce_{N,n}(t) = 1 - cos(pi n) cos(pi t) + 2 sum_{k=1}^{N/2} cos(2 pi n k/N) cos(2 pi k / N t) + sin(2 pi n k / N) sin(2 pi k / N t) = 1 - cos(pi n) cos(pi t) + 2 sum_{k=1}^{N/2} cos(2 pi k/N (n-t)) = D_{N/2}(2 pi (n-t) / N) - cos(pi (n-t), where D_M(x) is the Dirichlet kernel, ie. D_M(x) = sin( (M+1/2) x) / sin(x/2).> in that reference to 2001, i think i *did*, and the > result was not surprizing for N odd, but a little surprizing for N > even. i used superposition and defined x[n] to be 1 for n = 0 (or an > integer multiple of N) and zero for all other n.For N odd I get the interpolation kernel co_{N,n(t) = D_{(N-1)/2}(2 pi (n-t) / N). This is just a consequence, as you said, of the Nyquist term, which is added in for the even case. By the way, both kernels, ce and co, result in a pi-bandlimited, periodic interpolation of the data, if applied naively (ie. without regard to the parity of N). Do you spot the difference of the two interpolation functions (using the even and the odd kernel)? Regards, Andor
Andor wrote:> robert bristow-johnson wrote: > > > Andor wrote: > > > > > > are you claiming that x(n) = x[n]? > > > > yes, for n = integer. > > > > > I tried your formula in a maths > > > program, and it seems that x(t) is periodic with period 1, and does not > > > at all interpolate x[n] (at any scale). > > > > it should be periodic with period N. > > I just saw your mistake. It should be > > N-1 > x(t) = SUM{ x[n] * sin(pi*(t-n))/(N*tan(pi/N*(t-n))) } > n=0 > > (notice how the frequency is divided by N as compared to your formula).i'm happy to have mistakes pointed out (and i confess that i don't understand this as throroughly as i think i should) but i don't see how that is different from either formulae i put in this thread or in the 2001 thread. for N even, that's the result i have, Andor.> > > The (unique) pi-bandlimited interpolation function f(t) of the > > > uniformly spaced discrete N-periodic data x[n] is given (for n even) by > > > > > > f(t) = 1/N ( a_0 + 2 sum_{k=1}^{N/2-1} ( a_k cos(2 pi k / N t) > > > - b_k sin(2 pi k / N t) ) + a_{N/2} cos(pi t) ), > > > > > > where a_k = Re[ X[k] ] and b_k = Im[ X[k] ], and X[k] = DFT[ x[n] ]. > > > This results in f(n) = x[n], and f(t + N) = f(t) for all t. For odd N, > > > you can scratch the Nyquist cosine term and sum to (N-1)/2. > > > > well, if you have an arbitrary set of N values of x[n] for 0 <= n < N > > so that x[n+N] = x[n] for all n, when N is even, there is no guarantee > > that there is no energy in the X[N/2] bin. what do you do with that > > component? i think split it in half in the only reasonable thing. > > Don't know what you mean.i'm saying that, in general for the problem of bandlimited reconstruction of a periodic discrete-time function (or "sequence") that, for N even, we cannot count on there being no energy in the Nyquist bin, X[N/2]. indeed for the "special case" of { 1 for n = m*N m = integer x[n] = { { 0 otherwise all X[k] = 1, including X[N/2]. so then, when creating a real continuous-time function (assume the sampling time T = 1 so that x(n) = x[n] for integer n), how do we construct that real c-t function? we know X[0]/N is the DC component, and for 1 <= k <= N/2 - 1, we know that X[N-k] are the negative frequency components, X[k] are positive frequency, and (if x[n] is real, then these are complex conj) they combine to real sinusoidal components that we can add up. what do we do with X[N/2] (which does not exist for N odd)? i think the only reasonable thing to do is split it in half and put half of the amplitude at a frequency of -(N/2)/N and the other at +(N/2)/N. what other reasonable thing can we do with that component?> > > > so, you have your a_k and b_k defined in terms of X[k] which are > > defined in terms of x[n]. can you come up with an expression for f(t) > > in terms of x[n]? > > That's not too hard. Just insert the DFT definition for X[k], then > factor out the whole kasunkle and you get (for N even) > > f(t) = 1/N sum_{n=0}^{N-1} ce_{N,n}(t) x[n], > > where ce_{N,n}(t) is the periodic interpolation kernel for even N, > given by > > ce_{N,n}(t) = 1 - cos(pi n) cos(pi t) + 2 sum_{k=1}^{N/2} cos(2 pi n > k/N) cos(2 pi k / N t) + sin(2 pi n k / N) sin(2 pi k / N t) > = 1 - cos(pi n) cos(pi t) + 2 sum_{k=1}^{N/2} cos(2 pi k/N (n-t)) > = D_{N/2}(2 pi (n-t) / N) - cos(pi (n-t), > > where D_M(x) is the Dirichlet kernel, ie. > > D_M(x) = sin( (M+1/2) x) / sin(x/2). > > > in that reference to 2001, i think i *did*, and the > > result was not surprizing for N odd, but a little surprizing for N > > even. i used superposition and defined x[n] to be 1 for n = 0 (or an > > integer multiple of N) and zero for all other n. > > For N odd I get the interpolation kernel > > co_{N,n(t) = D_{(N-1)/2}(2 pi (n-t) / N). > > This is just a consequence, as you said, of the Nyquist term, which is > added in for the even case. By the way, both kernels, ce and co, result > in a pi-bandlimited, periodic interpolation of the data, if applied > naively (ie. without regard to the parity of N). Do you spot the > difference of the two interpolation functions (using the even and the > odd kernel)?there is clearly a difference. the N odd case, it looks just like Dirichlet. for the N even case, there is a tan() function in the denominator instead of a sin() function. but what makes this curious is that in application of the Dirichlet kernal to DFT bin case, it sin() in the denominator for any integer N, even or odd. that difference in form is the curiousity i don't yet have my head wrapped around. r b-j
robert bristow-johnson wrote:> Ron N. wrote: > > > If the signal is strongly bandlimited, then there is no content in the N/2 bin. > > let's say we don't know how strongly bandlimited it was originally, > except there was nothing above Nyquist. maybe *some* energy at > Nyquist. > > > If the signal is weakly bandlimited, then N has to approach infinity for > > the N/2 bin to determine the content at that frequency. > > i don't really get that at all. N is fixed.If there is any content in the N/2 bin, is the energy at the exact Nyquist frequency determinate? Wouldn't any amplitude of sinusoid at the Nyquist frequency produce alternating sign samples of any equal or lower amplitude at the sample rate for some phase? IMHO. YMMV. -- rhn A.T nicholson d.0.t C-o-M
Ron N. wrote:> robert bristow-johnson wrote: >> Ron N. wrote: >> >>> If the signal is strongly bandlimited, then there is no content in the N/2 bin. >> let's say we don't know how strongly bandlimited it was originally, >> except there was nothing above Nyquist. maybe *some* energy at >> Nyquist. >> >>> If the signal is weakly bandlimited, then N has to approach infinity for >>> the N/2 bin to determine the content at that frequency. >> i don't really get that at all. N is fixed. > > If there is any content in the N/2 bin, is the energy at the exact > Nyquist frequency determinate? Wouldn't any amplitude of > sinusoid at the Nyquist frequency produce alternating sign > samples of any equal or lower amplitude at the sample rate > for some phase?Of course. What's more, if it the signal isn't strictly bandlimited and sampled for at least k/(2Fs-Fmax) (k~=1) it can be only approximately reconstructed. The exercise is academic, but interesting nonetheless. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Jerry Avins wrote:> > Of course. What's more, if it the signal isn't strictly bandlimited and > sampled for at least k/(2Fs-Fmax) (k~=1) it can be only approximately > reconstructed. The exercise is academic, but interesting nonetheless.i don't think it's ***purely*** academic (oh, maybe it is). but this bandlimited reconstruction of periodic discrete-time data is a well-defined problem: assuming your discrete-time periodic function is: { 1 for n = m*N where m = any integer x[n] = { { 0 otherwise (there is no loss of generality if you understand this animal to be linear and time-invariant.) assuming the sampling period to be 1, the straight-forward reconstruction formula is +inf x(t) = SUM{ sinc(t - m*N) } m=-inf it's clear that when t = n = integer, that x(t) = x[n]. we can manipulate it to be: +inf x(t) = sin(pi*t) * SUM{ ((-1)^(m*N))/(pi*(t - m*N)) } m=-inf from that you can see that the (-1)^(m*N) factor toggles with m for odd N and does not toggle for even N. but from knowledge that the DFT of that periodic sequence is X[k] = 1 for all k, we can get for N odd: x(t) = sin(pi*t)/(N*sin(pi*t/N)) N odd but for even N you get, if you split the X[N/2] into two, one for postive and the other for negative frequency, x(t) = sin(pi*t)/(N*tan(pi*t/N)) N even
robert bristow-johnson wrote:> Jerry Avins wrote: >> Of course. What's more, if it the signal isn't strictly bandlimited and >> sampled for at least k/(2Fs-Fmax) (k~=1) it can be only approximately >> reconstructed. The exercise is academic, but interesting nonetheless. > > i don't think it's ***purely*** academic (oh, maybe it is). but this > bandlimited reconstruction of periodic discrete-time data is a > well-defined problem: > > assuming your discrete-time periodic function is: > > { 1 for n = m*N where m = any integer > x[n] = { > { 0 otherwise > > (there is no loss of generality if you understand this animal to be > linear and time-invariant.) > > assuming the sampling period to be 1, the straight-forward > reconstruction formula is > > +inf > x(t) = SUM{ sinc(t - m*N) } > m=-inf > > it's clear that when t = n = integer, that x(t) = x[n]. we can > manipulate it to be: > > +inf > x(t) = sin(pi*t) * SUM{ ((-1)^(m*N))/(pi*(t - m*N)) } > m=-inf > > from that you can see that the (-1)^(m*N) factor toggles with m for odd > N and does not toggle for even N. > > but from knowledge that the DFT of that periodic sequence is X[k] = 1 > for all k, we can get for N odd: > > x(t) = sin(pi*t)/(N*sin(pi*t/N)) N odd > > but for even N you get, if you split the X[N/2] into two, one for > postive and the other for negative frequency, > > x(t) = sin(pi*t)/(N*tan(pi*t/N)) N evenYou already pointed that out. I find it interesting to the point of being astounding; I certainly wouldn't have guessed it. Nevertheless, any energy in the last bin violates the Fs/2 > Fmax requirement for exact reconstruction, which is what I meant when I called the exercise academic. Look: I can derive a formula for the flexure of a beam that's accurate enough so measurement can't disprove it. (I claim no credit; it's in the textbooks.) But it must be wrong because somewhere along the development is the implicit assumption that the beam doesn't flex. (Specifically, that cross sections of the beam remain parallel through the analysis.) Engineering is like that. It doesn't bother me, but it probably drives my mathematically minded colleagues crazy. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
