robert bristow-johnson wrote:> Andor wrote:..> > I just saw your mistake. It should be > > > > N-1 > > x(t) = SUM{ x[n] * sin(pi*(t-n))/(N*tan(pi/N*(t-n))) } > > n=0 > > > > (notice how the frequency is divided by N as compared to your formula). > > i'm happy to have mistakes pointed out (and i confess that i don't > understand this as throroughly as i think i should) but i don't see how > that is different from either formulae i put in this thread or in the > 2001 thread. for N even, that's the result i have, Andor.No, you posted:> N-1 > x(t) = SUM{ x[n] * sin(N*pi*(t-n))/(N*tan(pi*(t-n))) } > n=0> x(t+N) = x(t)I told you where to look for the difference. It may be minor, but it was enough not to get your interpolation formula to work when I tried. ...> > That's not too hard. Just insert the DFT definition for X[k], then > > factor out the whole kasunkle and you get (for N even) > > > > f(t) = 1/N sum_{n=0}^{N-1} ce_{N,n}(t) x[n], > > > > where ce_{N,n}(t) is the periodic interpolation kernel for even N, > > given by > > > > ce_{N,n}(t) = 1 - cos(pi n) cos(pi t) + 2 sum_{k=1}^{N/2} cos(2 pi n > > k/N) cos(2 pi k / N t) + sin(2 pi n k / N) sin(2 pi k / N t) > > = 1 - cos(pi n) cos(pi t) + 2 sum_{k=1}^{N/2} cos(2 pi k/N (n-t)) > > = D_{N/2}(2 pi (n-t) / N) - cos(pi (n-t), > > > > where D_M(x) is the Dirichlet kernel, ie. > > > > D_M(x) = sin( (M+1/2) x) / sin(x/2). > > > > > in that reference to 2001, i think i *did*, and the > > > result was not surprizing for N odd, but a little surprizing for N > > > even. i used superposition and defined x[n] to be 1 for n = 0 (or an > > > integer multiple of N) and zero for all other n. > > > > For N odd I get the interpolation kernel > > > > co_{N,n(t) = D_{(N-1)/2}(2 pi (n-t) / N). > > > > This is just a consequence, as you said, of the Nyquist term, which is > > added in for the even case. By the way, both kernels, ce and co, result > > in a pi-bandlimited, periodic interpolation of the data, if applied > > naively (ie. without regard to the parity of N). Do you spot the > > difference of the two interpolation functions (using the even and the > > odd kernel)? > > there is clearly a difference. the N odd case, it looks just like > Dirichlet. for the N even case, there is a tan() function in the > denominator instead of a sin() function. but what makes this curious > is that in application of the Dirichlet kernal to DFT bin case, it > sin() in the denominator for any integer N, even or odd. that > difference in form is the curiousity i don't yet have my head wrapped > around.What do you mean by the "application of the Dirichlet kernal to DFT bin case, ..., N even or odd" ? What I was getting at is that if you take the kernel ce for even N and you interpolate a an odd number of discrete points with it, you get an anti-symmetric (about N) interpolation function. The same happens when you take the odd kernel for even number of data points. Regards, Andor
FFT Algorithm and Time
Started by ●November 11, 2006
Reply by ●November 17, 20062006-11-17
Andor wrote:> robert bristow-johnson wrote: > > > Andor wrote: > .. > > > I just saw your mistake. It should be > > > > > > N-1 > > > x(t) = SUM{ x[n] * sin(pi*(t-n))/(N*tan(pi/N*(t-n))) } > > > n=0 > > > > > > (notice how the frequency is divided by N as compared to your formula). > > > > i'm happy to have mistakes pointed out (and i confess that i don't > > understand this as throroughly as i think i should) but i don't see how > > that is different from either formulae i put in this thread or in the > > 2001 thread. for N even, that's the result i have, Andor. > > No, you posted: > > > N-1 > > x(t) = SUM{ x[n] * sin(N*pi*(t-n))/(N*tan(pi*(t-n))) } > > n=0 > > > > x(t+N) = x(t)you're right. in the Nov 14 post i had the scaling of the argument bumped up by a factor of N. i didn't even realize that. previous and later posts, i think i had the scaling correct.> I told you where to look for the difference.i was looking at other posts. more current in this thread and earlier in 2001. it was a "typo" that i hadn't even been aware of.> It may be minor, but it > was enough not to get your interpolation formula to work when I tried.cause it was scaled wrong. how did it work with the proper scaling? ...> > there is clearly a difference. the N odd case, it looks just like > > Dirichlet. for the N even case, there is a tan() function in the > > denominator instead of a sin() function. but what makes this curious > > is that in application of the Dirichlet kernal to DFT bin case, it > > sin() in the denominator for any integer N, even or odd. that > > difference in form is the curiousity i don't yet have my head wrapped > > around. > > What do you mean by the "application of the Dirichlet kernal to DFT bin > case, ..., N even or odd" ?if you assume the DFT to be a discrete-frequency uniform sampling of the output of the DTFT of the same input x[n] (except, for the DTFT, this x[n] is *zero* extended, not periodically extended), the continuous-frequency DTFT X(e^jw) can be related to the DFT output X[k] with this relationship: N-1 X(e^(jw)) = SUM{ X[k] * sin(pi*(N*w/(2*pi)-k)/(N*sin(pi/N*(N*w/(2*pi)-k))) } k=0 ("t" becomes N*w/(2*pi)) and it's a sin() in the denominator (not tan()) whether N is even or odd. that is at least a bit curious to me.> What I was getting at is that if you take the kernel ce for even N and > you interpolate a an odd number of discrete points with it, you get an > anti-symmetric (about N) interpolation function. The same happens when > you take the odd kernel for even number of data points.i don't quite understand what you mean here and i dunno exactly how to ask a clarifying question. r b-j
Reply by ●November 29, 20062006-11-29
remember this, guys?: robert bristow-johnson wrote:> given a perfectly periodic sequence, x[n] such that > > x[n+N] = x[n] for all n. > > so if you know one period, say > > x[n] for 0 <= n < N > > then you have a complete definition for x[n] for all n. correct? > > so, if we were to reconstruct out of those real samples a > continuous-time periodic signal, x(t) (let's assume the sampling period > to be 1, with no loss of generality) so that x(t-N) = x(t) for all t, > how is the function defined in terms of the finite set of samples x[0], > x[1], ... x[N-1] that fully define the periodic sequence and, these > discrete sequence should be able to fully define the continuous-time > signal it was sampled from (assuming appropriate bandlimiting, which we > are pushing the envelope a little). now, usually, we think of the > ideal interpolation formula for x(t) is: > > +inf > x(t) = SUM{ x[n] * sinc(t - n) } > n=-inf > > N-1 +inf > = SUM{ SUM{ x[n+m*N] * sinc(t - (n+m*N)) } } > n=0 m=-inf > > but since x[n+m*N] = x[n] for any integer m, then > > > N-1 +inf > x(t) = SUM{ SUM{ x[n] * sinc(t - (n+m*N)) } } > n=0 m=-inf > > N-1 +inf > = SUM{ x[n] * SUM{ sinc(t - n - m*N) } } > n=0 m=-inf > > N-1 > = SUM{ x[n] * h(t-n) } > n=0 > > now this interpolation function, > > +inf > h(t) = SUM{ sinc(t - m*N) } } > m=-inf > > is periodic with period N, h(t+N) = h(t) for all t, as we expect. so > what does that periodic interpolation function look like? i've > pondered this a while and first posted this to comp.dsp in 2001: > > http://groups.google.com/group/comp.dsp/msg/2cbabcc52d43399c?fwc=1 > > thread: > http://groups.google.com/group/comp.dsp/browse_thread/thread/44a63e8177ff7365/2cbabcc52d43399c?#2cbabcc52d43399c > > take a look at that. Adrian Hey got into it enough to see the thing > that was bothering me a little. anyway, the result i get for a closed > for periodic h(t) is > > { sin(pi*t)/(N*sin(pi*t/N)) N odd > h(t) = { > { sin(pi*t)/(N*tan(pi*t/N)) N even > > from above you get show > > +inf > h(t) = SUM{ sin(pi*(t - m*N))/(pi*(t - m*N)) } } > m=-inf > > +inf > = sin(pi*t) * SUM{ 1/(pi*(t - m*N)) } } N even > m=-inf > > +inf > = sin(pi*t) * SUM{ ((-1)^m)/(pi*(t - m*N)) } } N odd > m=-inf > > > > I'm not sure if there is a significant difference in the two reconstruction > > formulas for N and N+1 as N approaches infinity. Thoughts? > > i just don't want to make that assumption and equality holds exactly > for the two cases, even and odd. one case the formula looks just like > the Dirichlet interpolation commonly done for the FFT and the other, > it's slightly different, but it *is* different. in the even case, the > tails of those sinc() functions have bumps of opposite polarity so they > cancel themselves out more than in the odd case where the tails, though > descreasing in amplitude as 1/x, have their bumps of the same polarity, > so they team up. so i'm pretty sure the formula is correct (the > 1/tan() reduces the amplitude more than the 1/sin() as one approaches > midway between the two main pulses. it also came up (indirectly) with > tthese two mathematical identities: > > +inf > 1/tan(t) = SUM{ 1/(t - m*pi) } > m=-inf > > +inf > 1/sin(t) = SUM{ ((-1)^m)/(t - m*pi) } > m=-inf > > which i have not been able to prove directly. > > if someone has it, i would like some insight for why the Dirichlet > formula applies exactly only for N odd, not exactly for N even, > although it applies exactly for both N odd or N even in the case of > interpolating DFT output to get the DTFT of the time-limited x[n]. > > do you guys see what it is that is bothering me? or proving more > directly the two math identities above would be gratifying. i have not > been able to do that directly, as of yet.well, i suspected that this was scooped by someone else, but i didn't expect so recently: T. Schanze, "Sinc interpolation of discrete periodic signals", IEEE Transactions on Signal Processing, vol. 43, pp. 1502-1503, June 1995. i don't get IEEE, but if someone who has free access to the pdf file wants to email it to me, i would not complain. (screw IEEE.) anyway there is a free pdf of some comments about this at: http://iul.eng.fiu.edu/candocia/Publications/candocia_sp.pdf and they get the same results as me. dunno how the methods differ, if they do. just FYI, r b-j
