Who, me? Jerry Jon Harris wrote:> Works for me, but interestingly gives the exact same definition that the OP's > first post listed: > > >>>My mother-tongue isn't English. What does it mean "transient" in music >>>signal processing world? I have found physics meaning: transient - (physics) >>>a short-lived oscillation in a system caused by a sudden change of voltage >>>or current or load >>> >>>Best Regards, >>>Andrzej > > > So it's not too helpful since the OP already knows that! > > "Jerry Avins" <jya@ieee.org> wrote in message > news:40c5bc62$0$2921$61fed72c@news.rcn.com... > >>Stephan M. Bernsee wrote: >> >> >>>http://www.hyperdictionary.com/dictionary/transient >>> >>>--smb >> >>Sorry: "www.hyperdictionary.com cannot be found" >> >>Jerry
transient
Started by ●June 7, 2004
Reply by ●June 8, 20042004-06-08
Reply by ●June 9, 20042004-06-09
I realized that soon after I posted it, so I posted again explaining in more detail. I will be more observant in the future. --smb "Jon Harris" <goldentully@hotmail.com> wrote:> Works for me, but interestingly gives the exact same definition that the OP's > first post listed: > > So it's not too helpful since the OP already knows that!
"Jon Harris" <goldentully@hotmail.com> wrote:> Well transients are usually the things that don't show up in standard frequency > analysis!Well, actually they do! It's just that the "standard frequency analysis" (I assume you're talking about the Fourier transform here?) isn't very good at representing them in a manner that makes them easy to see in a spectrogram. Their energy contributes to many of the DFT bins which is why they appear as a "smear" across the frequency axis.> They are usually the "starts" and "stops" of signals, or in musical > terms, the attack and release.I'm not sure if the release phase really qualifies to be a transient. Usually, it's quite long (compared to the attack) and generally contains relatively steady-state partials. Even for drums, the release phase contains the decaying resonances of the instrument, which are often quite periodic. But maybe we disagree on the term release here: I consider "release" to be the decaying output that is observed after I stop providing energy to the excitation mechanism of the instrument. I don't think that actively stopping the instrument as you suggest (by muting the strings of a guitar with your hand) can be called a "release phase".> It's called Spectral view in CoolEdit, or sometimes I think it is > called a voice print.I think a "voice print" is something else, more like a long term spectrum of a voice to identify (or verify) the speaker of a message in the context of security. --smb
"Stephan M. Bernsee" <stephan.bernsee@web.de> wrote in message news:38ab652c.0406082215.6da4a187@posting.google.com...> "Jon Harris" <goldentully@hotmail.com> wrote: > > Well transients are usually the things that don't show up in standardfrequency> > analysis! > > Well, actually they do! It's just that the "standard frequency > analysis" (I assume you're talking about the Fourier transform here?) > isn't very good at representing them in a manner that makes them easy > to see in a spectrogram. Their energy contributes to many of the DFT > bins which is why they appear as a "smear" across the frequency axis.Yes, that is what I meant. Good clarification.> > They are usually the "starts" and "stops" of signals, or in musical > > terms, the attack and release. > > I'm not sure if the release phase really qualifies to be a transient. > Usually, it's quite long (compared to the attack) and generally > contains relatively steady-state partials. Even for drums, the release > phase contains the decaying resonances of the instrument, which are > often quite periodic. > > But maybe we disagree on the term release here: I consider "release" > to be the decaying output that is observed after I stop providing > energy to the excitation mechanism of the instrument. I don't think > that actively stopping the instrument as you suggest (by muting the > strings of a guitar with your hand) can be called a "release phase".Some instruments have a "transient" or percussive release. I think some electric organs have a "click" on release. You are correct that many instruments have a slowly decaying release, but for some I would call this a transient. I'm not sure why actively stopping an instrument wouldn't be considered the release phase. Many instruments are actively stopped. Back in the days of the ADSR (attack decay sustain release) model, I thought the whole point of the release phase was to model releases that ranged from fairly slow decays to very abrupt (transient) cut-offs.> > It's called Spectral view in CoolEdit, or sometimes I think it is > > called a voice print. > > I think a "voice print" is something else, more like a long term > spectrum of a voice to identify (or verify) the speaker of a message > in the context of security.You are probably right about this. Is there a common name for a color-coded spectrum plot like is used in CoolEdit (takes short term FFTs, horizontal axis represents time, vertical axis represents frequency, color represents intensity of that frequency)?
Reply by ●June 10, 20042004-06-10
"Jon Harris" <goldentully@hotmail.com> wrote:> Some instruments have a "transient" or percussive release. I think some > electric organs have a "click" on release. .... Many instruments are actively > stopped.I see your point, although I can't think of many instruments where this would apply. The only example that I can think of right now is an electric organ and probably a harpsichord. Most instruments have a relatively slow release and are not actively stopped. Even for woodwind instruments the air column continues to oscillate for a few cycles before the resonance finally breaks down. But I agree, an abrupt release would also produce a transient.> You are probably right about this. Is there a common name for a color-coded > spectrum plot like is used in CoolEdit (takes short term FFTs, horizontal axis > represents time, vertical axis represents frequency, color represents intensity > of that frequency)?The trouble is I can't use Cooledit since I'm primarily on the Mac, so I don't know what kind of display this is. I would guess from your description that it's a spectrogram. --smb
Stephan M. Bernsee wrote: ...> I see your point, although I can't think of many instruments where > this would apply. The only example that I can think of right now is an > electric organ and probably a harpsichord. Most instruments have a > relatively slow release and are not actively stopped. Even for > woodwind instruments the air column continues to oscillate for a few > cycles before the resonance finally breaks down.Piano, when the damper is applied. Kettle drum when stopped by hand. Cymbals, when the pedal is released. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
"Stephan M. Bernsee" <stephan.bernsee@web.de> wrote in message news:38ab652c.0406100016.5c16326a@posting.google.com...> "Jon Harris" <goldentully@hotmail.com> wrote:> > You are probably right about this. Is there a common name for a color-coded > > spectrum plot like is used in CoolEdit (takes short term FFTs, horizontalaxis> > represents time, vertical axis represents frequency, color representsintensity> > of that frequency)? > > The trouble is I can't use Cooledit since I'm primarily on the Mac, so > I don't know what kind of display this is. I would guess from your > description that it's a spectrogram.That sounds right. FYI, here are a couple of web sites that have screen shots of CoolEdit's Spectral view: http://www.worlditc.org/k_03_filtering_of_voices.htm http://kerouac.pharm.uky.edu/seti/experiments/cool_doppler/Cool_doppler.htm
Reply by ●June 11, 20042004-06-11
"Jon Harris" wrote:> That sounds right. FYI, here are a couple of web sites that have screen shots > of CoolEdit's Spectral view: > http://www.worlditc.org/k_03_filtering_of_voices.htm > http://kerouac.pharm.uky.edu/seti/experiments/cool_doppler/Cool_doppler.htmyes that definitely looks like a spectrogram display. --smb
Yes Jerry, but that wasn't my point. Of course you can actively stop almost *any* instrument, in which case you might get an additional transient (since you're actually "hitting" the instrument again, this could even be seen as a new attack phase!). I was talking about the natural release phase of instruments, usually it does not involve any action other than stopping the excitation. --smb Jerry Avins <jya@ieee.org> wrote in message news:<40c89433$0$3032$61fed72c@news.rcn.com>...> Stephan M. Bernsee wrote: > > ... > > > I see your point, although I can't think of many instruments where > > this would apply. The only example that I can think of right now is an > > electric organ and probably a harpsichord. Most instruments have a > > relatively slow release and are not actively stopped. Even for > > woodwind instruments the air column continues to oscillate for a few > > cycles before the resonance finally breaks down. > > Piano, when the damper is applied. Kettle drum when stopped by hand. > Cymbals, when the pedal is released. > > Jerry
Stephan M. Bernsee wrote:> Yes Jerry, but that wasn't my point. Of course you can actively stop > almost *any* instrument, in which case you might get an additional > transient (since you're actually "hitting" the instrument again, this > could even be seen as a new attack phase!). I was talking about the > natural release phase of instruments, usually it does not involve any > action other than stopping the excitation. > > --smbBut Stephan, That is how a piano is normally played. It's the sound we've come to expect. Whether it's best thought of an ending transient or a new attack would be an interesting discussion over a glass of beer. Of course, pianos have sustain pedals, but releasing the pedal damps many notes simultaneously. Even guitar and viol strings are rarely allowed to decay completely before the next notes on them are played. Consider even a trill on a flute. There is only one air column, so one note must stop as abruptly as the other note starts. Jerry> Jerry Avins <jya@ieee.org> wrote in message news:<40c89433$0$3032$61fed72c@news.rcn.com>... > >>Stephan M. Bernsee wrote: >> >> ... >> >> >>>I see your point, although I can't think of many instruments where >>>this would apply. The only example that I can think of right now is an >>>electric organ and probably a harpsichord. Most instruments have a >>>relatively slow release and are not actively stopped. Even for >>>woodwind instruments the air column continues to oscillate for a few >>>cycles before the resonance finally breaks down. >> >>Piano, when the damper is applied. Kettle drum when stopped by hand. >>Cymbals, when the pedal is released. >> >>Jerry
