I need a image processing system to perform various autonomous machine vision applications. A PC (or Laptop) is one alternative but I was wondering what else is available. As it's a research project cost is an issue.
Image processing systems
Started by ●June 4, 2004
Reply by ●June 5, 20042004-06-05
gford9163@yahoo.co.uk (Gary Ford) wrote in message news:<9052b1e1.0406040401.55e81dc@posting.google.com>...> I need a image processing system to perform various autonomous machine > vision applications. A PC (or Laptop) is one alternative but I was > wondering what else is available. As it's a research project cost is > an issue.You may wish to consider the DSKcam from BiTEC Ltd. It provides VGA resolution at 30fps. It can be run off a C6416DSK from Spectrum Digital which is a 720Mhz, 6,000MIPS DSP designed for image processing. It is also well suited for stand alone as the board only consumes around 2 Watts. You can get more information at www.BiTEC.Ltd.uk. Regards
Reply by ●June 6, 20042004-06-06
gford9163@yahoo.co.uk (Gary Ford) writes:> I need a image processing system to perform various autonomous machine > vision applications. A PC (or Laptop) is one alternative but I was > wondering what else is available. As it's a research project cost is > an issue.The e-Vision tools from euresys are quite good: http://www.euresys.com/Products/softwaretools/evision.asp Ciao, Peter K. -- Peter J. Kootsookos "I will ignore all ideas for new works [..], the invention of which has reached its limits and for whose improvement I see no further hope." - Julius Frontinus, c. AD 84
