Hi, I have a load of mass spec (maldi-tof) data that I need some help working with. At any time index t, there is a corresponding mass as determined by the coefficients from a quadratic. I would like to try to maximize my correlation by convolving my actual spectra with the expected signals. The problem is that I dont know how to adjust my coefficients in a coordinated fashion with my convolution to ensure that I get the best possible coefficients possible. Currently, I use a simplex method to bump my coeffs around and at each simplex step use a levenberg-marquardt fit until to test the correlation, or fit of the data sets. This seems to work alright, but local maxima are a problem since they may be many signals, as well as the time taken to iterate through the simplex algorithm. I am basically using the simplex to zone in on the coeffs, and convolving/correlation as a test to identify best fits. I am not a math guy nor a dsp guy, Im just a software engineer trying to fix a problem with our expected signals not matching our detected signals because our coefficients are off. Can anyone offer any alternative approaches to this problem? Suggestions? Critiques? Thanks, Bryan
Convolution, correlation and maximization
Started by ●January 26, 2007
