Hi All, I need your help in order to find a solution at the following problem: I need to change the sampling rate of a signal from the original 10ksample per sconds to 10.2 ksps. I should to do this without oversampling and decimation...which other possibilities I have? Ther is a rule that I should apply in all the case where the starting frequency and the final frequency are very close? thanks a lot bye bye michele
changing sampling rate from 10Ksps to 10.8ksps
Started by ●January 26, 2007
Reply by ●January 26, 20072007-01-26
Michele wrote:> Hi All, > > I need your help in order to find a solution at the following problem: > I need to change the sampling rate of a signal from the original 10ksample > per sconds to 10.2 ksps. > I should to do this without oversampling and decimation...which other > possibilities I have? > Ther is a rule that I should apply in all the case where the starting > frequency and the final frequency are very close? > > thanks a lot > > bye bye > > michele > >Search for "poly phase filter" -- it should help. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Posting from Google? See http://cfaj.freeshell.org/google/ "Applied Control Theory for Embedded Systems" came out in April. See details at http://www.wescottdesign.com/actfes/actfes.html
