Hello, Talking about video codecs, specifically Theora (www.theora.org) and M-JPEG2000, how do they compare in terms of compression ratio for a given quality? Being M-JPEG2000 based on still pictures and not taking advantage of interframe redundancies (from the very few I have read so far), is it viable for networking and storage applications? Kindest regards, JaaC -- Posted via a free Usenet account from http://www.teranews.com
Theora vs. M-JPEG2000
Started by ●February 18, 2007
Reply by ●February 21, 20072007-02-21
On 18 Feb, 23:18, Jaime Andres Aranguren Cardona <j...@nospam- sanjaac.com> wrote:> Hello, > > Talking about video codecs, specifically Theora (www.theora.org) and > M-JPEG2000, how do they compare in terms of compression ratio for a given > quality?Well, I've seen discussions that suggest JPEG2000 can compare favourably with MPEG-4, and also others that suggest there's not a lot to choose between Theora and MPEG-4. The discussions are usually talking about quality for specified ratio, but that typically works out similar.> Being M-JPEG2000 based on still pictures and not taking advantage of > interframe redundancies (from the very few I have read so far), is it > viable for networking and storage applications?Given that MJPEG was clearly viable, I see no reason why not. It's also possible to trivially create a variant that takes some advantage of interframe redundancies by encoding an image that's subtracted from the previous frame (as it appears after running back through the decoder, not the original frame). I did that with JPEG once and the results were reasonably good.
