On Mar 15, 8:06 pm, "Dave" <Confused.Scient...@gmail.com> wrote:> Hello all, > > I am confused about how zero-filling / windowing a signal alters its > information content and I'm hoping someone here can help. > > I have a continuous signal (time domain) and I Fourier transform it to > get a band-limited spectrum (frequency domain). From Shannon & > Weaver, I can compute the information content of the time domain > signal from the signal variance and, given the linearity of a DFT, I > expect the information content of the frequency domain signal is the > same. > > The DFT code that I have has the option of zero-filling/zero-padding > the original signal as a means of interpolating in the frequency > domain. This doesn't change the location/frequency of the peaks in > the spectrum but does make it easier to accurately locate the maximum > of each peak. So, does zero-filling/zero-padding change the > information content of the signal?It certainly doesn't add information. Zero padding in the frequency domain is identical to sinc interpolation in the time domain. The result is just a bunch of weighted averages of the existing information content in your original signal vector (minus rounding/quantization noise). Windowing might destroy information, especially if any portion of the window is zero, or small relative to the quantization level. IMHO. YMMV. -- rhn A.T nicholson d.0.t C-o-M
Zero padding and the Shannon information content
Started by ●March 16, 2007
Reply by ●March 16, 20072007-03-16
