Hi, I've been reading quite a bit about oversampling and it's apparent use in noise reduction, but haven't been able to tie everything together. As I probably can't explain my exact question clearly, I'll give an example, I have a Analog Devices evaluation board with a 1MSPS A/D with CPU hooked up to a gryo. The gyro has a raw BW of 1000Hz, I have a single pole filter at 50Hz between it and the A/D (hooked up per the datasheet). I am sampling at 10X 50hz, or 500 Hz, since the single pole filter is not great. The datasheet indicates that the gryo noise is white Gaussian and I am seeing it as +/- 4 counts on the A/D, which agrees with the datasheet estimate with a 50Hz filter. So my attempt here is to use oversampling to bring the noise down, I oversample at 4x,16x,32x, up to 256x and average the samples (every 500hz, or 2 mS). But I see no reduction in noise, still +/- 4 counts, no matter what. Well, thinking about it for a moment I realize that the data probably doesn't change much over a 2mS period (i.e., the noise is slow), it's just averaging the same number 256 times. Ok, so the only way to get around this is to add higher frequency noise, which I can do by relaxing the output filter, I do this and the oversampling now brings down the noise, but, and here is the rub, when I relax the filter the overall noise increases, so the net result is I have the same noise as I did in the beginning :( Now I can average multiple 2mS samples over a second to bring the noise down, but this obviously reduces the BW, which I don't want, and that is what I consider a normal filter, not oversampling. So the question is, how can I use oversampling to reduce noise without signal loss? Or maybe I can't, that oversampling doesn't do what I think it does. It did reduce my external filtering requirements, I can see that, but I don't see any noise reduction capabilities without loss of signal content. thanks for any help! steve
Oversampling for noise reduction
Started by ●March 16, 2007
Reply by ●March 16, 20072007-03-16
"stevepierson" <gkicomputers@yahoo.com> wrote in news:1174063927.072728.4880@y80g2000hsf.googlegroups.com:> Hi, > I've been reading quite a bit about oversampling and it's apparent use > in noise reduction, but haven't been able to tie everything together. > As I probably can't explain my exact question clearly, I'll give an > example, I have a Analog Devices evaluation board with a 1MSPS A/D > with CPU hooked up to a gryo. The gyro has a raw BW of 1000Hz, I have > a single pole filter at 50Hz between it and the A/D (hooked up per the > datasheet). I am sampling at 10X 50hz, or 500 Hz, since the single > pole filter is not great. The datasheet indicates that the gryo noise > is white Gaussian and I am seeing it as +/- 4 counts on the A/D, which > agrees with the datasheet estimate with a 50Hz filter. > > So my attempt here is to use oversampling to bring the noise down, I > oversample at 4x,16x,32x, up to 256x and average the samples (every > 500hz, or 2 mS). But I see no reduction in noise, still +/- 4 counts, > no matter what. Well, thinking about it for a moment I realize that > the data probably doesn't change much over a 2mS period (i.e., the > noise is slow), it's just averaging the same number 256 times. > > Ok, so the only way to get around this is to add higher frequency > noise, which I can do by relaxing the output filter, I do this and the > oversampling now brings down the noise, but, and here is the rub, when > I relax the filter the overall noise increases, so the net result is I > have the same noise as I did in the beginning :( > > Now I can average multiple 2mS samples over a second to bring the > noise down, but this obviously reduces the BW, which I don't want, and > that is what I consider a normal filter, not oversampling. > > So the question is, how can I use oversampling to reduce noise without > signal loss? Or maybe I can't, that oversampling doesn't do what I > think it does. It did reduce my external filtering requirements, I can > see that, but I don't see any noise reduction capabilities without > loss of signal content. > > thanks for any help! > > steve > >You have to define "oversampling" for us. The way I'm familiar with it, its a valuable tool in signal reconstruction that allows one to accurately reproduce the digitized signal without noise. When you think about it this way, noise present when the data was acquired is considered "signal". Oversampling deals with noise associated with analog playback, not noise that has already been sampled. FWIW, it does this by compressing the recorded info in frequency, allowing the analog output filters to have gentler rolloffs. -- Scott Reverse name to reply
stevepierson wrote:> Hi, > I've been reading quite a bit about oversampling and it's apparent use > in noise reduction, but haven't been able to tie everything together. > As I probably can't explain my exact question clearly, I'll give an > example, I have a Analog Devices evaluation board with a 1MSPS A/D > with CPU hooked up to a gryo. The gyro has a raw BW of 1000Hz, I have > a single pole filter at 50Hz between it and the A/D (hooked up per the > datasheet). I am sampling at 10X 50hz, or 500 Hz, since the single > pole filter is not great. The datasheet indicates that the gryo noise > is white Gaussian and I am seeing it as +/- 4 counts on the A/D, which > agrees with the datasheet estimate with a 50Hz filter. > > So my attempt here is to use oversampling to bring the noise down, I > oversample at 4x,16x,32x, up to 256x and average the samples (every > 500hz, or 2 mS). But I see no reduction in noise, still +/- 4 counts, > no matter what. Well, thinking about it for a moment I realize that > the data probably doesn't change much over a 2mS period (i.e., the > noise is slow), it's just averaging the same number 256 times. > > Ok, so the only way to get around this is to add higher frequency > noise, which I can do by relaxing the output filter, I do this and the > oversampling now brings down the noise, but, and here is the rub, when > I relax the filter the overall noise increases, so the net result is I > have the same noise as I did in the beginning :( > > Now I can average multiple 2mS samples over a second to bring the > noise down, but this obviously reduces the BW, which I don't want, and > that is what I consider a normal filter, not oversampling. > > So the question is, how can I use oversampling to reduce noise without > signal loss? Or maybe I can't, that oversampling doesn't do what I > think it does. It did reduce my external filtering requirements, I can > see that, but I don't see any noise reduction capabilities without > loss of signal content. >ADCs with a high front-end bandwidth and relatively high bit counts have lots of high-frequency noise. This noise tends to be white after sampling, no matter how fast you sample. If you're sampling something slow, then sampling fast and low-pass filtering will average out more of the ADC noise. If you're sampling something with low-frequency noise that swamps out the ADC noise then no amount of post-sampling filtering will help. By the way: you can often make a superior anti-aliasing filter in the sampled-time world. Oversampling at the ADC, then filtering and decimating before you do the rest of your processing, can save you board space and grief with analog filters. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Posting from Google? See http://cfaj.freeshell.org/google/ "Applied Control Theory for Embedded Systems" came out in April. See details at http://www.wescottdesign.com/actfes/actfes.html
stevepierson wrote: [...]> I've been reading quite a bit about oversampling and it's apparent use > in noise reduction, but haven't been able to tie everything together.Oversampling can help you in the following: 1. You can get with the lower bit precision ADC, since the quantization error is averaged out. 2. You can get with the simple analog filter for antialiasing, since the sample rate is higher. But, the oversampling can't clean your signal from the noise which is present in the signal bandwidth. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
On Mar 16, 1:08 pm, Scott Seidman <namdiestt...@mindspring.com> wrote:> "stevepierson" <gkicomput...@yahoo.com> wrote innews:1174063927.072728.48=80@y80g2000hsf.googlegroups.com:> > > > > > > Hi, > > I've been reading quite a bit about oversampling and it's apparent use > > in noise reduction, but haven't been able to tie everything together. > > As I probably can't explain my exact question clearly, I'll give an > > example, I have a Analog Devices evaluation board with a 1MSPS A/D > > with CPU hooked up to a gryo. The gyro has a raw BW of 1000Hz, I have > > a single pole filter at 50Hz between it and the A/D (hooked up per the > > datasheet). I am sampling at 10X 50hz, or 500 Hz, since the single > > pole filter is not great. The datasheet indicates that the gryo noise > > is white Gaussian and I am seeing it as +/- 4 counts on the A/D, which > > agrees with the datasheet estimate with a 50Hz filter. > > > So my attempt here is to use oversampling to bring the noise down, I > > oversample at 4x,16x,32x, up to 256x and average the samples (every > > 500hz, or 2 mS). But I see no reduction in noise, still +/- 4 counts, > > no matter what. Well, thinking about it for a moment I realize that > > the data probably doesn't change much over a 2mS period (i.e., the > > noise is slow), it's just averaging the same number 256 times. > > > Ok, so the only way to get around this is to add higher frequency > > noise, which I can do by relaxing the output filter, I do this and the > > oversampling now brings down the noise, but, and here is the rub, when > > I relax the filter the overall noise increases, so the net result is I > > have the same noise as I did in the beginning :( > > > Now I can average multiple 2mS samples over a second to bring the > > noise down, but this obviously reduces the BW, which I don't want, and > > that is what I consider a normal filter, not oversampling. > > > So the question is, how can I use oversampling to reduce noise without > > signal loss? Or maybe I can't, that oversampling doesn't do what I > > think it does. It did reduce my external filtering requirements, I can > > see that, but I don't see any noise reduction capabilities without > > loss of signal content. > > > thanks for any help! > > > steve > > You have to define "oversampling" for us. The way I'm familiar with it, > its a valuable tool in signal reconstruction that allows one to > accurately reproduce the digitized signal without noise. When you think > about it this way, noise present when the data was acquired is considered > "signal". Oversampling deals with noise associated with analog playback, > not noise that has already been sampled. FWIW, it does this by > compressing the recorded info in frequency, allowing the analog output > filters to have gentler rolloffs. > > -- > Scott > Reverse name to reply- Hide quoted text - > > - Show quoted text -the oversampling I am talking about concerns input sampling, I am reading articles like this one https://www.mysilabs.com/public/documents/tpub_doc/anote/Microcontrollers/P= recision_Mixed-Signal/en/an118.pdf Key Points =B7 Oversampling and averaging can be used to increase measurement resolution, eliminating the need to resort to expensive, off-chip ADC's. =B7 Oversampling and averaging will improve the SNR and measurement resolution at the cost of increased CPU utilization and reduced throughput. =B7 Oversampling and averaging will improve signal- to-noise ratio for "white" noise.
"stevepierson" <gkicomputers@yahoo.com> wrote in news:1174070899.059642.36190@d57g2000hsg.googlegroups.com:> the oversampling I am talking about concerns input sampling, I am > reading articles like this one > > > https://www.mysilabs.com/public/documents/tpub_doc/anote/Microcontrolle > rs/Precision_Mixed-Signal/en/an118.pdf >Note that the noise your document refers to comes AFTER the ADC. Your noise, though, comes in before the ADC. -- Scott Reverse name to reply
On Mar 16, 1:20 pm, Vladimir Vassilevsky <antispam_bo...@hotmail.com> wrote: "But, the oversampling can't clean your signal from the noise which is present in the signal bandwidth." Ok, thinking about that statement, I think it makes sense now, my oversampling WAS removing any high frequency noise outside the signal bandwidth, but since there wasn't any HF noise, it wasn't removing any, that's why my 256 averaged oversampled result was exactly the same as 1 sample. The low frequency noise can't be distinguished from my signal, so really nothing I can do about that, unless I bring the bandwidth down. thanks for the help
stevepierson wrote: ...> https://www.mysilabs.com/public/documents/tpub_doc/anote/Microcontrollers/Precision_Mixed-Signal/en/an118.pdf > > Key Points > � Oversampling and averaging can be used to > increase measurement resolution, eliminating > the need to resort to expensive, off-chip ADC's. > � Oversampling and averaging will improve the > SNR and measurement resolution at the cost of > increased CPU utilization and reduced throughput. > � Oversampling and averaging will improve signal- > to-noise ratio for "white" noise.The noise being referred to is produced by the sampling process. The increase in resolution allows you to better see the noise riding on the input signal. Consider an attempt to record speech in a boiler factory. Everything coming into the microphone is signal in the DSP sense, despite its being called noise by the recording engineer. Oversampling won't diminish it. Jerry -- Engineering is the art of making what you want from things you can get. ¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯
Reply by ●March 17, 20072007-03-17
On Mar 16, 9:52 am, "stevepierson" <gkicomput...@yahoo.com> wrote:> Hi, > I've been reading quite a bit about oversampling and it's apparent use > in noise reduction, but haven't been able to tie everything together. > As I probably can't explain my exact question clearly, I'll give an > example, I have a Analog Devices evaluation board with a 1MSPS A/D > with CPU hooked up to a gryo. The gyro has a raw BW of 1000Hz, I have > a single pole filter at 50Hz between it and the A/D (hooked up per the > datasheet). I am sampling at 10X 50hz, or 500 Hz, since the single > pole filter is not great. The datasheet indicates that the gryo noise > is white Gaussian and I am seeing it as +/- 4 counts on the A/D, which > agrees with the datasheet estimate with a 50Hz filter. > > So my attempt here is to use oversampling to bring the noise down, I > oversample at 4x,16x,32x, up to 256x and average the samples (every > 500hz, or 2 mS). But I see no reduction in noise, still +/- 4 counts, > no matter what. Well, thinking about it for a moment I realize that > the data probably doesn't change much over a 2mS period (i.e., the > noise is slow), it's just averaging the same number 256 times. > > Ok, so the only way to get around this is to add higher frequency > noise, which I can do by relaxing the output filter, I do this and the > oversampling now brings down the noise, but, and here is the rub, when > I relax the filter the overall noise increases, so the net result is I > have the same noise as I did in the beginning :( > > Now I can average multiple 2mS samples over a second to bring the > noise down, but this obviously reduces the BW, which I don't want, and > that is what I consider a normal filter, not oversampling. > > So the question is, how can I use oversampling to reduce noise without > signal loss? Or maybe I can't, that oversampling doesn't do what I > think it does. It did reduce my external filtering requirements, I can > see that, but I don't see any noise reduction capabilities without > loss of signal content. > > thanks for any help! > > steveI think you may be confusing the issues of "noise reduction" and "signal estimation", the latter which may be more useful here. There are numerous papers which deal with this; here is one: http://tinyurl.com/2cqowo Tom
stevepierson wrote: ...> Ok, so the only way to get around this is to add higher frequency > noise, which I can do by relaxing the output filter, I do this and the > oversampling now brings down the noise, but, and here is the rub, when > I relax the filter the overall noise increases, so the net result is I > have the same noise as I did in the beginning :(When starting out on the wrong foot, it's easy to march off into absurdity. Adding noise for the pleasure of eliminating it later is an example. ... Jerry -- Engineering is the art of making what you want from things you can get. ¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯
