Oversampling for noise reduction
Started by stevepierson ●March 16, 2007
On Mar 17, 4:44 pm, Jerry Avins <j...@ieee.org> wrote:
> stevepierson wrote: > > ... > > > Ok, so the only way to get around this is to add higher frequency > > noise, which I can do by relaxing the output filter, I do this and the > > oversampling now brings down the noise, but, and here is the rub, when > > I relax the filter the overall noise increases, so the net result is I > > have the same noise as I did in the beginning :( > > When starting out on the wrong foot, it's easy to march off into > absurdity. Adding noise for the pleasure of eliminating it later is an > example. > > ... > > Jerry > -- > Engineering is the art of making what you want from things you can get. > =AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=
=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF= =AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF i'll forward your tidbid to the dither folks....
stevepierson wrote:
> On Mar 17, 4:44 pm, Jerry Avins <j...@ieee.org> wrote: > >> When starting out on the wrong foot, it's easy to march off into >> absurdity. Adding noise for the pleasure of eliminating it later is an >> example. > > i'll forward your tidbid to the dither folks....
If the dither folks are knowledgable and honest I'm sure they will agree with Jerry. Dither is applied during re-quantisation of a signal (ie converting from float or 24 bit integer to 16 bit integer) by adding noise which aims to make the discrete tones that are a by product of re-quanisation less obvious. See : http://en.wikipedia.org/wiki/Dither Erik -- +-----------------------------------------------------------+ Erik de Castro Lopo +-----------------------------------------------------------+ "We have fifty million Muslims in Europe. There are signs that Allah will grant Islam victory in Europe - without swords, without guns, without conquests. The fifty million Muslims of Europe will turn it into a Muslim continent within a few decades." -- Libyan leader Mu'ammar Al-Qadhafi http://www.memritv.org/Transcript.asp?P1=1121
