hi, have anybody configured slip for balckfing dsp BF533. My SLIP config through serial cable works. but with the dsp, not a single byte of data is being delivered. i have checked the serial line configuration using the stty command. i have disabled any flow control. still i am unable to transfer any data. any help appreciated. amar
slip and blackfin
Started by ●May 25, 2004
Reply by ●June 2, 20042004-06-02
Hi, though posted it long back, i thought it would be worhtwhile to follow this up as I found the solution and it might be useful for somebody someday. finally it worked with the following commands slattach -p slip -s 115200 -e ttyS0 stty -F /dev/ttyS0 -icanon -crtscts -ignbrk clocal slattach -p slip -s 115200 -m ttyS0 & basically the crtscts option which is not supported by the DSP was not being disabled. the above commands helped doing it. amar amaraavati@yahoo.com (amara vati) wrote in message news:<f89b870.0405242255.7f5d1c89@posting.google.com>...> hi, > > have anybody configured slip for balckfing dsp BF533. My SLIP config > through serial cable works. but with the dsp, not a single byte of > data is being delivered. i have checked the serial line configuration > using the stty command. i have disabled any flow control. still i am > unable to transfer any data. any help appreciated. > > amar
