Hi I want to use microphone array for DoA estimation.For DoA estimation,I require the data (which will be processed to find angle of arrival).I want to know how to take input audio data on PC .On my LAPTOP,i have only one microphone input so how can I get multiple channels on single microphone input. Thanks Salrome _____________________________________ Do you know a company who employs DSP engineers? Is it already listed at http://dsprelated.com/employers.php ?
multi channel Audio input to PC through single microphone in MATLAB
Started by ●April 13, 2007
Reply by ●April 13, 20072007-04-13
salrome wrote:> Hi > > I want to use microphone array for DoA estimation.For DoA estimation,I > require the data (which will be processed to find angle of arrival).I want > to know how to take input audio data on PC .On my LAPTOP,i have only one > microphone input so how can I get multiple channels on single microphone > input. > > Thanks > > SalromeYou can't (or at least, you really will not want to use analog multiplexing for such a task! And laptop mic inputs are rarely high-quality or noise-free). A rather vital piece of information is: how many microphones? What type? Capacitor or dynamic? Capacitor microphones need external "phantom" power. Elecret mics (which can be pro quality) use internal batteries. And what sample rate and word length etc? What interfaces does your laptop have (e.g. USB 1 or USB 2? Firewire (4-pin or 6-pin)). You will need an external soundcard (e.g. USB 1/2, Firewire if your laptop supports it). There are many such devices around at a wide range of prices, serving the pro, semi-pro and domestic audio markets (e.g. M-Audio, Roland (Edirol), Behringer, etc). High-end systems will provide 8 channels or more, complete with phantom power mic preamps (but use external power supply if conencting to the laptop via USB etc). Old USB 1 cannot really handle more than about 6 channels (there is one Emagic device that managed it); for safety (and especially if wanting pro sample rates and 16bit audio or better) if using more than 4 mics, you would want USB 2 or Firewire. If just using two microphones, there are many inexpensive USB-1 devices with built-in preamps that will do very nicely. The alternative solution for multiple mics is a portable mixer, sending line-level audio to simple line-input sound cards. Depends on what you are prepared to carry around, if that is an issue. You need decent hardware such as a mixer, and good preamps, as matching the levels will be a critical task. Software to record multiple channels together is yet another matter. Richard Dobson
Reply by ●April 14, 20072007-04-14
On Apr 13, 10:06 pm, "salrome" <usman01as...@gmail.com> wrote:> Hi > > I want to use microphone array for DoA estimation.For DoA estimation,I > require the data (which will be processed to find angle of arrival).I want > to know how to take input audio data on PC .On my LAPTOP,i have only one > microphone input so how can I get multiple channels on single microphone > input. > > Thanks > > Salrome > > _____________________________________ > Do you know a company who employs DSP engineers?> Is it already listed athttp://dsprelated.com/employers.php?With the majority of sound cards you are limited to 2 mics. Beoyond that you need either a special sound card or A/D convertors. You need a pre-amp probably as well - one for each channel. Wang King
Reply by ●April 19, 20072007-04-19
>On Apr 13, 10:06 pm, "salrome" <usman01as...@gmail.com> wrote: >> Hi >> >> I want to use microphone array for DoA estimation.For DoA estimation,I >> require the data (which will be processed to find angle of arrival).Iwant>> to know how to take input audio data on PC .On my LAPTOP,i have onlyone>> microphone input so how can I get multiple channels on singlemicrophone>> input. >> >> Thanks >> >> Salrome >> >> _____________________________________ >> Do you know a company who employs DSP engineers? > >> Is it already listed athttp://dsprelated.com/employers.php? >With the majority of sound cards you are limited to 2 mics. Beoyond >that you need either a special sound card or A/D convertors. You need >a pre-amp probably as well - one for each channel. > >Wang King > >I have got the sound card Creative Audigy 4 pro for multiple microphone input.I would be glad if some one has info regarding 1.How to connect multiple microphones to this card,which ports will be used. 2.How can I read the audio data from the microphones through the sound card in MATLAB 3-which additional equipment will be required for getting data into computer Best Regards salrome _____________________________________ Do you know a company who employs DSP engineers? Is it already listed at http://dsprelated.com/employers.php ?
