Hi all, I m currently doing hardware in the loop JTAG cosimulation test using XTREME DSP Development Kit 2. The FPGA onboard is a Virtex 2 XC2V3000-4FG676. My problem is when i try to run simulation for my Simulink model that has the cosim block connected in my original design i get an error message:"Error configuring device, a problem may exist in the hardware configuration . Check that the cable , scan chain and power connection are intact, that the specified scan chain configuration matches the actual hardware, and that the power supply is adequate and delivering the correct voltage".. I would appreciate if some one can point me in the right direction because the manuals never really touch on this issue, they presume this is pretty plug and play.Apparently it isnt. And thanks for the info last time, Martin, u were a great help.
XTREME DSP Development Kit JTAG Problem
Started by ●April 19, 2007
