Pin Description ADSP-21364
Started by daniel.bojara May 15, 2007
Hi,
i can't find the Pin Description for the ADSP-21364 with 144 LQFP
Package!!
can somebody help me?
thx
_____________________________________
Do you know a company who employs DSP engineers?
Is it already listed at http://dsprelated.com/employers.php ?
"daniel.bojara" <daniel.bojara@web.de> wrote in news:l4adna4K-
fin2tfbnZ2dnUVZ_sSmnZ2d@giganews.com:
> Hi, > > i can't find the Pin Description for the ADSP-21364 with 144 LQFP > Package!! > > can somebody help me? > > thx > > > > _____________________________________ > Do you know a company who employs DSP engineers? > Is it already listed at http://dsprelated.com/employers.php ? >
http://www.analog.com/UploadedFiles/Data_Sheets/ADSP21362_21363_21364_21365 _21366.pdf I would suggest using the ADSP-21369 instead or sticking with the 21261/2 -- Al Clark Danville Signal Processing, Inc. -------------------------------------------------------------------- Purveyors of Fine DSP Hardware and other Cool Stuff Available at http://www.danvillesignal.com
Thanks, but ....
"http://www.analog.com/UploadedFiles/Data_Sheets/ADSP21362_21363_21364_21365_21366.pdf"
--> is only the description for the 136-Ball BGA Description inside!
"I would suggest using the ADSP-21369 instead or sticking with the
21261/2"
--> why?
news:sdKdnTnAYcJUd9fbnZ2dnUVZ_syunZ2d@giganews.com:
> Thanks, but .... > > > > "http://www.analog.com/UploadedFiles/Data_Sheets/ADSP21362_21363_21364_ > 21365_21366.pdf" > > --> is only the description for the 136-Ball BGA Description inside! > > > > > "I would suggest using the ADSP-21369 instead or sticking with the > 21261/2" > > --> why? >
The ADSP-21369 has better periphearal support including an SDRAM controller, I2C and UARTs + all the 21364 peripherals. I discuss the 21369 and the current status of the SHARC on our web site (on the home page). Our business is built around third generation SHARC DSPs (OEM boards and systems). The 21261/2 is less expensive. Both the 21262 and 21369 function very well. The 21364 suffers from a serious DMA errata problem. You can download the errata from the ADI site. Al Clark Danville Signal Processing, Inc. -------------------------------------------------------------------- Purveyors of Fine DSP Hardware and other Cool Stuff Available at http://www.danvillesignal.com
