Problem with C6713's McBSP interfacing with an I2S CODEC
Started by Jessecw May 31, 2007
Hi All,
     I am going to connect an audio CODEC with C6713. And the CODEC
has no DSP mode. So I want to use McBSP as an I2S bus.
     Here are parts of my schematic.
     DSP C6713:                 CODEC:
     CLKX1----------+
                           +------------MCLK (bit clock signal)
     CLKR1----------+
     FSX1-----------+
                          +------------LRCK
     FSR1-----------+
     Here is an example McBSP setting from TI's TMS320C6000 McBSP: I2S
Interface.
     FSX is output pin
     FSR is output pin
     CLKX is output pin
     CLKR is output pin
     My question is: If all pins are set as output pin, will CLKR1 or
FSR1 work properly? or Are there any problems with my schematic?
     Thanks in advance.
Jesse
Sorry forget to say that "+" means connected together.
Thanks
Jesse
On 5 31 ,   5 35 , Jessecw <jessechen...@gmail.com> wrote:
> Hi All, > > I am going to connect an audio CODEC with C6713. And the CODEC > has no DSP mode. So I want to use McBSP as an I2S bus. > > Here are parts of my schematic. > > DSP C6713: CODEC: > CLKX1----------+ > +------------MCLK (bit clock signal) > CLKR1----------+ > > FSX1-----------+ > +------------LRCK > FSR1-----------+ > > Here is an example McBSP setting from TI's TMS320C6000 McBSP: I2S > Interface. > FSX is output pin > FSR is output pin > CLKX is output pin > CLKR is output pin > > My question is: If all pins are set as output pin, will CLKR1 or > FSR1 work properly? or Are there any problems with my schematic? > > Thanks in advance. > > Jesse
