In deciding whether an athlete has recovered from a concussion, his performance in cognitive tests taken after injury is compared to those taken before injury. The test results consist of around 100 data points which measure reaction times under various conditions. The usual method for answering the question as to whether an athlete has recovered from a concussion is to compare the means of the reaction times for the 2 tests. My question relates to whether the sets of data points might be viewed as digital signals and whether cross correlating the signals would reveal anything useful.
Cross correlation applicable?
Started by ●June 12, 2007
Reply by ●June 12, 20072007-06-12
On 12 Jun, 13:49, "cl" <cliff.ly...@gmail.com> wrote:> In deciding whether an athlete has recovered from a concussion, his > performance in cognitive tests taken after injury is compared to those > taken before injury. The test results consist of around 100 data points > which measure reaction times under various conditions. The usual method > for answering the question as to whether an athlete has recovered from a > concussion is to compare the means of the reaction times for the 2 tests. > > My question relates to whether the sets of data points might be viewed as > digital signalsIn principle, yes. One might assume that the athlete becomes more tired as tests progress, and that a development in reaction times during the experiment might tell you something about his stamina.> and whether cross correlating the signals would reveal > anything useful.Not unless the experiment was designed with correlation analysis in mind. The experimentalist would have to control factors like the environment where the experiment takes place, the athlete's preparation in terms of food and sleep, etc. If such factors were NOT acounted for, forget about correlation analysis and stick with hypothesis tests. Rune
