21061 EZ-Kit lite session
Started by nagelg August 13, 2007
Hello,
I have tried the csv “csv_adsp.zip” files from evert to  support the
adsp-21061 ez-lite kit. But it does not work.
I have got the files for the VisualDSP Version 3.0, 3.5 and 4.0.
What must I do, that the EZ-Kit Lite works with V3.5 and V4.0. I have
copied the csv files:
- Regfile61_EZKIT.csv ( in system directory visualdsp )
- Regfile.csv ( "" "" )
into the visual dsp3.5 directory.
In the Configurator of the Session it is not possible to get the EZ-Kit
Lite with RS232 Connection. I think, that the driverfile
“Wm21061Ez.dll” is missing. I have tried to use the driverfile from
V3.0. But it does not work.
Does anybode know, whats the problem?
Best regards
I just bumped into this situation as well.  I'm setting up VDSP 4.5 with a
 Danville Signal DSPstak, but would like to continue to talk to a 21061
EZ-Kit as well.
Did you find a solution?
Rick Garner
Inspired Systems
>Hello, > >I have tried the csv “csv_adsp.zip” files from evert to support the >adsp-21061 ez-lite kit. But it does not work. > >I have got the files for the VisualDSP Version 3.0, 3.5 and 4.0. > >What must I do, that the EZ-Kit Lite works with V3.5 and V4.0. I have >copied the csv files: >- Regfile61_EZKIT.csv ( in system directory visualdsp ) >- Regfile.csv ( "" "" ) >into the visual dsp3.5 directory. > >In the Configurator of the Session it is not possible to get the EZ-Kit >Lite with RS232 Connection. I think, that the driverfile >“Wm21061Ez.dll” is missing. I have tried to use the driverfile from >V3.0. But it does not work. > >Does anybode know, whats the problem? > >Best regards > > > > >
I too have run into this situation. I realize this is an ancient thread but
if the csv_adsp.zip file still available I would really like to get a copy
of it so I may use my 21061 EZ-Kit lite in VisualDSP++.
Thanks,
Mike
> Danville Signal DSPstak, but would like to continue to talk to a 21061 >EZ-Kit as well. > >Did you find a solution? > >Rick Garner >Inspired Systems >
