I'm trying to convolve two vectors by using the Fourier transform. I take the Fourier transform of both vectors, multiple them, and then take the inverse Fourier transform. My convolved signal should only contain real numbers, however, my result contains both real and imaginary numbers. Do I need to add the real and imaginary parts together to get the convolution?
Convolution via Fourier Transform
Started by ●August 15, 2007
Reply by ●August 15, 20072007-08-15
On Aug 15, 11:30 am, Chris Barrett <"chrisbarret"@0123456789abcdefghijk113322.none> wrote:> I'm trying to convolve two vectors by using the Fourier transform. I > take the Fourier transform of both vectors, multiple them, and then take > the inverse Fourier transform. My convolved signal should only contain > real numbers, however, my result contains both real and imaginary > numbers. Do I need to add the real and imaginary parts together to get > the convolution?You're probably violating some symmetry condition somewhere. Did you zero-pad your signals to the proper, same length? How did you "compute" the Fourier transform exactly? Suppose you want to compute y[n] = x[n] * h[n]. If you do this properly, you would get X[k] the DFT of x[n] to be conjugate-symmetric, H[k] the DFT of h[n] to also be conjugate- symmetric. Hence Y[k] = X[k] . H[k] is also conjugate symmetric, and thus y[n] the inverse DFT of Y[k] is purely real. Now, where did your scheme break down? Julius
On Aug 15, 9:30 am, Chris Barrett <"chrisbarret"@0123456789abcdefghijk113322.none> wrote:> I'm trying to convolve two vectors by using the Fourier transform. I > take the Fourier transform of both vectors, multiple them, and then take > the inverse Fourier transform. My convolved signal should only contain > real numbers, however, my result contains both real and imaginary > numbers.Are the imaginary components of the result very tiny relative to the real components? If so, they could just be rounding noise resulting from the accuracy limits of floating point arithmetic. What happens if you do an FFT and IFFT without any modifying multiplications? IMHO. YMMV. -- rhn A.T nicholson d.0.t C-o-M
"Chris Barrett" <"chrisbarret"@0123456789abcdefghijk113322.none> wrote in message news:GUFwi.102728$g86.8527@newsfe14.lga...> I'm trying to convolve two vectors by using the Fourier transform. I take > the Fourier transform of both vectors, multiple them, and then take the > inverse Fourier transform. My convolved signal should only contain real > numbers, however, my result contains both real and imaginary numbers. Do > I need to add the real and imaginary parts together to get the > convolution? >The rule for convolution by this method is that the transforms be of equal length and at least M+N-1 samples each; where M is the original length of one sequence and N is the original length of the other. Zero pad each to the same length that's at least M+N-1 and see if that doesn't make things improve. Fred
On Aug 16, 10:13 am, "Fred Marshall" <fmarshallx@remove_the_x.acm.org> wrote:> "Chris Barrett" <"chrisbarret"@0123456789abcdefghijk113322.none> wrote in > messagenews:GUFwi.102728$g86.8527@newsfe14.lga... > > > I'm trying to convolve two vectors by using the Fourier transform. I take > > the Fourier transform of both vectors, multiple them, and then take the > > inverse Fourier transform. My convolved signal should only contain real > > numbers, however, my result contains both real and imaginary numbers. Do > > I need to add the real and imaginary parts together to get the > > convolution? > > The rule for convolution by this method is that the transforms be of equal > length and at least M+N-1 samples each; where M is the original length of > one sequence and N is the original length of the other. Zero pad each to > the same length that's at least M+N-1 and see if that doesn't make things > improve. > > FredDon't you need to overlap and add otherwise the result is circular.
Reply by ●August 16, 20072007-08-16
"HardySpicer" <gyansorova@gmail.com> wrote in message news:1187216367.266241.84480@e9g2000prf.googlegroups.com...> On Aug 16, 10:13 am, "Fred Marshall" <fmarshallx@remove_the_x.acm.org> > wrote: >> "Chris Barrett" <"chrisbarret"@0123456789abcdefghijk113322.none> wrote in >> messagenews:GUFwi.102728$g86.8527@newsfe14.lga... >> >> > I'm trying to convolve two vectors by using the Fourier transform. I >> > take >> > the Fourier transform of both vectors, multiple them, and then take the >> > inverse Fourier transform. My convolved signal should only contain >> > real >> > numbers, however, my result contains both real and imaginary numbers. >> > Do >> > I need to add the real and imaginary parts together to get the >> > convolution? >> >> The rule for convolution by this method is that the transforms be of >> equal >> length and at least M+N-1 samples each; where M is the original length of >> one sequence and N is the original length of the other. Zero pad each to >> the same length that's at least M+N-1 and see if that doesn't make things >> improve. >> >> Fred > > Don't you need to overlap and add otherwise the result is circular. >The result is circular no matter what. What's important is that there's no overlap in time after doing the convolution. A circular convolution in time would be the same. The sequences would have to be padded to avoid overlap. I don't understand "overlap and add" in this context.... It's just one convolution, not a series of them. Not a streaming situation as I understand it. Fred
On Aug 16, 1:19 am, "Fred Marshall" <fmarshallx@remove_the_x.acm.org> wrote:> "HardySpicer" <gyansor...@gmail.com> wrote in message > > news:1187216367.266241.84480@e9g2000prf.googlegroups.com... > > > > > On Aug 16, 10:13 am, "Fred Marshall" <fmarshallx@remove_the_x.acm.org> > > wrote: > >> "Chris Barrett" <"chrisbarret"@0123456789abcdefghijk113322.none> wrote in > >> messagenews:GUFwi.102728$g86.8527@newsfe14.lga... > > >> > I'm trying to convolve two vectors by using the Fourier transform. I > >> > take > >> > the Fourier transform of both vectors, multiple them, and then take the > >> > inverse Fourier transform. My convolved signal should only contain > >> > real > >> > numbers, however, my result contains both real and imaginary numbers. > >> > Do > >> > I need to add the real and imaginary parts together to get the > >> > convolution? > > >> The rule for convolution by this method is that the transforms be of > >> equal > >> length and at least M+N-1 samples each; where M is the original length of > >> one sequence and N is the original length of the other. Zero pad each to > >> the same length that's at least M+N-1 and see if that doesn't make things > >> improve. > > >> Fred > > > Don't you need to overlap and add otherwise the result is circular. > > The result is circular no matter what. What's important is that there's no > overlap in time after doing the convolution. A circular convolution in time > would be the same. The sequences would have to be padded to avoid overlap. > > I don't understand "overlap and add" in this context.... It's just one > convolution, not a series of them. Not a streaming situation as I > understand it. > > FredAs long as the 2 input signals were real then the output of the IFFT should be real as well - The size of the FFTs or overlapping won't affect the fact he's getting imaginary numbers back. Usually there is some noise in the FFT so the imaginary component is quite small wrt the real component, in this case I just ignore the imaginary portion of the result. An alternative is to use a FFT algorithm specifically designed for real data. The algorithm assumes the complex conjugate symmetry and returns only the real portion when doing an IFFT. Cheers, Dave
