Floyd L. Davidson wrote: (snip)> In a digital channel you cannot pass frequencies higher > 1/2 the Nyquist rate, which in theory is a very sharp > cutoff but in practice it becomes very similar to the > gradual analog cutoff.If you read Nyquist's paper, that is pretty much it. He was figuring out for fast he could send pulses through a band limited channel and separate them out at the other end. Electronic communication was digital before it was analog. -- glen
Questions about equivalents of audio/video and digital/analog.
Started by ●August 19, 2007
Reply by ●August 20, 20072007-08-20
Jerry Avins <jya@ieee.org> wrote:>Dave Platt wrote: >> In article <1187572498.074750.50210@i38g2000prf.googlegroups.com>, >> Radium <glucegen1@gmail.com> wrote: >> >>> I'm curious to why there are no purely-analog devices which can >>> record, store, and playback electric audio signals [AC currents at...>> The net result is that an audio CCD is capable of >> storing a >> decent-quality signal for only a few tens or hundreds of milliseconds, >> from input to output. >> Another sort of a purely analog signal-storage device, >> with no moving >> parts other than the electrons which convey the signal, is a simple >> length of transmission line (with perhaps some amplifiers mid-way)....>Come on, Dave, a CCD is a digital device, subject to >aliasing.CCDs are analog devices, with an analog voltage output. The fact that they are commonly used as the sensor in digital cameras results in the output of a CCD virtually always going directly (well, after a bit of signal processing for things such as white balance, ISO gain, etc.) to an analog-to-digital converter that digitizes the analog signal.>The charges represent the signal at a >particular instant of its average over a particular >interval. (My CCD digital camera can take time >exposures.) A CCD's content may not be quantized in >amount, but it is quantized in time. In a camera, where >the charges pertain to individual pixels, the result is >also quantized in space.But none of that quantization changes the fact that the device itself has an analog output. -- Floyd L. Davidson <http://www.apaflo.com/floyd_davidson> Ukpeagvik (Barrow, Alaska) floyd@apaflo.com
nospam@nospam.com (Don Pearce) wrote:>On Sun, 19 Aug 2007 23:26:16 -0700, dplatt@radagast.org (Dave Platt) >wrote: > >>"Digital" and "subject to aliasing" are two different things. >> >>As I believe the term "digital" is usually meant, it implies a >>two-state (on/off) storage representation. It's not just that theThat describes a binary digital system. Not all digital systems are binary. What is called M-ary is very common, with multiple states.>>signal amplitude is quantized, but that the quantization uses a >>power-of-two representation and storage system of some sort.It doesn't require a power of two representation, though that certainly makes a lot of other functionality much easier. The key is "discrete states" from a "finite set". That makes it digital.>My reading of the possible systems goes like this. > >analogue - a continuous representation of the original signal >sampled - a representation of the signal at discrete time pointsNote that discrete time points does not make a signal digital, if the value of the signal can still be varied infinitely.>quantized - a sampled signal, but with the possible levels constrained >to a limited set of valuesThat is by definition a digital siganl. As soon as the possible values are "constrained to a limited set", it is by definition digital data.>digital - a quantized signal, with the individual levels represented >by numbersIt makes no difference how the levels are represented.>Aliasing is going to happen as soon as you move beyond the first line >of that list.Your definitions are pretty good! The significant points are that analog is continuous with an infinite set of values, while digital has a discrete number of values from a finite set. The standard definitions of analog data and digital data (these are milspec and Federal Standard 1037C definitions) are: analog data: Data represented by a physical quantity that is considered to be continuously variable and has a magnitude directly proportional to the data or to a suitable function of the data. digital data: 1. Data represented by discrete values or conditions, as opposed to analog data. 2. Discrete representations of quantized values of variables, e.g. , the representation of numbers by digits, perhaps with special characters and the "space" character. See http://glossary.its.bldrdoc.gov/fs-1037/ -- Floyd L. Davidson <http://www.apaflo.com/floyd_davidson> Ukpeagvik (Barrow, Alaska) floyd@apaflo.com
Jerry Avins <jya@ieee.org> wrote:>I like your categories. It is possible in concept to >have a signal that is quantized in magnitude and >continuous in time, but (unless we resort to counting >electrons) I don't think it's possible in practice.If you quantize the magnitude, it is digital. That is by definition. -- Floyd L. Davidson <http://www.apaflo.com/floyd_davidson> Ukpeagvik (Barrow, Alaska) floyd@apaflo.com
